Electric Grumpy Tigercub
Well folks as the club mass Ohmen build edged towards completion last year a couple of us thought about the next build. If you don’t know already then it will soon become apparent that I have a preference for ic twins and although this build will be electric it is at least a twin.
There are already a few build logs here for ic versions (as per the original design) and electric plus scaled up with retracts and flaps, but for me it will be a straight as possible standard build.
Boring for the experienced builders out there although I would like it to be helpful to those like me who don’t have decades of building under their belt and want a proven good flyer
Cheat 1 – Kit purchased from Sarik last year
Cheat 2 – Electrical bits purchased from 4-Max last year
Cheat 3 – Read through all of the build logs here to gleam any information I could
For those that aren’t familiar with Peter Miller’s Grumpy Tiger Cub its vital statistics are:
Wingspan: 53in (2125 mm)
Weight: 4 lb 11 oz( 2.126 Kg),
Wing area: 500sqin( dm
2
Wing loading: 21oz/sq ft ( g/dm
2
Servos: 4max 2x 10g and 2x 45g)
Retracts: Fixed
Motor: 4-Max 3035 870Kv
ESC: 30A x 2 + 5A UBEC
Prop: 9x6 tractor and pusher
Battery: 4 S 3700mAh (I have 4S3300 so will use those)
Calculated thrust (4max) 4.6 lbs (weighs 4.68 lbs) 2068g
Calculated speed 62 mph
Lets start the build and hope I can keep the building work with the pace of posting updates
Things to consider pre-build
  • Canopy from Steve at Vortex, big thanks as there was so waiting due to COVID 19 but no rush and good job
  • Modification of the cowls/nacelles to suit the electric set up
  • Modification to the fuselage for the battery access
Nothing major and looking at the drawings it has Peter's signature design/construction style throughout which is reassuring from the experience gained from the Ohmen build and limited overall experience.
I will be using the plasterboard and plastic sheet method of bas board and dusting down the SLEC board for the fuselage once I have cleared enough bench space. I thought I would get clever and attach the drawings on both sides of the plaster board which does limit the “I just need a peek to check that” if there is balsa and pins stuck in.
Posted by Chris Walby on 10/01/2021 07:55:01:
Hey Chris,
... it seems that the inches are quite a bit larger in the UK than they are on the Continent... surprise
... but then that's probably the reason why I'm still an apprentice modeller...
Cheers & keep the faith
Chris
Posted by McG 6969 on 10/01/2021 09:42:50:
Hey Chris,
Chris
Hi Chris (The one from Belgium)
You forget that since 1st January 2021 we can make our inches as big as we like wink
Levanter
Thanks for the feedback and having checked it would appear that the incorrect conversion (Trump) factor was used resulting in a wildly inaccurate wingspan, the correct size should be 1346 mm.
Piers, I have PM'ed you regarding your question.
The build continues with assembly of the nacelles and the wings.
Only mod to the nacelle was a large hole cut in N2 to allow the ESC control wire through as the power cables will traverse via the unused aileron pushrod/bell crank rib holes. I'll be using in wing aileron servos just in case I fancy a bit of flaperon or differential later on. Oh and I made the motor stand-off on my 1940's Myford lathe.
Nothing to report on the wing build, all standard assembly with just the wings to join and nacelles to fix later on.
Edited By Chris Walby on 11/01/2021 11:40:18
On with the build and having moved more static useful items (rubbish, parts, materials for other projects and tools) from the end work surface I set the SLEC building board for the fuselage assembly to start. This has the benefit of allowing work on the wings and nacelles all to be progressed at the same time!
Fuselage would be easy except as this will be electric it will need a battery hatch in the nose.
I want the flexibility to move the lipo between F1 all the way back to under the LE of the C of G even to the point moving the rubber/elevator servos by a bit (deal with that later).
The plan is to make F1 and F2 out of ply and open F3 out to allow the lipo to pass through in either orientation.
Then build the fuselage with the intension to cut the top off F2 to form a hatch from F1 to F3 as I need the length to feed the lipo in and then move it about to achieve C of G
I’ll add a photo of the fuselage shortly once I get back in the workshop.
Edited By Chris Walby on 14/01/2021 07:09:49
On to wing joining and this went without issue, the drawing says dihedral of ½ inch under each tip although I was told that in previous thread discussions it should be an inch under each tip. I went with the drawing and the supplied brace on the basis that it was easier and generally more dihedral make it more stable right way up and less when inverted! Off topic but I have loads of fun with my foamboard Nutball (flying disk) with massive dihedral trying to fly inverted with rudder and elevator only controls! Look at supports for the aileron servos mounting plates (more of that later).
20210111_171215.jpgPS - Nacelles dry fitted as I was still working on the first LE strip, but more on that later.
Had to have a bit of a chuckle as I finished of the last of the motor stand off’s as it was a bit of touch and go with the ali stock (leftover included). Dad would be proud with the lack of waste and no option of making a mistake.
