S1581 Hawker Nimrod MkI
47 minutes ago, Ron Gray said:
Others may correct me but if your Rx is using the pad type aerials you can change them for the whisker type (older Rx have a larger connector). I’ve certainly done it on some of my older Rx and not had a problem, range may have changed slightly but still capable of LOS flights.
The RX is new and has two whisker. I will replace the S8 with an R8 with a sat in the tail.
