Dean Hunter Posted January 7, 2021 Share Posted January 7, 2021 Rx AR6335, E-flite 10amp ESC, DX7s Bind plug in Rx Battery plugged in Rx flashes, DXts switched on binding Rx light goes constant Rudder Aileron etc work, motor does not!!!!! System beeps..... So what is the problem? The control surfaces all move as the should but the but "twitches" Would a faulty ESC be the problem? Any advice very welcome Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted January 7, 2021 Share Posted January 7, 2021 Continuous beeps? Maybe the throttle needs training? If your ESC manual doesn't explain let us know... Quote Link to comment Share on other sites More sharing options...
Speedster Posted January 7, 2021 Share Posted January 7, 2021 Turn on power on the plane. Hold the plane Set throttle to max Turn on the tx and after a few beeps pull the throttle back to 0, then the esc is calibratet. aaaaand ready to go after the cell count.beeps This should be done with a new rx or new esc. You can maybe also just try to set the throttle throw to max and /or first try to give max pull back trim, sometimes this is enough to arm the esc. But the right way is to calibrate it as first described, then the esc know where 0 and full power is and it will arm the esc when powered up next time Cheers Soren Edited By Speedster on 07/01/2021 18:14:54 Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted January 7, 2021 Share Posted January 7, 2021 With just your Transmitter On Dean Reverse the throttle. Switch off the Tx. Now go through your set up again Quote Link to comment Share on other sites More sharing options...
Dean Hunter Posted January 7, 2021 Author Share Posted January 7, 2021 The advice sounds good. Some of which I have tried - but most I haven't. Will get back to you all Quote Link to comment Share on other sites More sharing options...
Paul C. Posted January 7, 2021 Share Posted January 7, 2021 Please remove the prop first before testing A&E are very busy at the moment 😱 Quote Link to comment Share on other sites More sharing options...
Dean Hunter Posted January 8, 2021 Author Share Posted January 8, 2021 Hi Folks - just spent an hour and got nowhere!! The most I have achieved is the prop turns slowly!! Can I have options please? But presented as a total idiots guide.... Quote Link to comment Share on other sites More sharing options...
Peter Smith Posted January 8, 2021 Share Posted January 8, 2021 It may be that your throttle trim tab needs adjusting to fully on. Do this then re bind the receiver. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted January 8, 2021 Share Posted January 8, 2021 Posted by Dean Hunter on 08/01/2021 14:35:04: Hi Folks - just spent an hour and got nowhere!! The most I have achieved is the prop turns slowly!! Can I have options please? But presented as a total idiots guide.... A 10 Amp ESC suggests quite a low powered model but iit would be a really good idea to remove the propeller when you're doing any setting up. Even a small prop can inflict significant injury and even if you survive an inadvertant full throttle blast, the model may well damage itself. It's a good habit to get into... Quote Link to comment Share on other sites More sharing options...
Guillaume Posted September 28, 2023 Share Posted September 28, 2023 Hello everybody ! i am facing exactly the same problem as mentioned above … All control surfaces are moving after binding but motor won’t arm.. Tried all the above solutions but nothing is working for me .. 😑 Any further advices ? Thanks in advance. Guillaume Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 28, 2023 Share Posted September 28, 2023 William, are you getting steady Beeps from the motor ? Quote Link to comment Share on other sites More sharing options...
john davidson 1 Posted September 28, 2023 Share Posted September 28, 2023 Make sure the throttle trim is right down as far as it will go 1 Quote Link to comment Share on other sites More sharing options...
Guillaume Posted September 28, 2023 Share Posted September 28, 2023 6 hours ago, Denis Watkins said: William, are you getting steady Beeps from the motor ? Either short beeps repeated and nothing happens, or, when I invert the throttle chanel, I get 1 , then 2 then 3 beeps and again the same sequence… Quote Link to comment Share on other sites More sharing options...
Guillaume Posted September 28, 2023 Share Posted September 28, 2023 5 hours ago, john davidson 1 said: Make sure the throttle trim is right down as far as it will go It is.. all trimmed down.. Quote Link to comment Share on other sites More sharing options...
Guillaume Posted September 28, 2023 Share Posted September 28, 2023 (edited) I am with a multiprotocole radio (RadioMaster Zorro), I tried before with another multiprotocole radio and it did not work neither.. The point is : with a spectrum radio (DX7s) everything was ok and the ESC armed without any issue.. I bet there is one only thing I am not doing right but which one ? I have no f***ing clue .. 😑 Edited September 28, 2023 by Guillaume Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 29, 2023 Share Posted September 29, 2023 20 hours ago, Guillaume said: Either short beeps repeated and nothing happens, or, when I invert the throttle chanel, I get 1 , then 2 then 3 beeps and again the same sequence… Yes, the 1,2,3 is inviting you to set the throttle The manufacturer of your ESC should give you their sequence But You can try your self moving your throttle from high to low ( with the prop OFF ) during the beeps Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted September 29, 2023 Share Posted September 29, 2023 Changing the throttle input value from 100%.... I'm sure someone mentioned this to me in the dim and distant past......trial and error I'm afraid Quote Link to comment Share on other sites More sharing options...
