Danny Fenton Posted December 24, 2021 Author Share Posted December 24, 2021 For those that have real trouble sleeping I have done a video of the journey. Its 30 mins long so have coffee and biscuits ready. Cheers Danny 1 Quote Link to comment Share on other sites More sharing options...
RottenRow Posted December 24, 2021 Share Posted December 24, 2021 Very interesting video Danny. It was notable that on your first attempt to solder the inlet pipe and flexi the solder flowed on the brass but not on the stainless steel, but the second (successful) attempt it appeared to flow on the stainless piece first. I guess it's all down to getting the right amount of heat into both at the same time, and with them being different materials that might have made it more difficult. Your cleaning up of the front edge of the flexi seems to have done the trick though. It was also interesting that the stainless appeared to reach red heat very easily, or was that just an effect caused by the camera? Brian. Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 24, 2021 Author Share Posted December 24, 2021 Hi Brian, thanks for the feedback, I find videos like that interesting, but not to everyone's taste. I think the torch is very hot, I was able to blow a hole in the K&S brass at one point, so with the Stainless being very thin it got very hot very quickly. The early attempt didn't have the flat exposed edge, and I think that was key. Cheers Danny Quote Link to comment Share on other sites More sharing options...
alan p Posted December 24, 2021 Share Posted December 24, 2021 Danny according to google there is a need to wire brush the stainless to remove any oxides prior to brazing. when soldering alum instuctions similar to use ,stainless wire brush and remove oxides prior to soldering Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 24, 2021 Author Share Posted December 24, 2021 38 minutes ago, alan p said: Danny according to google there is a need to wire brush the stainless to remove any oxides prior to brazing. when soldering alum instructions similar to use ,stainless wire brush and remove oxides prior to soldering Thanks Alan, but I went further and filed the top surface. Perhaps abrading the inside of the flexi is what you mean? Anyway achieved my goal for now. Cheers Danny Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 29, 2021 Author Share Posted December 29, 2021 still waiting for brass stock to finish the exhausts, but they are near enough to move on. I have been experimenting with the cockpit interior, on the full size the panels are made of something akin to hardboard, and then they are covered, and wrapped over any exposed framework, with vinyl. I am simulating this with a combination of 1.5mm Vector board with 0.25mm vector board simulating the vinyl. Not much to see yet, I have only done the two rear sides, but I think I am happy the process works. And will continue. For a flying only model this is way too much detail, but I enjoy it so there. The floor is 2mm depron, re-enforced with soft 6mm square rails. Cheers Danny 1 Quote Link to comment Share on other sites More sharing options...
Richard Mallam. Posted December 30, 2021 Share Posted December 30, 2021 Hi Danny, apologies for going off current topic - I am some way behind you. I have a question concerning the flaps which you have made and that I am now trying to recreate. I have made a template to match the airleron riblets (part number 208) for the flaps but am unable to determine from your pics how they do not bind with the webbing (part number 228) unless severely notched, which would weaken the trailing edge? Can you advise - thanks Richard Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 30, 2021 Author Share Posted December 30, 2021 Hi Richard, yes you do have to be quite cunning with getting the clearance, and the diagonals have to be carefully positioned. The flap and the trailing edge are quite thin in section so rigidity could be an issue. The diagonal bracing, though not scale worked well. The ribs are thinned down quite a bit as is that false spar you mention. If I understand you correctly? Cheers Danny Quote Link to comment Share on other sites More sharing options...
Richard Mallam. Posted December 30, 2021 Share Posted December 30, 2021 Thanks very much Danny, yes you understand. Not an easy task, but I guess that's why we do it! Richard Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted December 30, 2021 Author Share Posted December 30, 2021 Indeed can't make it too easy. I have just checked my covered wing and that thin trailing edge has curved a little. Have to clamp it when not flying to keep it straight. Maybe clamp and coat the inside with a thinned coat of resin? Cheers Danny Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted January 1, 2022 Author Share Posted January 1, 2022 Happy New Year to all my scale buddies ? Just to finish off the exhaust section, I silver soldered brass plates to blank off the ends of the pipe, and tapped for a pressure nipple. Cheers Danny 7 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted January 7, 2022 Author Share Posted January 7, 2022 So now that all the excitement off the exhaust is done. I have moved back into the cockpit. I have done all the panelling that covers the interior of the cockpit. This is not scale so I have used a bit of poetic licence. The interior will replicate the bright red vinyl from the full size. Still searching for a subject, though may end up using an imaginary, but plausible scheme. Worked on the front seats today, just shaped blue foam. Steely eyed amongst you will see I have removed 75 percent of the bulkheads in the cockpit, but unfortunately the one behind the front seats is carrying structural loads so cannot go. It was only ever a flying only model to play with a four stroke glow after all. Cheers Danny 3 Quote Link to comment Share on other sites More sharing options...
