Skippers Walker Posted August 28, 2021 Share Posted August 28, 2021 Please can anyone suggest an inexpensive set of kneedle nose circlip pliers to use for this task? It's very difficult to determine from the various tools advertised the actual tip size. I already have internal and external circlip tools but they are far too 'industrial' for the very small clips on brushless motors. SW Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted August 28, 2021 Share Posted August 28, 2021 When faced with a similar problem in the past. I got around it by buying a cheap set of suitable pliers from Poundland and ground/ filed the nose to shape that I needed. One tool for one job, cost a quid. 1 Quote Link to comment Share on other sites More sharing options...
Capt Kremen Posted August 28, 2021 Share Posted August 28, 2021 Another, (cheap?), way I noted on a YouTube contributor dismantling a motor. Take some strong but thin twine. (Some types dental floss may be strong enough). Loop one length around one side of the circlip another length of twine on the opposite side and PULL/Stretch the 'arms' of the circlip apart. Yes, it is a bit of a three handed task but with luck you can part the circlip sufficient to slip it over the retaining grove. Assuming you don't loose the circlip in the process, it is still ideal to replace with a new unstretched one. 1 Quote Link to comment Share on other sites More sharing options...
John Lee Posted August 28, 2021 Share Posted August 28, 2021 Plenty of suggestions (including my own!) in this thread 1 Quote Link to comment Share on other sites More sharing options...
Skippers Walker Posted August 29, 2021 Author Share Posted August 29, 2021 Thanks for the helpful comments. RS Components look like a possible source of quality pliers. I guess that the actual motor manufacturers must have access to the correct kit. Kind regards SW Quote Link to comment Share on other sites More sharing options...
