Chad Veich Yak-11 Build
Hi I’ve had the plans and laser cut kit for the Yak for a while now gluing a bit now and again between house moves etc. So thought I would share my progress so far now that I have more room to build it.
The plans were drawn by Chad Veich, They are part of the Bates plans range and I got my copies through Fighteraces and the laser cut kit was from Belair Kit cutters here in the UK.
The model spans 82” and I have a Zenoah 45 which will easily fit in the 11” Diameter cowl. I will be using Robart 631 RS air retracts and 673 Robostruts.
Vince
  • Like 3
Some more progress with the wing. The retract bearers are epoxied in after checking they sit correct in both positions. The flaps are finished and the aileron cores are started. The plans show enclosed flap servos but I will make them accessible the same as the aileron ones before final sanding and running servo leads and airlines for the retracts before final sheeting.
Vince
Edited by Vince Findlay
I forgot to put in final sheeting
  • Like 3
The first wing panel is now sheeted, This is done on a saddle supplied in the kit to keep it true and set the washout etc. I used sandbags to weigh it down while everything dried. The airline and servo leads were also run and taped in first.
I also tried a servo tester for the 1st time while checking the flap servo...I wish I had this piece of kit years ago to save using the receiver etc. Got this one from the Steve Webb models for a tenner.
Next to set up the wing jig and get the second wing to the same stage, Laminate the leading edges and fit and sand the wing tips ?
  • 1 month later...
Both wings are now sheeted with the wing tips and laminated leading edges fitted and sanded. The tail plane and fin are sheeted and the rudder and elevator cores were made up over the plans. I’ve put these to one side just now and will join the wing panels later.
I’ve started the fuselage by making up the rear trusses and looking out the the formers.
Cheers Vince
Thanks, I have seen the Chez Mate and Perastroika racing versions of Chad’s design on Rcu and they look great, I think the builders just modified the existing plans? I remember seeing a 66” span one as well, but I’m not sure if the plans are available. I will be building the two seater version as per plan. I will have a go at making a plug and vac forming my own canopy later, it’s quite long so I will probably do it in sections.
23 hours ago, perttime said:
At least, he has made a plan for a 66" span Check Mate / Perestroika.
Perttime, I had another look at the 66” air racing Yak and I bet it would be great with a 120 four stroke, Definitely going to see my one through to completion before I think of my next project…it’s so easy to get side tracked with this great hobby ?
Some more progress on the fuselage. The tail wheel brackets, side formers and stringers are fitted. Just temporarily pinned in the the top formers to get an idea of the shape of things to come ?
I’ll be working on the front bulkhead area ducting next. Then join and glass the wing panels so I can finish the wing seating, dowel locations and wing fixing bolts.
