Rocker Posted February 12, 2022 Share Posted February 12, 2022 Just brought a Spektrum 8020T receiver and have just set up the Telemetry on my DX8 When I set the flight pack voltage on the DX8 I select Lipo 6s and the minimum voltage comes up at 18 V and the max at 25.4 V. I want to set the minimum voltage at 22 V but when I try the lipo setting just changes to Lipo at 7S. If I return the Lipo to 6S the minimum goes back to 18 V. 18V surely is to low for a 6s lipo How can I get the setting on my DX8 to get the correct low battery setting right. At 18 V I would of lost power to the model ???? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 12, 2022 Share Posted February 12, 2022 Which DX8 Rocker Is it the Black DX8G2 Quote Link to comment Share on other sites More sharing options...
Nigel R Posted February 13, 2022 Share Posted February 13, 2022 3.0 per cell will match the low volt cutoff in your esc. This will be voltage under load not resting voltage. Unless you have good reason I'd leave as is. Quote Link to comment Share on other sites More sharing options...
Rocker Posted February 13, 2022 Author Share Posted February 13, 2022 Hi Denis it is the DX8 G2 Nigel thanks for your reply. That makes sense I thought if Spektrum had set it like that it must be right. I take your advice and leave it at the Spektrum setting Thanks 1 Quote Link to comment Share on other sites More sharing options...
