edwards flyboy Posted December 9, 2021 Share Posted December 9, 2021 I'm having g difficulty running the throttle wire from an OS 70 Surpass to the servo in a wots wot,due to the carb being so central on the.the engine,any help would be appreciated Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted December 9, 2021 Share Posted December 9, 2021 Use a 15 - 20mm M3 spaced nut, and 25 mm M3 hex cap head bolt underneath your throttle arm at th carb. This pushes the throttle movement away from centre. One of mine has a 30mm spacer, you choose. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted December 9, 2021 Share Posted December 9, 2021 Remove the carb. Turn it 180 degrees. Reattach. Throttle should be rather less central. At least that worked for my mk1 os70. Later version may be slightly different. Quote Link to comment Share on other sites More sharing options...
Jon H Posted December 9, 2021 Share Posted December 9, 2021 Is the engine side mounted? Some photos and extra detail might help Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted December 10, 2021 Share Posted December 10, 2021 My Thunder Tiger 75 FS is installed side mounted on my Wots Wot, I'll have to check the throttle routing. But this pic (not mine) shows a throttle linkage to an OS 70 Surpass that may work on your Wots Wot, it's something I've done on several models. 1 Quote Link to comment Share on other sites More sharing options...
edwards flyboy Posted December 10, 2021 Author Share Posted December 10, 2021 6 hours ago, Frank Skilbeck said: My Thunder Tiger 75 FS is installed side mounted on my Wots Wot, I'll have to check the throttle routing. But this pic (not mine) shows a throttle linkage to an OS 70 Surpass that may work on your Wots Wot, it's something I've done on several models. Quote Link to comment Share on other sites More sharing options...
edwards flyboy Posted December 10, 2021 Author Share Posted December 10, 2021 Thanks for that Frank,it's a Mark 1 Surpass,the throttle barrel is above the carbon,but that solution will help, providing that it does not interfere with the tank Quote Link to comment Share on other sites More sharing options...
edwards flyboy Posted December 10, 2021 Author Share Posted December 10, 2021 Qall good now ,thanks for your pics Frank 1 Quote Link to comment Share on other sites More sharing options...
CARPERFECT Posted January 13, 2022 Share Posted January 13, 2022 On 09/12/2021 at 19:56, edwards flyboy said: I'm having g difficulty running the throttle wire from an OS 70 Surpass to the servo in a wots wot,due to the carb being so central on the.the engine,any help would be appreciated Have you got the engine inverted or at 90 degrees Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted January 13, 2022 Share Posted January 13, 2022 Was there a specific reason not to turn the plastic throttle lever 180° ?. Quote Link to comment Share on other sites More sharing options...
flight1 Posted January 13, 2022 Share Posted January 13, 2022 2 hours ago, Paul De Tourtoulon said: Was there a specific reason not to turn the plastic throttle lever 180° ?. Come on life not that simple? Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted January 14, 2022 Share Posted January 14, 2022 (edited) The way I solved the problem of running a throttle snake to the awkwardly placed central carb arm on many fourstrokes for years now is to fix a 25mm M2 machine screw to the throttle arm (secured with a lock nut) and then use a standard heli ball link on the plain threaded extended end, again secured with washers and nuts on either side. Reliable and works a treat. Edited January 14, 2022 by Cuban8 Quote Link to comment Share on other sites More sharing options...
