Tony Harrison 2 Posted December 18, 2021 Share Posted December 18, 2021 I just bought one of these but I'm wondering if it became disassenbled at some point. I'm sure many know this gadget - it has three main acrylic pieces, with the blade-holder fixed at right angles to the longer piece: they're cut with twin square dovetails that fit snugly together. They look as if they have traces of glue - but with mine, they were not glued together. Doesn't look to be usable if not fixed rigidly at right angles, and I can epoxy these bits straight away; but should it have come like this, not glued? Should I mention it to the shop? rgds Tony Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted December 18, 2021 Share Posted December 18, 2021 It looks like a copy of the old Kavan cutter, why would you want to glue it together ?. Quote Link to comment Share on other sites More sharing options...
Tony Harrison 2 Posted December 18, 2021 Author Share Posted December 18, 2021 Hi Paul. It does bear a certain resemblance. If you imagine the upright (blade holding) bit not fixed solidly at right angles, but free to wobble from side to side, you'll appreciate that it would not guarantee a precisely square cut all the way along a strip. And I think it was meant to come glued solidly from new, but had come apart in shipping or on the shop's shelf. rgds Tony Quote Link to comment Share on other sites More sharing options...
David Ovenden Posted December 19, 2021 Share Posted December 19, 2021 Tony, Looking at the photo I believe the blade holder (vertical part) should be rigidly attached to the horizontal (adjustable sliding) part. You could glue it but I would contact the shop for a replacement item. Quote Link to comment Share on other sites More sharing options...
Tony Harrison 2 Posted December 30, 2021 Author Share Posted December 30, 2021 On 19/12/2021 at 12:16, David Ovenden said: Tony, Looking at the photo I believe the blade holder (vertical part) should be rigidly attached to the horizontal (adjustable sliding) part. You could glue it but I would contact the shop for a replacement item. Hi David, and thanks - sorry for my belated reply but I've only just seen your helpful comment! I couldn't be bothered to drive ten miles to the shop, then wait an indefinite period for a replacement to arrive - so I epoxied it together again. It works fine, very useful. Best, Tony Quote Link to comment Share on other sites More sharing options...
David Ovenden Posted December 30, 2021 Share Posted December 30, 2021 1 hour ago, Tony Harrison 2 said: Hi David, and thanks - sorry for my belated reply but I've only just seen your helpful comment! I couldn't be bothered to drive ten miles to the shop, then wait an indefinite period for a replacement to arrive - so I epoxied it together again. It works fine, very useful. Best, Tony In the circumstances I would have done the same Tony 2 Quote Link to comment Share on other sites More sharing options...
