Posts not going up
Peter Miller
Peter,
If you experience the problem again please observe what happens when you click on 'Submit Reply'? Does the button colour fade (greyed out) and stay that way for a few minutes, after which it changes to 'Saving'. While 'Saving' does your browser display it's 'wait for it' signal?
I see this behaviour regularly. At first I thought posts were not going to be saved, however if I wait long enough they are.
(Problem seen over long period with different browsers).
I had this problem quite a few times. Eventually I worked out that when the problem arose I had not pressed the Submit Reply button ?
Now I am more careful so that I don't press Latest Posts before Submit Reply. ?
Just did it again
and it worked when I pressed Submit Reply on the second attempt.
Edited by EarlyBird
3 minutes ago, Peter Miller said:
I went back to it after leaving the forum it said my reply had been reinstated.
Yes that's what happened to me and I assumed I had not pressed submit reply. I was going to say 'in my case it's an age thing' ?
Now you have got me thinking that maybe I did press Submit Reply.
Time for some more testing I think.
