Doylie Posted April 14, 2021 Share Posted April 14, 2021 Hi, I was after a little help please? I've finished covering a Tiger Moth in silver Oratex and want to paint part of it with humbrol enamel (the yellow stripes) and was wondering if it needs thinning and are there any other things i need to be aware of ? Its a long time since i've built a model and it looks quite nice , i don't want to spoil it!. Any advice would be much appreciated. Quote Link to comment Share on other sites More sharing options...
PeterF Posted April 14, 2021 Share Posted April 14, 2021 I have used Humbrol enamel a couple of times brushed on and never thinned it. I suggest you test it on a scrap of the Oratex first to make sure that there is no reaction between the two. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 14, 2021 Share Posted April 14, 2021 Agree, cover a bit of scrap and try it, may need a little thinning but a test will tell for sure. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 14, 2021 Share Posted April 14, 2021 All the humbrol paint that comes with Airfix now is waterbased, so no probs at all. D.D. Quote Link to comment Share on other sites More sharing options...
Geoff S Posted April 14, 2021 Share Posted April 14, 2021 How is the water-based Humbrol identified? Most of mine is quite old and in those tiny tins but a local dept store (Boyes in Ripley, Derbys) usually has a good stock which has probably been there for some time so perhaps not water-based. I usually thin mine and clean brushes with white spirit but I prefer water-based paint because of the easy clean up. I use quite a lot of Valspar for example. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 14, 2021 Share Posted April 14, 2021 Comes in plastic containers Geoff. D.D. 1 Quote Link to comment Share on other sites More sharing options...
Geoff S Posted April 14, 2021 Share Posted April 14, 2021 Thanks, Dwain. Should be easy to spot, then. All the Humbrol I've ever seen has been in tins, usually those ridiculously small ones. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 14, 2021 Share Posted April 14, 2021 They go an amazingly long way tho, don't they. D.D. Quote Link to comment Share on other sites More sharing options...
PeterF Posted April 14, 2021 Share Posted April 14, 2021 When I painted the Mossie in my avatar picture (for scale, that is an 82" span) I bought the colours from a Boyes store, all the old solvent based enamels in tins, light grey, PRU blue and sand, I think it was about 18 tins in all from memory , I had rather an odd look at the till. The tins had been there for a while and had separated into an almost solid plug of pigment and the solvent / oil. I emptied the tins into glass mixing jars and got it all mixed up and it went on a treat. All matt colours and then a coat of Poly-C gave it a nice semi matt finish. 1 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 14, 2021 Share Posted April 14, 2021 That's a cracking finish Peter. Here is a pic of the water based Humbrol "tub". I noticed that the Revell tins I have are water based too. The Humbrol tins are oil based. D.D. My Stash, some of these are over 10 years old 1 Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 15, 2021 Share Posted April 15, 2021 If you have proper smelly Humbrol Enamel Doylie, As the lads say, test it. If you have to thin it, do not go more than 10% as good properties are lost. For spraying, I thin about 5%, to be milk consistency. Non water based still works well with white spirit. Even with water based paint, don't go overboard thinning, as properties of paint are lost. And don't paint in this cold weather. You need to above 5°C, 10°C is better, but ideally paint on or above 15°C air temperature 1 Quote Link to comment Share on other sites More sharing options...
Doylie Posted April 22, 2021 Author Share Posted April 22, 2021 Thanks for all the answers, ive tried a bit on a scrap piece covered in Oratex and it works fine. Getting a nice clean edge, now that's another matter!!! (only joking, masking tape is fine, not perfect, but as they say good enough for a blind man on a galloping horse! Thanks Quote Link to comment Share on other sites More sharing options...
Dave Garrett 1 Posted April 22, 2021 Share Posted April 22, 2021 Thanks lads, I am about to encounter exactly the same issue with my DB Sports & Scale Tiger moth? Quote Link to comment Share on other sites More sharing options...
