Gary Clark 1 Posted January 5, 2022 Share Posted January 5, 2022 Really enjoying your build Earlybird. I was recommended the Rhapsody by Peter at the start of the year after building the Ballerina (which I loved) but then went away with work for the past 8 months so only just getting sorted again. I got a plan enlarged to make it 70" as well since I think it would look even better and really grab attention at that size, especially with its elliptical wing. Definitely high up my to-do list so thanks for starting a thread. I had noticed when i looked before that there were very few example out there Gary 1 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 6, 2022 Author Share Posted January 6, 2022 Thanks Gary, Destiny is on my list and my thoughts are to enlarge to say 70" for the same reasons. It will also be my first plan build, if I can use my Saito FG21 that would make it my first non electric build. That's next years winter build challenge.? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 6, 2022 Share Posted January 6, 2022 I did see one for sale on Ebay many years ago.It was quite local and I was tempted to buy it but didn't as I still have mine. A 70" span version would be spectacular. I suspect that many people do not believe that a high wing model can be just as aerobatic as a low wing one. They want to see my Peggy Sue and Peggy Sue 2 in action. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 6, 2022 Author Share Posted January 6, 2022 Having seen Peggy Sue 'in action' yes it's amazingly aerobatic. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted January 6, 2022 Share Posted January 6, 2022 I can also vouch for how nimble Peggy Sue 2 is, B schedule no problem! However, for a truly spectacular sight the Sig Rascal (mine’s the 110” version) takes some beating. I converted mine to 10s power and it is fully aerobatic but does everything with so much grace! Quote Link to comment Share on other sites More sharing options...
Graham Davies 3 Posted January 6, 2022 Share Posted January 6, 2022 3 hours ago, Peter Miller said: I suspect that many people do not believe that a high wing model can be just as aerobatic as a low wing one. They want to see my Peggy Sue and Peggy Sue 2 in action. I can vouch for that. The flick roll rate on Peggy Sue is rather alarming, to say the least... As was landing it with the flight battery hanging out after I'd flick-rolled it free from it's mount! She's a gentle lady until provoked. Much like Mrs D.... 1 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 7, 2022 Author Share Posted January 7, 2022 I created a template of the apple cheek by tracing off the plan. and spent a day working out how to make it. Decided to make it in two parts with the join at the cowl, the vertical line above. Cut and glued some wood this morning and glued them together to give this and fitted. some shaping required but next drill the ventilation holes through the ply sides, how many and what size? More in a couple of days, as I need time to think ? Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 8, 2022 Author Share Posted January 8, 2022 Enough thinking so started drilling vents. then realised the shape would be close to the join so added triangles made from scrap. then roughly shaped and dry fit as some adjustments may be needed. Planking ? Two bits well it's a start. A good day as all went well after the couple of holes in a bad position. They are covered so no problem, even at two feet. ? 1 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 9, 2022 Author Share Posted January 9, 2022 All morning adjusting the fit of the cheek as I thought it stuck out too much. Then finished the planking on the side. a bit of rough sanding as I went along just to make sure nothing was wrong. Turned out surprisingly well, ? Turn round and repeat. Getting cheeky? ? 1 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 16, 2022 Author Share Posted January 16, 2022 Second side done. The bottom planking next. ? 2 Quote Link to comment Share on other sites More sharing options...
Geoff S Posted January 17, 2022 Share Posted January 17, 2022 Nice job with the planking. It can be quite time consuming but ultimately satisfying. I had to plank the bow and stern of my Thames sailing barge hull. Then decked with a sheet of light ply with score lines for the deck planks I really must finish it some time but there's nowhere local to sail it. I bought the complete kit from Traplet with the CNC parts, 4 huge sheets of drawings and a DVD. As it turned out the hull formers were wrong and I had to bodge it to get the chine straight. The reimbursed me for the whole amount so it's just cost me the 3mm balsa for the sheeting. Sorry for the none aero modelling comment but sailing is really just 2D flying ? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 17, 2022 Share Posted January 17, 2022 Nice job. Surely there must be a pond or lake in your area where you could test it? My Higgins 78 foot PT boat at speed. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 17, 2022 Author Share Posted January 17, 2022 1 hour ago, Peter Miller said: My Higgins 78 foot PT boat at speed. Where do you store a 78 ft boat? Interestingly when the planking started taking shape I did think I could be building a boat. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 21, 2022 Author Share Posted January 21, 2022 Planking has got to the point where I need to install the ESC. I have set it up with the programming card and tested the motor for rotation. Next seal it in with the remaining planking. ? Quote Link to comment Share on other sites More sharing options...
Geoff S Posted January 21, 2022 Share Posted January 21, 2022 Are you implying that the ESC will be built into the model and be inaccessible? That would worry me. ESCs are highly electrically stressed (or can be) and I have had them fail in the past. Not seriously (just one of the 3 motor outputs) but it had to be replaced. Obviously, direction of rotation won't be a problem as you'll still be able to get at the motor connections but I'd be very wary of building in the ESC. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 21, 2022 Share Posted January 21, 2022 True If you can't get at something...you will need to. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 22, 2022 Author Share Posted January 22, 2022 20 hours ago, Peter Miller said: True If you can't get at something...you will need to. My thoughts exactly Peter. Geoff it would worry me also. I have installed the ESC at this stage as it is easier to do than later. The F1 vent slot is large enough for the ESC to pass through, I made sure it was. The tricky bit will be threading the various wires through the holes in the formers and battery tray. My thoughts are to add draw strings when removing the ESC. That's plan A plan B is to cut an access slot in the liteply battery tray, I could have built it that way but didn't because of poor planning. Now this is all very optimistic, expecting the model to last longer than the ESC. ? I have not had a problem so far removing the ESC from the pile of debris. With practice my models are lasting longer so building for longevity and easy maintenance is a good idea. ? Thanks 1 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 23, 2022 Author Share Posted January 23, 2022 More planking. Middle two first which are easy. Then working outwards, these need to be tapered towards the front not so easy as they have to be individually cut and adjusted to fit. More fun to come. ? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 23, 2022 Share Posted January 23, 2022 Oh yes! Tapered AND chamfered ! Wait until you build Destiny!!!! Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 25, 2022 Author Share Posted January 25, 2022 Chamfers are the key to a good fit. Only one left. ? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 25, 2022 Share Posted January 25, 2022 Looking very good Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 27, 2022 Author Share Posted January 27, 2022 and even better now the planking is finished. Not bad for a first attempt even though the stripes aren't even ? Still good practice for Destiny. For me every build is practice for the next one. 1 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 27, 2022 Share Posted January 27, 2022 Looking very good 1 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 29, 2022 Author Share Posted January 29, 2022 The fuselage is now at the stage where I can fit the wings. and then finish the wings ? 3 Quote Link to comment Share on other sites More sharing options...
Jonathan M Posted January 29, 2022 Share Posted January 29, 2022 That's beginning to look nicely rhapsodic! ? Quote Link to comment Share on other sites More sharing options...
