Robert Parker Posted January 19, 2022 Share Posted January 19, 2022 (edited) Hi All, I have just bought an NX8, and I am having trouble getting the WiFi to set up. I have tried several times now and getting a little annoyed with it. So I go into WiFi Utilities, connect to network and select my WiFi, so far ok, I then select password and it takes me to the password screen, I use the scroll wheel to enter the correct password. (At this point it is me I think), I press the scroll wheel and it takes me to the main screen. I then go to the WiFi utilities screen, credentials and highlight the connect and press the scroll wheel, it tries to connect but fails. The password is correct, I have entered it correctly. Is pressing the scroll wheel the way to enter the password after the last character has been entered? I have tried about 5 times now even with my 15 year old son at hand and still to no avail. The instructions skip this bit, just enter the password it says Any advice welcome I have registered the set online though I don't see this would make any difference as it will not connect Regards Robert Edited January 19, 2022 by Robert Parker Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted January 19, 2022 Share Posted January 19, 2022 (edited) Forgive the narna type questions Robert But have you registered the NX. To Update the NX As from there you log into wifi. Does all the available Wi-Fi on your location show on the list? As always, YouTube shows you how Edited January 19, 2022 by Denis Watkins Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted January 19, 2022 Share Posted January 19, 2022 (edited) Part of my post was missing sorry. My NX did not get full function until registered and upgraded. I was doing a double check on your process as it is the way to go. The thumbwheel does confirm inputs, so is the last click Again Does all available local Wi-Fi show on your screen. Edited January 19, 2022 by Denis Watkins Quote Link to comment Share on other sites More sharing options...
Nigel R Posted January 20, 2022 Share Posted January 20, 2022 Silly question - are you for certain connecting to your own WiFi? Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted January 20, 2022 Author Share Posted January 20, 2022 Hi Both, I have registered the NX online and all available WiFi are shown and correctly identifying my own in the process. I will try again later tonight Regards Robert Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted January 20, 2022 Author Share Posted January 20, 2022 (edited) Having had a couple more attempts, with no success I took some photos to show you what I am doing. Starting to enter password Password entered. Attempt 1. On entering the last letter and still highlighted I pressed the scroll bar (long press, short press or click no response) And went straight to the home screen. password entered. Attempt 2. went 1 space so last letter not highlighted and pressed the scroll bar (long press, short press no response) And back to the home screen. Then going to the WiFi utilities selecting connect to Network I get this sometimes, new to me. Then it tries to connect and then I get this on either attempt. I have also tried the "Saved Networks" only not to connect. Just a note that I have upgraded from a DX9 so the Spektrum system is not new to me. Regards Robert Edited January 20, 2022 by Robert Parker Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted January 21, 2022 Share Posted January 21, 2022 This is going to sound really stupid, but have you tried rebooting the hub/router? It was the only way I could manage to get my wife's new ereader to join our network...... Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 21, 2022 Share Posted January 21, 2022 Does look to be a password issue. I had problems with passwords when I kept trying the wrong password, I can't remember what it was, I kept putting the wi-fi password in but eventually worked out it was asking for the device password. Frustrating yes, to the point where it nearly went out of the window. Once I realised the issue it was simple. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted January 21, 2022 Share Posted January 21, 2022 Get what you can from this YouTube vid from 3 minutes mark. 1 Quote Link to comment Share on other sites More sharing options...
Mitchell Howard Posted January 21, 2022 Share Posted January 21, 2022 Is the NX8's WiFi 2.4GHz only or does it also include 5GHz - our home router (nothing special, 6yr old Virgin Media item) sends out two networks, a 2.4GHz one and a 5GHz one. I name my networks by the frequency, so I can see, but if you've never done that, they could look very similar. If the NX8 can only see one or the other, or you're used to connecting to a particular one with one password, then perhaps you're indeed giving it the wrong password. Take a look at the back of the router. 1 Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted January 22, 2022 Author Share Posted January 22, 2022 Hi All, Finally sorted ? It was not me, well not quite. Having again looking at U-tube and came across one which discussed how to update via USB lead. In this video it also mentioned to do this first as Spektrum have experienced some radios WiFi setups not working correctly. So I followed the instructions as per video and then went on to WiFi setup and entered the password, this time pressing the Back button instead of the scroll wheel and it took me back to the WiFi setup screen and then pressed connect and I'm connected. Thanks to all who gave their advice. My next tasks are to change to Mode 1 and transfer all my model memories from my DX9 once I buy a mini SD card with an adapter Regards Robert Quote Link to comment Share on other sites More sharing options...