cymaz Posted January 7, 2022 Share Posted January 7, 2022 Another masterpiece! 1 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted January 7, 2022 Author Share Posted January 7, 2022 Not sure about that LOL but thank you ? Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted January 7, 2022 Share Posted January 7, 2022 Love the seats. 1 Quote Link to comment Share on other sites More sharing options...
alan p Posted January 7, 2022 Share Posted January 7, 2022 No rivet counting on this one then? 1 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted January 7, 2022 Author Share Posted January 7, 2022 10 minutes ago, alan p said: No rivet counting on this one then? I wouldn't go as far as that Alan, you know me cannot resist the odd rivet or two ? 1 1 Quote Link to comment Share on other sites More sharing options...
Basil Posted January 8, 2022 Share Posted January 8, 2022 21 hours ago, Danny Fenton said: So now that all the excitement off the exhaust is done. I have moved back into the cockpit. I have done all the panelling that covers the interior of the cockpit. This is not scale so I have used a bit of poetic licence. The interior will replicate the bright red vinyl from the full size. Still searching for a subject, though may end up using an imaginary, but plausible scheme. Worked on the front seats today, just shaped blue foam. Steely eyed amongst you will see I have removed 75 percent of the bulkheads in the cockpit, but unfortunately the one behind the front seats is carrying structural loads so cannot go. It was only ever a flying only model to play with a four stroke glow after all. Cheers Danny Danny, where did you souce your pilot from. Bas Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted January 8, 2022 Author Share Posted January 8, 2022 Hi Basil, the pilot figure was pointed out to me by a forumite in this thread, back a few pages. He is from Max Grueter and is available as an STL file for €35 you then have to get it printed. Andy Meade has set up a small business printing them at the scale you require. The head is resin printed by a friend, another friend printed the body using normal 3d printing. Okay did a bit more on the cockpit, concentrating on the rear seat today. I have made a video of the process if anybody is interested? Cheers Danny 2 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted January 9, 2022 Share Posted January 9, 2022 Great work as usual Danny, I hope you have a good supply of blue foam as it is a scarce as balsa now. in fact it is now black but out of stock. 1 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted January 10, 2022 Author Share Posted January 10, 2022 (edited) Thanks Eric, I still have a bit left but I sure people would be interested in a suitable substitute to Sheffield Insulations blue foam? I had a play with the back of a front seat, but unlike the back seat which has lumps and ripples standing proud, the front seat had ridges and ripples going inwards, much harder to replicate, still better than smooth surfaces. Hopefully I can make a little more convincing with the airbrush. Video on how the back seat was done. Cheers Danny Edited January 10, 2022 by Danny Fenton 3 Quote Link to comment Share on other sites More sharing options...
stu knowles Posted January 11, 2022 Share Posted January 11, 2022 I like the effect on the seats Danny - and how you got there. Neat and clever. Thanks for the video 1 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted January 11, 2022 Author Share Posted January 11, 2022 Hi Stu, and thanks for the feedback ? Still debating whether to paint or airbrush. The cockpit interior will have to be a brush i think, but the seats themselves could be airbrushed. One guy on RCSB used tissue and thinned pva as a surface finish, tempting.... Cheers Danny Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted January 11, 2022 Author Share Posted January 11, 2022 Been musing over the vinyl beading around the perimeter of the seat cushions, found a simple way to do it. Should look great once painted. Cheers Danny 1 Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted January 12, 2022 Share Posted January 12, 2022 Hi Danny, ... regarding the seats' beading, even if it feels like "a simple way' to you, could you please help the mere mortals with a few bits of explanation? ... Cheers Chris 1 Quote Link to comment Share on other sites More sharing options...
