MZ24 Throttle kill on signal loss Set Up?
Cliff 1959
Reading the MZ24 manual, there is a specific failsafe settings menu where you select what the channel does on failsafe, So for the throttle channel, select this to go to failsafe and then just set the failsafe with the throttle cut active, all the throttle cut does is move the throttle signal to minimum, so if you set failsafe with the throttle cut active then on failsafe the receiver will instruct the throttle channel to go to this position.
9 hours ago, Cliff 1959 said:
Sorted Frank, thanks (club rules).
Thanks Denis Graupner more complex!!
Having reviewed quite a few makes of transmitters, Graupner is no more complex than many others. You just have to know the system.
But it does allow you to determine what you want each channel to do on a failsafe, hold or go to a set position and also how long to wait before going to failsafe.
BTW setting a failsafe is a CAA requirement, and if fitted the throttle must go to minimum on loss of signal, as all 2.4 radios have a failsafe then it is important that it has been set and tested.
