John Botomley Posted December 15, 2021 Share Posted December 15, 2021 I purchased a lightly used Ripmax Wot's Wot foam-and I cannot get the ESC to work. My initial radio set up was a Futaba 8FG + R606FS FASST Rx - nothing - no beeps - just a low frequency "ticking" Next up was a new R617 FASST Rx - nothing - just a low frequency "ticking" I've tried calibrating the throttle channel, reversing the throttle channel (sometimes needed with Futaba) - nothing - just a low frequency "ticking" Next up was a Turnigy ESC with the R606FS Rx - nothing Next up I changed radio to a Spektrum Dx6i + AR 6200 Rx using DSM2 - everything worked fine with the Turnigy ESC, but nothing with the original Ripmax one - except a higher frequency ticking? I know the battery is fine, as is the motor. The BEC side of the Ripmax ESC works too Is it just a knackered ESC?? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted December 15, 2021 Share Posted December 15, 2021 Ticking is often when one of the motor wires is not in circuit, not making contact. Test connectors and soldering all between motor and ESC Quote Link to comment Share on other sites More sharing options...
