Modern day equivalent for electric power source help please
Andy C
So I am part way through building my DSC Fly Baby and need some help in selecting power source and battery please.  Its quite an old design and information I can find on its plan, build notes box and also the web is that the following were suggested power sources.
.049 to .074 engine
035 cobalt or 05/075 ferrite electric motor such as the DSC 075 Hyperthrust motor
.05 to .075 electric motor with 6 or 7 cells battery
Wing area is shown as 275 sq inches
I have also found on outerzone:
reference to a more recent build using Firepower 450 Sport motor (1100kv) and 1800mAh battery on a 9x4.5 prop but it has not follow up info on whether it actually flew.
And a link to an old RCME article written by the designer Ted Davey which gives more details, weight ready to fly as 34ozs and a wing loading of 16.8oz per square foot and he uses an 8x4 prop.
Many Thanks
Edited by Andy C
  • Andy C changed the title to Modern day equivalent for electric power source help please
I don't know the model, but in one of my models the 049 replacement is a 1900kv Overlander 2826 on 2s with an 8x4. Gives about 70W and a 1000 to 1300 mAh is a long flight.
You want something more than that. The same motor on a 9" prop would take the motor to its limit at 100W ish.
Andy, I converted my "Henry" motor glider design from a Cox 049 to a 400 can brushed motor running on 7 cells nicads driving a 5x3 folder or 6x4 fixed prop. Later that was upgraded to a 57 gm 1022kv BL motor on 3s 2200 (1st generation circa 12c) lipo battery that actually weighed the same as the nicads. This combo drove a 9x5 folder at 9000rpm pulling 11.3A for 115W & transformed the model performance.  Henry.thumb.jpg.b6f837b3efc51bf6a830ab8372d815f6.jpgThis is Henry with the brushed motor.
The BL motor mentioned is no longer available so I was going to suggest a larger more powerful 76g Keda 2217/16 1050kv which I use in my Amigo 2 but that also seems out of production now. However this DYS motor has similar weight & kv so should give similar performance. In the Amigo the Keda turns a 9x5 folder at 10000rpm, 14A for 165W using a 3s lipo. Battery size in the Amigo is from 700 to 1400 mAH (depending on the wind speed) but I only power on for about 25 -30 secs per launch. I suggest that a 3s 1300 - 1500mAH might be adequate capacity for your Fly Baby.
@Andy C - my rationale goes as follows : in the OP suggested power for the design included .049 to .074 engine.
My Henry design initially flew quite well on an .049  & as mentioned the subsequent conversion to brushed electric /nicads gave similar performance using a 5x3 or 6x4 prop. Converting to a 57gm brushless with very low "C" rated lipos driving a 9x5 prop transformed the performance at the same time increasing the duration (over an hour per charge was normal but it is a motor glider).
This BL/lipo combo using a 9" prop was now delivering power at a level similar to a pre schnurle .09 engine driving a 7" prop.
The Keda motor using modern 3s lipos in the Amigo gives about a 40% increase in power using the same 9x5 prop, no doubt due to it's increased dimensions & weight. The DYS motor linked is similar in size, weight & Kv to the Keda therefore I would expect similar power output from it using the same prop & lipos.
As for duration,  I normally reckon for a typical sports model  to use a battery capacity that would give, theoretically at least, about 5 - 6 minutes of full power. From experience I've found this actually allows a much longer flight time without depleting the battery overmuch.
Edited by PatMc
