James Middleton Posted August 29, 2021 Share Posted August 29, 2021 I use a(n) FrSky DJT module and a D8R-11 Rx. Is it "safe" to continue running with the (original) 35MHz Tx-antenna attached to the Tx? I prefer the..."feel/balance" of the Tx with the long aerial in-place! (I don't use a cradle). Are there any (technical) reasons why this might be,..."risky"? Just wondering,...any comments? James Quote Link to comment Share on other sites More sharing options...
Martin Dance 1 Posted August 29, 2021 Share Posted August 29, 2021 I don't think there is any reason why the extended Tx antenna would cause problems with the 2.4Ghz signal. A more likely problem if you fly on a club site will be people moaning about the lack of a frequency pennant o lack of peg on the peg board? 1 Quote Link to comment Share on other sites More sharing options...
Alan Hilton Posted August 29, 2021 Share Posted August 29, 2021 If the frsky 2.4 module is in place no 35 meg rf will be transmitted so no problem Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted August 30, 2021 Share Posted August 30, 2021 I fitted the strap doodah to mine for the same reason, more holes on one, so you can balance better. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted August 30, 2021 Share Posted August 30, 2021 just make sure that other fliers are aware, or you may poke their eye out.............................. 1 Quote Link to comment Share on other sites More sharing options...
Wookman Posted September 2, 2021 Share Posted September 2, 2021 I use a 9X2 with a FrSky module with the 35Mhz aerial extended. Never been a problem. Quote Link to comment Share on other sites More sharing options...
