Nylon engine-mounts: self-tappers or through-bolts?
Jonathan M
Can't see vibration causing issues myself, as Paul says it's like screwing into a giant nyloc.
If you want to use through bolts, go ahead, both methods work.
Something else. I use a dremel cutwheel to cut into a screw, then use this to kind of cut a thread into the mount after drilling pilot holes.
I've used this method to clean out bulkhead threads in locations where a tap and tap wrench would not access but by using a caphead screw cut this way to effect a crude tap and a ball head Allen key it's an an easy fix.
7 hours ago, Paul De Tourtoulon said:
Screwed into plastic is like a nystop nut but with 10 times more surface...
Absolutely spot on.  I wouldn't self-tap into metal or wood mounts, but into GRP designed for the purpose - why not?
The only problem is getting the pilot hole just right.  The temptation is to drill undersize for a really tight fit, but that risks shearing the screw head.  If you get the hole right and use proper Parker Kalon (or equivalent) screws, then there'll be no problem.
