S1581 Hawker Nimrod MkI
It is fairly straightforward Geoff, ther is still time to join in you know
The iffy bit on this is that blessed threaded section for the rigging plate. I think the easiest solution is to leave it off until the whole assembly is ready for covering, then let the screw and plate in by removing a small section of rib on one side
Danny
I wouldn't 'push' the Chief, Martian...
... or you might get a full house of board erasers before you realize. surprise
The other reason being that I 'll have to be several weeks late to start. Let's keep the Boss at a steady low pace, it's not a race after all. cool
Chris
You know I am not a fast builder....
Hopefully you can see how the threaded rod and tension plate will fit. The slot is only accesable from the one side. The two small gaps are sealed with some balsa before covering. The whole things has been sanded to profile, quite difficult to keep it symetrical, but slowly does it.
On to the rudder now....
Danny
Okay that's enough for this evening.
I wanted to start with an easy bit that I could bin if I couldn't get back into the groove, but all is well so tomorrow the tailplane and elevators which should be a much greater challenge. There is still a notch to cut in the fin trailing edge for the 1/8 ply stern/fin post R1, but that can wait until the fuselage id under way.
Oh I know a couple of people need to know this, fin 5.6g rudder 7.6g
Danny
Edited By Danny Fenton on 01/10/2018 20:58:21
Hi Martyn, no worries it isn't a race
The hinges are regular Dubro jobs, as per the plan. The way the hinges are done on the full size is difficult to replicate without making the tail surfaces from tubing, which we haven't done. So it is a compromise, I know... page 2 and I am compromising, doesn't bode well does it
Danny
Just in case I am not being very clear, here are a couple of shots of the fin and rudder. If anybody is struggling to follow the plan etc, then please say something
There is no such thing as a stupid question, and i can assure you this is not an easy plan to follow and has taken months to figure out parts of it. So I may make assumptions that are unfair on you guys, so please speak up
Danny
Hi Danny,
Thanks for the additional pics.
This will sound very daft indeed, but if I remember your Chippie thread well, you were giving more details about - for example - the glues you used, the kit parts but also the stock bits that weren't included in the kit, etc.
Now my plans and kit are still wrapped and of course, I do realize that I'm the most novice member of your Classroom, so I might just sit back and wait till I'm less overwhelmed. angel
Also, I can't project myself doing the fin/rudder parts including 'careful' sanding in just one evening, even being a 'long' session. I guess I'll need something like ten sessions for this... ppfff ! blush
The DB plan shows six ribs for the rudder, yours has five. Is this on purpose?
Chris
Hi Chris, you are steeley eyed. One house point to Chris
I had six ribs on one side, but not the other! when I looked at the pic I spotted it and quickly added it before bed
I have used a SLEC stripping tool to use the edges of the sheets of wood that the parts arrive in. If the wood is too heavy then switch to lighter stock by all means.
I fold the plan so that i can work on the relevent section without cutting the plan up, I really hate that, not sure why I rarely use a plan again!
I use the backing from Solartex (doesn't everybody keep the film backing for plan preotecting?) Balsa Cabin also sells plan protector sheets which is very good.
Glues, I have tried all sorts, but being impatient I am using Rocket Hot, which is a thin CA. For larger surfaces I use Titebond wood glue. CA gives a brittle joint so dont flood the area!
Waiting and soaking what you see up is very wise. If we fall into a hole, and do something wrong, you will be able to benefit
Danny
Edited By Danny Fenton on 02/10/2018 16:26:17
Posted by Danny Fenton on 02/10/2018 16:23:58:
Danny
That's why I get a plan copied (in my case at Staples or whatever they're called now) so I feel free to cut it up as required without needing to feel guilty.
Geoff
Edited By Geoff Sleath on 02/10/2018 16:40:40
Posted by Martyn K on 02/10/2018 16:33:17:
On the full size and the model there is a slot in the fin for the rear fin >< tailplane rigging wire. I can see this on the plan. Your heading Nimrod shows a front wire as well. How will this be fastened Danny?
Martyn
You are quite right Martin I hadn't spotted that. Not just the Nimrod, but the Fury as well, plan is missing it. I will have to ponder that. I guess i am going to have to add another in a similar way to the rear one. The fittings are expensive and it will add weight. I might have to see if I can do this another way. Maybe Piano wire as specified on the plan?
Thoughts anybody?
Geoff I have an aversion to cutting a plan up, I know it isn't rational but there you go......
Danny
Okay the sanding is done on the horizontal stabiliser. The key is to focus on getting the doublers around the edge really thin, pay attention to the cut through sections shown on the plan and taper the edges as if it were sheet balsa. Always keep the block skewed around 45 degrees to the ribs or you will catch them and break them off, I know this but still broke one crook once the doublers ats on the perimeter are sized then blend that thickness ont the ribs. Easier done than said but it isn't easy and you need a good eye.
You should end up with something like this:
23.4g
Can you see how much doubler remains at the leading edge? and that distance needs to stay constant all the way around the tips. The trailing edge remains square, not radiused (is that a word?)
Danny
Edited By Danny Fenton on 02/10/2018 22:07:17
Its a replica Martyn
The rear rigging wire is on a thread on the full size. When the pitch trim is applied it lifts the rigging and the tailplane to alter pitch. Wouldnt mind seeing the tailplane mounts on the full size i guess that has a similar screwjack type thread. I can only assume the replica isnt exact, though it sure looks it!
I appreciate that some joining in are not as comfortable with building from a plan as others so I have done a bit of a piccy sequence that may help. Those of you steaming ahead can look away
Here the perimeter is outlined with tha various thicknesses of wood. I used a much lighter wood stock for this as i am trying to save weight. However the edges of the sheets containing the parts is a great source of wood and saves wastage. I use a SLEC Balsa Stripper to cut my strip wood from a sheet of soft 1/4 inch balsa.
You can also see that i do not build over the plan for these bits. I am using thin CA in a pipette and only hold the part flat down when i am gluing. Very little glue is needed otherwise the joint gets swamped and the entire area becomes brittle. (and adds pointless weight. If you are more comfy with aliphatic or pva then pin the part down to keep it flat while the glue dries.
You can see I true one end of the stringers/ribs and then add a few marks to give me the approx size, and angle.
Cut with a razor saw, slightly over size then sand down to size, frequently trial fitting.
I hold the part down while running a fine bead of CA along the join. pressing down gently as it dries, 5 secs typically.
continue attaching all the parts, then flip over and do the other side.
Shaping is done with a medium fine Perma Grit block. I chamfer the edges down to the edge of the 1/16th balsa core at 45 degrees, then alter the angle to gradually include the ribs etc. Then i finisish final shaping by eye. Pay careful attention to the aerodynamic balances at the front of the elevators.
Don't forget to leave cut outs for the glass horns.
The horn is not glued yet, that will happen after the tops have been covered.
As for the joiners i am still musing over that one. I am in favour of a carbon tube with a glass horn J and B welded in place, but the piano wire method will work fine, just heavier.
Danny
