EarlyBird Posted February 18, 2021 Share Posted February 18, 2021 As my RF-4 build is coming to an end I have started thinking what next. I have downloaded the plan and article from outerzone, @Peter Millerdesigned and recommended it so it must be good. It looks a good candidate for a first plan build. First I will go to the printers and get a couple of plans printed, why else would one go to the printers ? Just a minute I have The Ohmen waiting to start and by the time I can get to the printers we will be flying again. It's good to have plenty to do. 1 Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted February 18, 2021 Share Posted February 18, 2021 I wasn't over enamoured by the look of the Ohmen which our club chose as a mass build project just before Covid struck. As a committee member, I decided to join in but with a scaled down version for a little OS 20FS that was sitting in a drawer waiting patiently for a home (with a little perverse pleasure from reverse engineering an electric design for IC) and I have to say that both mine and the 15 or so produced by builders ranging from first timers to veterans have been a raging success. Almost all of the builds have flown between lock downs and their owners are delighted with them. My little one (40" span) can be a bit feisty but is pure fun whereas a 3S powered standard 48" version could serve as a first low winger with reasonable control movements. With 4S power they are little monsters... Thoroughly recommended... Quote Link to comment Share on other sites More sharing options...
kc Posted February 18, 2021 Share Posted February 18, 2021 The O Four9ier plan and article is on Outerzone and you can print it yourself on an A 4 printer if you open it in Adobe Acrobat Reader DC and print it as a poster, then use sellotape. Select 'cut lines' to and just cut one print and overlap onto the other. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted February 18, 2021 Author Share Posted February 18, 2021 (edited) Thanks KC but I don't have a printer or Sellotape, I ran a paperless office and had no need for either until recently. ? 0-four9ier_oz2312_article.pdf0-four9ier_oz2312.pdf That's clever files added to post. ? Edited February 18, 2021 by EarlyBird More info added Quote Link to comment Share on other sites More sharing options...
Matt Carlton Posted February 18, 2021 Share Posted February 18, 2021 (edited) Ooo embedding files into posts, that's rather fancy. I like that. Edited February 18, 2021 by Matt Carlton Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted February 19, 2021 Author Share Posted February 19, 2021 6 hours ago, Matt Carlton said: Ooo embedding files into posts, that's rather fancy. I like that. And it is easy to do, drag and drop or copy and paste, The same as photos. Quote Link to comment Share on other sites More sharing options...
Matt Carlton Posted February 19, 2021 Share Posted February 19, 2021 Found you can do the same with video files, and YouTube videos will embed by pasting the link into the post. Put a test post in the site tech forum. Works really well. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 1, 2021 Share Posted March 1, 2021 My O-Four9ier is now being covered. I wonder how long a video one can add to a posting?? 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted March 1, 2021 Share Posted March 1, 2021 Directly into a post, 43Mb so not a lot. Use YouTube instead, it’s dead easy in this new forum. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted March 1, 2021 Author Share Posted March 1, 2021 Peter, What is your electric setup to replace the 049 I/C? I assume you asked George ? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 3, 2021 Share Posted March 3, 2021 I am using amotor salavaged frommy Waco Hadrain. A 2321 2050 with a 2o0 ESC and an 1100mah battery. This set up flew my Miss Camomile well so will be just about right for this one. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 3, 2021 Share Posted March 3, 2021 A couple of points to prospective builders. The ribs vary quite a bit, Trim the rear of the ribs off and use 1/4" trailing edge. This also give better adhesion for Mylar hinges, I will post pictures of the motor and cowl conversion. Also the battery bay which is now going through major surgury as it needs a bit of a redesign. I COULD get the battery and plugs in but they needed persuasion with a 2 1/2 hammer.? Eventually the plans will be published but not soon as they will have to wait for another plan that will fit on one side of a plan sheet. The original used comparatively large servos, (Compared to 9 gram ones that we all use today) HEY!!!! They lost the Spell checker!!!! 1 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted March 3, 2021 Author Share Posted March 3, 2021 2 minutes ago, Peter Miller said: HEY!!!! They lost the Spell checker!!!! When you get the squiggly red line right hover over the word and right click, the spellings are at the top of the dialogue box. I hope if not let us know. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 3, 2021 Share Posted March 3, 2021 I will try thet Nope. No sqiggly red line!!?? Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted March 3, 2021 Author Share Posted March 3, 2021 12 minutes ago, Peter Miller said: I will try thet Nope. No sqiggly red line!!?? Can you help with this @Martin Harris - Moderator? Peter what PC and browser are you using, MacBook? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 3, 2021 Share Posted March 3, 2021 Chromebook Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted March 3, 2021 Author Share Posted March 3, 2021 First Right click and a dialogue box pops up Then towards the bottom there is Check Spelling, click the arrow. Then tick Check spelling when entering text. This could be browser dependent I am using W10 Edge Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 3, 2021 Share Posted March 3, 2021 Lets try Again Ah Yes, They have done well.On the old forum you clicked on the Spell check symbol ad all the wrong words where highlighted. This one adds several operations to the simple task. 1 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted March 3, 2021 Author Share Posted March 3, 2021 Good ? Any progress with the email notifications? Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted March 3, 2021 Share Posted March 3, 2021 3 hours ago, EarlyBird said: Can you help with this @Martin Harris - Moderator? Peter what PC and browser are you using, MacBook? I’m afraid I’ve never even seen a Chrome Book. There is probably a setting somewhere to enable spell checking. I’ve tried the Chrome browser on my PC and that highlights a misspelled word with a wiggly line. Are there any Chrome Book users out there that could help Peter? Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted March 3, 2021 Author Share Posted March 3, 2021 Thanks Martin, Peter has sorted the spelling and we are now progressing email alerts. I think! ? Quote Link to comment Share on other sites More sharing options...
Dad_flyer Posted March 3, 2021 Share Posted March 3, 2021 5 hours ago, Peter Miller said: I am using amotor salavaged frommy Waco Hadrain. A 2321 2050 with a 2o0 ESC and an 1100mah battery. This set up flew my Miss Camomile well so will be just about right for this one. I have the 4-Max 2321 2050 as a recommended replacement for 049 in Mayfly. 2s and 8x4 prop. The power is just right, but I am currently replacing it. The X-mount is thin carbon sheet, which has cracked (I crashed too much while learning). As a small motor it has screw spacings which are narrow, and replacement X-mounts are hard to find. It also just looks too small in the model and as a replacement for an 049 and heavy 1960s RC I have had to add lead anyway to get the balance. My replacement choice is 2826 1900 which is a little heavier but at least looks a lot more sturdy. Even with the extra weight there will still be ballast. The parts are more standard across my other models as well. I have not tested which prop to give the power I want on 2s. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 7, 2021 Share Posted March 7, 2021 Well it is ready for test flights 56" span, 336 square inches. 24 ounces. 10 oz per sq ft wing loading Now called the O-Four9ier E 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted March 7, 2021 Share Posted March 7, 2021 That’s nice Peter, I bet it flies as good as it looks! Quote Link to comment Share on other sites More sharing options...
alan p Posted March 7, 2021 Share Posted March 7, 2021 Not stuck for a place to put your CAA reg then? Quote Link to comment Share on other sites More sharing options...
