GARY BLANDFORD-HULL Posted May 11, 2021 Share Posted May 11, 2021 Hi, looking for some info on the best adhesive to use for gluing XPS foam to Balsa Wood? Looking for something that dries clear, is reasonably quick setting, and does not eat into the foam. PVA is OK I know but the drying time is to long for me. Glad to receive some suggestions/comments. Thanks. Gary Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted May 11, 2021 Share Posted May 11, 2021 One type of glue would be amazing Gary On balsa foam composites, I use 3 or 4 different glues, including epoxy Based on strip joining, sheet laminating, stressed areas, and unstressed panels Joints can help too to key in dissimilar materials, and slow curing glue is often twice as strong as quick fix glue. Super glue will suit your requirements, but be sure it is foam safe, and wear a mask in a ventilated area, preferably outdoors. Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted May 11, 2021 Share Posted May 11, 2021 For glueing a balsa LE to a foam wing I use 30min Epoxy. I just wrap masking tape around the LE to hold it in place until cured. I then razor plane/sand the balsa to the final LE profile. I have also used gorilla glue for glueing in ply dihedral braces into foam, just don't use too much Gorilla glue as it foams up and is difficult to sand when cured. Cyno works OK with foam too depending on the foam but foam safe should be OK. I sometimes use it for glueing carbon rods into foam for reinforcement. I usually use a kicker too but fingers sometimes seem to get stuck to the foam! 1 Quote Link to comment Share on other sites More sharing options...
Mike Chantler Posted May 11, 2021 Share Posted May 11, 2021 What Piers says. In the past have used 30min epoxy. But recently have started using Lumberjack 5 and 30min liquid PU. I find it easier to spread and cut than GG. And I find PU easier to sand/cut through than epoxy. I think either will do fine. Stick masking tape on the surfaces you don't want glue on(!) prior to applying glue ? Quote Link to comment Share on other sites More sharing options...
