Tim Kearsley Posted April 19, 2021 Share Posted April 19, 2021 Due entirely to pilot error, my 3.7m Super Ava Pro sailplane had an argument with a small fence post on landing. This has resulted in a small dent in the leading edge of the centre wing section, between two ribs (see photo). I believe this is a carbon/Kevlar weave. Any idea how to go about repairing it? Thank you. Quote Link to comment Share on other sites More sharing options...
Wookman Posted April 20, 2021 Share Posted April 20, 2021 Pull it back into shape with a pin or sharp scalpel then soak the area in runny superglue. Don't put too much on as will go everywhere. Put a bit on and let it dry then put a bit more on and let that dry. Carry on like this until you have enough thickness to gently sand back to shape and polish up. Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted April 20, 2021 Author Share Posted April 20, 2021 Thanks Wookman, I'd pretty much come to the same conclusion. Thankfully, there appears no damage at all to any ribs, just the "dent" in the carbon/Kevlar skin. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 20, 2021 Share Posted April 20, 2021 I’ve done the same thing on my DLG, the LE has had a couple of dings, all because of me misjudging ‘return to hand’ once when it hit my shin (ouch) and recently when it hit the TX (broke a switch lever). Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted April 20, 2021 Author Share Posted April 20, 2021 Sounds painful Ron! It's a testament to the strength of the Super Ava wing that the post that it hit, which admittedly was only well "weathered" 2 x 2, broke off at the base! Quote Link to comment Share on other sites More sharing options...
FilmBuff Posted April 21, 2021 Share Posted April 21, 2021 My Pulsar had a serious arrival that broke the D box and the spar. I found this Vladimir Model repair kit from Hyperflight invaluable. https://www.hyperflight.co.uk/products.asp?code=VM-COMP-REPAIR-KIT&name=vm-composite-model-repair-kit Best £37 I have ever spent. Enabled a £900 glider to get flying again. Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted April 21, 2021 Author Share Posted April 21, 2021 4 hours ago, FilmBuff said: My Pulsar had a serious arrival that broke the D box and the spar. I found this Vladimir Model repair kit from Hyperflight invaluable. https://www.hyperflight.co.uk/products.asp?code=VM-COMP-REPAIR-KIT&name=vm-composite-model-repair-kit Best £37 I have ever spent. Enabled a £900 glider to get flying again. Thank you for that. I didn't know they sold it! Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted April 21, 2021 Author Share Posted April 21, 2021 Just ordered the last one they had in stock! Many thanks Filmbuff for the tip. 1 Quote Link to comment Share on other sites More sharing options...
FilmBuff Posted August 16, 2021 Share Posted August 16, 2021 On 21/04/2021 at 15:22, Tim Kearsley said: Just ordered the last one they had in stock! Many thanks Filmbuff for the tip. How did you get on? Quote Link to comment Share on other sites More sharing options...
Tim Kearsley Posted August 16, 2021 Author Share Posted August 16, 2021 2 hours ago, FilmBuff said: How did you get on? Very well! The repair is at least as strong, probably stronger, than the original and its barely noticeable. The repair kit was well worth the money. 1 Quote Link to comment Share on other sites More sharing options...
