3d printed 1/6 scale ww1 wheels
mightypeesh
Hi Gents. I have just taken over a partially built Flair Legionnaire kit which has the main wing and fuselage structures built to a lovely standard. The box included a set of Flair vintage wheels which i have never quite liked the look of - good for an SE5 but not sure on a Nieuport.... I have started tinkering with Fusion 360 CAD software and have access to 3d printers at work so thought I would have a go at designing my own to see if I can do a job more to my liking!
I find Fusion a very user friendly bit of software (once you have pulled your hair out getting the basics right) and quickly had a file suitable for what I wanted which I printed out in PLA. I designed them for a tyre made from 16mm neoprene cord and to have a 5mm brass tube bush in the centre given an shaft size of 4mm. If Anybody is interested in the files along with a tool for cutting the neoprene accurately and aligning the ends for gluing I have put them onto Thingiverse here for you to use.
.286522904_thumbnail(4).jpg.53e2b48c1d5698bec2f7c785c3c2afd4.jpg          399595731_thumbnail(6).jpg.5f27f88af79bf58fa2b30fd49f8cdeff.jpg
Kit of parts ready to go!
I wanted to add some spoke detailing to the wheels where the hole is using wire and added a air valve using a bit of carbon rod. The trusty Dremel soon had the wire in place. I also wanted to cover the wheels in fabric for a softer more scale look. I found the best covering came from an old cotton pillow case which I used Easy Dope on to stick it down. I will let the pictures do the talking....
1806537850_thumbnail(7).jpg.cf26da697d0c9b2ca2507b64e1367a3a.jpg    831821878_thumbnail(8).jpg.08658b5bf8e7bbc9604b4dbc7f4c94a5.jpg    5352216_thumbnail(1).jpg.d56f3571ec5e56dfdab38efd6e4ef45a.jpg
1332585177_thumbnail(2).jpg.4a59abc12f8d4e5eb2792a95394e6c0b.jpg    606339856_thumbnail(11).jpg.fcb310c28d709f88c4a0f02503300a8d.jpg     397412935_thumbnail(12).jpg.a27285927fa6c0426085e767675a2b39.jpg
  641105938_thumbnail(3).jpg.9987dc2158010bc9215995c206c0c083.jpg     1540963209_thumbnail(14).jpg.51fff064d9a3662df3819ef72c07166d.jpg     1871889388_thumbnail(15).jpg.144f08135f948f064a738f8981b287fa.jpg
All epoxied together, using the brass bush to centralise each half. Don't forget to paint inside the wheels where it can be seen as it will be jolly difficult once joined.
The next bit is the tyres. The 16mm neoprene is from fleabay for just under a fiver for a meter. This will give you enough for three tyres which means you can mess one out of three up!
I have also put the tool for cutting the cord square and aligning the ends accurately for gluing on the Thingiverse page for you. I cut the neoprene to 285mm initially, but trimmed it a tiny bit so that the tyre is a nice snug fit on the rim. I will glue the tyre on once the wheels are painted, probably with epoxy. I found the best glue for the ends is good old Evostick. I applied two even thin layers to each end allowing to dry between the first and second application, then touch dry on the second before bringing them together in the jig and taping together with masking tape so there was slight pressure on the ends. Leave overnight for a good strong bond, then repeat.
1281934955_thumbnail(16).jpg.bb04fca4a4adf47834c83431c4741ad9.jpg   IMG_3816.JPG.b7a8d10070ecdcef28fd0ba99db65adb.JPG     IMG_3817.JPG.8f946f5bd415f153b13c4d887929c855.JPG
thumbnail.jpg.76a05aa6f0bdd7059aa57e52f457402b.jpg      62912933_thumbnail(18).jpg.5f27868f74759bf70b3b17a7d37f5fc1.jpg
That's it really, I am pleased with the result of my first foray into CAD modelling and 3d printing. The wheels are 4 1/4" in diameter (110mm) and weigh just under 50 grams each before paint. I think will look great on the Nieuport, the build of which I will post here when some more goodies turn up in the post. the last pic is of them next to the Flair vintage wheels as a comparison.
IMG_3789.JPG.e0ba1965c1bbb735b7ca67a27b7032f8.JPG    608795500_thumbnail(17).jpg.1491d8b04fbde780e3af6005d51a73ed.jpg    1311201797_thumbnail(19).jpg.1787ed2aba5e9ebd632f51d056765de4.jpg
All ready for paint. Hope you like them, Cheers, Simon.
  • Like 4
