2.4g Shaun Posted July 14, 2021 Share Posted July 14, 2021 (edited) Hi, To date I've used Hitec 645mg servos in my larger models (1/3 scale Cub, WW1 Morane etc. ) and had no problems. Chatting with fellow modellers it also appears Savox have many fans so what would be the equivalent as I'd like to give them a go in my latest project. I'm not over enamoured by continually buzzing digital servos in this type of model (but open to to trying them). High voltage versions would be beneficial as my standard Rx battery packs are 2 x Li-Ion cells. Over to you Savox fans Edited July 14, 2021 by 2.4g Shaun Typo Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted July 15, 2021 Share Posted July 15, 2021 I have been a fan of both for some time now, HT 5485 digi carbonite are excellent but so are the Savox ones in the same price range, both metal and plastic geared depending on the expected stress. Not much in it really. Quote Link to comment Share on other sites More sharing options...
MattyB Posted July 15, 2021 Share Posted July 15, 2021 I no longer use the cheap, smaller Hitecs (HS45s, 81s etc) as the quality seems to have dropped off since lower priced competition from HK etc came along. I only use their ball raced servos now, but at the size and price point you are talking about they should still be fine. I have Savox too, but tbh there's nothing between them for me - choose whichever you can find/get a good deal on that have similar performance specs. Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted July 16, 2021 Share Posted July 16, 2021 (edited) All other things being equal, I'd probably go for Savox rather than Hitec for one simple reason. They have an odd number of splines (25), which allows fine adjustment of servo arm positions by rotating them through (nearly but not quite) 180 degrees. Most Hitecs have an even number (24), which I've always thought spoils an otherwise excellent range of servos. Edited July 16, 2021 by Gary Manuel Quote Link to comment Share on other sites More sharing options...
