Patrick Marsden Posted January 6, 2021 Share Posted January 6, 2021 I have got hold of an ESM/YT F7F Tigercat which I am going to electrify. I have seen the 4 Max recommended set up but havent had a reply to an enquiry re 3 bladed props so havent decided on a set up yet. Has anyone got the above aircraft and if so what set-up are you using, preferably with 3 bladed props for a more scale look. Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted January 9, 2021 Share Posted January 9, 2021 Hi, George's (4-Max) set up is on his web site and if in doubt give him a phone call to discuss your requirements. Looking at the videos its not short of power using his spec. PS IMHO 3 blade props don't perform as well as a 2 blade and there are those that display with a three blade and fly on two blade props. Plus if using std/pusher props there is less choice and even less with three blades. Kit by ASM Built by George Worley Model Grumman F7F Tigercat Wingspan 82" / 2082mm Flying Weight 21lbs / 9525g Motor 2x PO-5065-420 Prop 2x JXF 14" x 10 " (1 standard, 1 pusher) Battery 2x 6 cell 5000mAh LiPo battery ESC 2x 4M-ESC70A + 20A UBEC + Green Servo Power Distribution Box Quote Link to comment Share on other sites More sharing options...
Patrick Marsden Posted January 10, 2021 Author Share Posted January 10, 2021 Posted by Chris Walby on 09/01/2021 18:59:22: Hi, George's (4-Max) set up is on his web site and if in doubt give him a phone call to discuss your requirements. Looking at the videos its not short of power using his spec. PS IMHO 3 blade props don't perform as well as a 2 blade and there are those that display with a three blade and fly on two blade props. Plus if using std/pusher props there is less choice and even less with three blades. Kit by ASM Built by George Worley Model Grumman F7F Tigercat Wingspan 82" / 2082mm Flying Weight 21lbs / 9525g Motor 2x PO-5065-420 Prop 2x JXF 14" x 10 " (1 standard, 1 pusher) Battery 2x 6 cell 5000mAh LiPo battery ESC 2x 4M-ESC70A + 20A UBEC + Green Servo Power Distribution Box Thanks for the info Chris, interesting re the props. I'm guessing that George is really busy, have tried ringing on several occasions and have sent 2 emails as per his voicemail message but no reply yet. I'm in no rush so not urgent. Quote Link to comment Share on other sites More sharing options...
