Dumas Dragon Rapide
Chris Walby
2 hours ago, Shaun Walsh said:
Presuming you are using a 2S battery
Hi, not sure the relevance of the 2S battery question, but yes that's the primary option although others have used 3S and the 4Max kit can do either.
As for the space, previous photo looks like the motor will go it although the mount might be a bit tight
If the worse comes to the worse, I'll trim the X mount down and fix the screws with a smaller PCD as I'll only be scale flying I doubt they will pull out of ply.
PS I thing the Hacker will be an even harder choice due to the lack of space in the front of the nacelle
I'm a bit late answering the question about the fuselage stringers but I believe they are supposed to be glued on the outside of the basic frame.
The Tiger Moth has a single wooden strip on each side (and the bottom rear) of the fuselage, it gives the fuselage some section but I think their main job is to raise the fabric covering off the steel tubing and fittings (stopping holes caused through fretting). The Piper PA-25 Pawnee has the same feature.
I think the DH.89 is the same as I saw an uncovered fuselage under restoration which appeared to be a ply box with stringers running outside.
You can simply add a stringer over the cut ones.
Some piccies:
1. Our Tiger Moth, the wooden stringer (painted green) is within the red ringed area (just below the pitch trim control rod). The upright and diagonal members are steel tube.
2. My Hacker Tiger Moth (CO2). The model as designed doesn't have the stringers but I will add them (when I eventually get round to finishing it). Stringer is just taped on here and is a bit oversize.
Found a photo that will help (from Wikimedia Commons).
De_Havilland_DH98_Restoration._(16650115122).thumb.jpg.70b25e5f9de54ab82a00d3e0ef57da97.jpg
Two more Tiger Moths, both Flair, the stringer is running through the centre of the registration on the big one. The small model is the rubber powered kit, converted to electric. It has the side stringers on the plan but leaves off the lower rear one.
I received the hardware from 4-Max and George included a programming card that I had not heard of before.
He says it is important to set the “Low Voltage Cut Off” level to the lowest. Failure to do so could result in one ESC cutting power to one motor which would then make your model
uncontrollable under power should the battery voltage drop too much.
I am not at all sure what to do with it and it came with no instructions. Does any of you have experience of using such a card?
There is a guide on the 4-Max web site and I'll set mine up and detail a how to guide for you.
PS it is a case of plug and play and so much better that trying how to do/screw it up with the TX!
Ian
With a twin that cannot fly on one the best advice is to simply stay well clear of the ESC LVC point. In other words keep the flights short and record how long they were. The safest way to judge how much capacity you have used is to note how many mAh you have to put in to restore the battery to full. I would suggest a flight duration that ended up using using about 60% of its nominal capacity should be safe and keep the voltage clear of the LVC.
It is what I do with my Bombardier airliner twin.
I could set up the Tx to arrange that one motor could be cut 'on demand' so I could actually find out, at a safe altitude, if it it is controllable but so far I have not plucked up the courage to do it. ?
40 minutes ago, Simon Chaddock said:
Ian
I would not suggest trying spin recovery with this model from what I have found there is very little information on the subject + due to its size and construction I would say there would be undue stress and resultant catastrophic failure of the airframe if it was repeated frequently. Pick another twin to play with.
Second point ESC LVC can be encountered in more ways than just duration as high load even on a fully charged battery can occur. It depends on the battery capacity, C rating and load imposed. That's why George suggests that the setting is moved as low as possible. I noted that an earlier post mentioned running on 3S as 2S didn't give the performance they wanted.
Its worth remembering (for me anyway) that adding weight is not an option so going 3S would impose a reduction in battery capacity to achieve the same AUW and I'll stick with Georges suggestion for now.
Thanks for peoples advice, but please keep it relevant to this build, cheers
Thanks for the info and advice. I shall try to figure it all out when I have got closer to finishing the Rapide. The tiny servos for the ailerons that I received do fit easily into the end of the wings just behind the aileron so i shall give that a go.
  • 11 months later...
I posted on another Rapide thread as I could not log on for some reason and have rejoined. User name and password are different but I am still Ian Lauder!
After a long break to join a club and learn how to fly RC and build a Super 60 - I have returned to the Dumas Rapide build and am stuck at the engine mounting stage.   George at 4-Max sold me a bundle of hardware that he recommends for this kit and it included two  2 x PPOM-2314-2400 Brushless Motors which have a mounting cross to be fixed to the rear of the motor.  Offering them to the plan, they seem to just fit inside the outline of the cowl as previous posters have shown here, but I have to construct a firewall to bolt the cross to. Has anyone mastered this and can suggest the best way to do it whilst saving weight?
Hi, My build has stalled although I will get it off the sideboard and have a look as I have the same 4Max kit.
I think it will be a case of mocking something up, posting here and seeing if anyone else has a better idea although that's the point of forums like this ! 😉
Unless someone else has done it....
  • 4 weeks later...
This is an interesting thread. My own build of the Dragon Rapide stalled a few years ago, one reason being the motor mounting. I stumbled across these , I think on ebay. There seems to be plenty of room in the cowl to allow for the dropped engine bearer to fit....
Edited by Nick James
Thanks Nick and an interesting option, once I get back to it at some point.
Looking at mine IIRC its tight between the ali motor mount (outside fixing holes) and the cowl so I was going to see if I could get a clubmate to 3D print something that the motor mounts to and sits directly against the existing bulkhead. The challenge will be strength at min weight, but he does like a tricky problem to solve!
Hi Chris - I spent ages (probably weeks on and off) trying to work out how to fit it using the X mount supplied with the motor. I came to the conclusion that it will only fit if the outer holes are clipped off - but then you're left with nothing to attach it to the plane.
  • 4 weeks later...
  • 7 months later...
Hello after a long gap.  So I learnt to fly again (after 50 years, and that was single channel) and as its 2 Christmas's since I started the Rapide kit, and the weather is lousy, I am determined to complete the model. I have mounted the motors (what a time consuming task that was), installed the servos/receiver and started to cover the tail fin. Unfortunately as the covering shrank it pulled the fragile rounded top down so I had to take off the covering and strengthen the balsa top curve.  I am expecting similar problems with other fragile parts.  I am about to work out how to secure the tube through which the elevator wire runs so that it is not flopping about inside the fuselage.  Any tips are welcome.  I bet those in the Holy lands and Ukraine wish they only had these problems!
Happy Christmas.
Hi Rapide. The tubes for control rods can be a so and so to fix as few if any adhesives will stick to them. I wrap the ends and any midway support areas with masking tape applied firmly and then lightly coated with cyano to prevent the adhesive drying out. Just one or two winds. Then once ibstalled through the supports or the side of fuz just apply a drop of cyano and jobs done. Provided both ends are fixed securely then the control will be sound. Thr middle support if used doesnt have to be glued, just supported so as to take load off the end fixings. Same applies to control snakes on bigger models.
Good luck with build.
Edited by Engine Doctor