Talking about the nacelles I was having a think about making them removable and added a ply plate against N1 then screwed it from the back. Okay it will be fiddly when all assembled, but at least won’t mean breaking the cowl to remove it.
Nacelles have proved a little more interesting as I was intending on to strap the ESC to the stand offs, but when it came to the cowl construction its was obvious that's not going to work. The ESC's can go where the tank has vacated and that brings me on to the cooling requirements. Perhaps a small chin scoop on the cowl and another scoop where ESC will live. The back of the nacelle underside is sloped and a larger exit scoop should work ok
Balsa glued to get the general shape and I'll add a more for the shape/scoop.
….Order the covering film....
Sort of decision time as the covering arrived after a couple of days in the post.
Peter’s was yellow, but then I thought tigers are orange and then that go me thinking that bight be hard to ss and the stripes won’t show up. Then I thought it could not be any worse than the Extra Slim Twin that is translucent yellow and appears to change orientation depending on the sun shining through the covering and open structure wing.
The votes are open
  1. Traditional yellow
  2. Tiger orange
Along the same theme I contacted one of my fellow club members who has a film cutter and likes a challenge (not sure if that’s me or the decals). Anyway he has come up trumps with these which look spot on to me.
And now back to the build
  • Nacelles trimmed to fit the wings
  • Fuselage battery hatch build (planked, now that’s an interesting technique that needs to be practiced once retired as it’s a bit time consuming
  • Fit snakes
  • Fuselage turtle deck formed (balsa sheet dampened and masking taped to formers, once dry then same again on the other side. When both are dry, cut and glue in place
  • Glue and sand motor cowls
I’ll attach some more photos on the next post.
You are doing a great job.
I know that it is a bit cramped for electric power really.
You have done a really neat job on the planking.
There is just enough to get some experience of planking which is a really useful technique.
Then you can try my Destiny
Only jokingwink
Edited By Peter Miller on 23/01/2021 08:38:00
Hi Peter,
No real issues with the electrics as the motors are small volume compared with IC, no tank so the ESC has loads of space, battery in the fuselage. There are other ways, but George's (4-Max) seems the most elegant although at some point it will light a fire of controversy.
Only real mod is the hatch for the battery as the wires go down the aileron rod hole in the ribs + plenty of room for the servo cables down their paper tube.
The big question will be to leave the Elevator/Rudder as plan or move them back for more flexible location of the battery. My gut feeling is it will need the battery as far forward as possible and if that's the case the servo can go in as plan.
I can't quite see where the nacelles go on the Destiny (only build twins wink) and the planking looks nice. Is it any lighter than rolling sheet or just better and complex curves?
Hi Chris
I agree that George always has the best answer.
I never worked out an electric conversion for Grumpy Tigercub. I think another electric conversion was dione but can't remember it.
I hate to say it but once a model has been and gone I usually don't remember a lot about it. I have even looked at a picture and thought "That is a nice little model!" and then realised that it was one of mine.
With a fully compound curve shape such as Destiny planking is the only way I can think of doing the job but then, back when I started building models planking was the only way to do the job unless you wanted to hollow out vast lumps of balsa. (Jim Walkers Fireball was a classic example of that!!!!)
Peter,
Not sure about sensational but I certainly enjoyed myself messing around with your Grumpy Tigercub . After all my mods I refer to it as the Grumpy Tigercat ! Managed a few outings with it last year despite the lockdowns, really great fun to fly.
Fun watching other folks build logs of the same basic model so I have been following this build , thanks Chris.
Tim
The point of this build thread is so that if a newbie were to decide to build an electric twin (as close to the original design) without resizing or adding bits like flaps or retracts they could with the minimum of off topic departures.
Sorry but its one on by bug bears where a thread heads off topic (some for pages) and it makes the read very disjointed. Tim's runs to 18 pages and while useful it heads in all kinds of IMHO unhelpful directions.
Ron's thread is here **LINK**
Building continues with sheeting the upper and lower wing surfaces, only departure is to a fully sheeted wing. Sue's Ohmen was a bit of a nightmare with the semi sheeted wing and applying the decals with positioning and possible puncher of the covering.
Glued the nacelles in at the same time and the (found in the bits box) pre made LE strip.
Grumpy's mate thinks he will need to go on a diet to fit
Edited By Chris Walby on 24/01/2021 16:52:46
With the top sheeting completed I moved on to adding the aileron hinge blocks, a replacement balsa block where the central aileron servo would go (using servos in the wings) and the TE blocks.
After that it was a case of gluing the nacelles in and sheeting the underside.
Moved on to the nose and laminating the wingtips prior to shaping
Minor clash with the wing bolts to snakes and no issue, will just have to remember if I ever change a wing bolt to cut it down to the right length.
Question for the modellers out there? As its electric it was supplied with a standard and pusher prop, but which goes where? Hope you know your cats before answering? And will it make a difference on the GTC?
