Mathew Spearey Posted January 13, 2021 Share Posted January 13, 2021 Hello, I've recently come across my dads old Precedent HiBoy 2, which was never completed. It's a long shot but wanted to ask if anybody had a copy of the instructions lying around? As far as I can tell, it's possibly just the servos that need attaching and linking up. Would be very grateful for any help. Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted January 13, 2021 Share Posted January 13, 2021 It's possible that someone might have a copy of the instructions available, but if not, the Hiboy is very much a standard trainer model and will follow the basic setup principles for most high wing trainers. I'm sure we can can up with a list of checks that you can use to get going in the absence of the original build manual. Learned to fly power on a Hiboy myself back in the 80s. Quote Link to comment Share on other sites More sharing options...
David Davis Posted January 13, 2021 Share Posted January 13, 2021 Welcome to the forum Mathew. If I may offer a bit of unsolicited advice, if you were to contact your local model aeroplane club someone could help you to finish your Hiboy and help you to fly it too once the current Covid 19 restrictions have been relaxed. You may find the address of your nearest club here: **LINK** Quote Link to comment Share on other sites More sharing options...
kc Posted January 13, 2021 Share Posted January 13, 2021 Welcome to the forum Mathew. Someone may have the HiBoy instructions but if not the excellent instructions from some American kits may also help with servo instalation see this Great Planes trainer instruction book but note the Centre of gravity and control movement will be different on the Hiboy. Note particularly the correct instalation of the rubber grommets on the servos. Much other useful info there too. Put a few photos of your plane servo area here on the forum and ask for advice -no doubt someone will offer advice. We will want to know whether your Hiboy has ailerons ( i.e. 3 or 4 channel ) and whether its a foam wing or built up wing version. Joining a club and being a BMFA member to get insurance are two important things that are desirable. One thing that is mandatory now is registering with the CAA to get an Operator ID before flying. All quite simple though. Edited By kc on 13/01/2021 13:52:39 Quote Link to comment Share on other sites More sharing options...
mike yates Posted January 13, 2021 Share Posted January 13, 2021 Hi Mathew, I have a Hi Boy (aileron ) kit partially built that was donated to me. Have to see if there are instructions included so will get back to you. Mike Quote Link to comment Share on other sites More sharing options...
mike yates Posted January 13, 2021 Share Posted January 13, 2021 Hi Mathew, Have found the instruction manual to the Hi Boy Series II. I'm afraid it gives no information regarding control throws and the CG is "With the tank FULL the model should hang slightly nose down when supported under the wings between 1/4 to 1/3 of the width of the wing (cord) back from the leading edge." Not very helpful advice as I would never balance a model with a full tank? What I can remember when I had one of these kits ( 30yrs ago?) is tank height was a problem?? Also it weighed a lot but could take a fair bit of punishment. The instructions do mention "drawings", but I haven't come across those but the advice and link given by DD is very useful. Mike Quote Link to comment Share on other sites More sharing options...
