Rich Griff Posted June 30, 2021 Share Posted June 30, 2021 I have a Futaba t4vf skysport4 tx, please would someone help in so much that will this tx work a Futaba fp-r115f 5 channel Rx please. Help greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted June 30, 2021 Share Posted June 30, 2021 Those are a match in the manual Rich Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted June 30, 2021 Share Posted June 30, 2021 If it's all 35mhz then as long as you have the correct crystals installed then yes, basically on 35 mhz it is only when you go PCM or over 9 channels that you get incompatibilities. Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted June 30, 2021 Author Share Posted June 30, 2021 Thanks, crystal 66 in each unit. Tx carrier wave spot on but no ripples or movement seen on scope. Rx aerial lead ok to board and servos move when battery connected, but system does not work, stick movement, no servo movement. Servos work on an other set. I would have thought that something would have been visible on a scope from tx and stick movement ? I was told the set did work, it was in an RC car, naughty boy ! It owes me nothing so I will have a look-see in the back of the tx for power supply/bad connection... Would be nice if it worked... Would this tx drive a dual conversion Rx ? Yes it 35meg. I presume a challenger driving a dual convertion Rx would not drive this Rx 115f ? Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted June 30, 2021 Author Share Posted June 30, 2021 Dennis, you have a manual ? Any test procedures, wiring schematics, scope traces or anything like that ? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted June 30, 2021 Share Posted June 30, 2021 25 minutes ago, Rich Griff said: Dennis, you have a manual ? Any test procedures, wiring schematics, scope traces or anything like that ? Manual online In manualslib Google it Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted June 30, 2021 Share Posted June 30, 2021 58 minutes ago, Rich Griff said: Would this tx drive a dual conversion Rx ? Yes providing the crystal in the Rx is for a dual conversion Rx. Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted July 1, 2021 Author Share Posted July 1, 2021 Thanks for the replies guys. Thanks for the he heads up about manualslib, a great resource but some more investigation needed a think. Not given up on this skysport4 4 combo set yet. Will use scope on the challenger tx to see if any "movement" is seen when twideling the sticks on that. I would have thought some movement or difference in tx signal when sticks moved. We shall see in due course. The lad said the skysport4 used to work, so there is some hope... Anyway running up paw 19 again today. Quote Link to comment Share on other sites More sharing options...
