John Botomley Posted February 21, 2022 Share Posted February 21, 2022 I'm looking to buy a smallish warbird - I'm thinking 3S LiPo size, either hand launch or fixed undercarriage to keep it simple. I'm advised that the Mustang tends to be one of the more stable ones.....? I normally fly Futaba FASST , but also have a Spektrum DSM2/ DSMX transmitter. I would even consider a nitro capable model - I have a couple of spare engines (15 & 19 size) So - I'm after some practical advice and / or a good used model - WHY?? Quote Link to comment Share on other sites More sharing options...
Jon H Posted February 21, 2022 Share Posted February 21, 2022 Small warbirds are rarely the most stable of beasts. Bigger is usually better. The question i would ask is what are you looking for? Is this a stepping stone to bigger models later, something fun to fly in the park, something like a fun fighter to offer scale shape but high performance? If its a stepping stone i would go bigger, if its a park fly then electric foamy jobs are likely to be a good bet. Fun fighter kits have a long history and their performance is both fast and wild at times although a smaller engine can tame the beast somewhat. Its just helpful to know a little more about what you want from the model. Quote Link to comment Share on other sites More sharing options...
Glenn Philbrick Posted February 21, 2022 Share Posted February 21, 2022 Having had most of the popular warbirds over the years I would agree the mustang variants tend to be more forgiving. The fun fighter are a good basic model but might be under powered with either 3s or a 19 size ic. Foamys are good in light winds and would be ok with 3s. Quote Link to comment Share on other sites More sharing options...
J D 8 Posted February 21, 2022 Share Posted February 21, 2022 I built a Cambrian Spitfire with an Irvine 20, flew well enough but getting away from hand launch was dodgy. Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted February 21, 2022 Share Posted February 21, 2022 From my experience John, go big or go foam. Big machines are easier to see and usually have a lower wing loading which normally makes them more predictable and less twitchy. If you want to go small, go foam. Again the foam small machines are generally lighter so fly nicer. What you really need to avoid is a small, heavy, highly detailed machine which is a real fight to get into the air, twitchy in the air and a nightmare to land. I totally agree with Jon, work out why you want a warbird and what are you expecting to get from it. What is your classification of a warbird, a WWII fighter, a WWII trainer? What is your flying experience? Is size really a critical requirement? Work out the above and then look at a few suppliers and see what is on offer and go from there. Quote Link to comment Share on other sites More sharing options...
MattyB Posted February 21, 2022 Share Posted February 21, 2022 (edited) Before the prices got silly when they rebranded to EFlite the Parkzone foamies were a perfect option. Some had retracts, some were handlaunch, but all flew beautifully with pretty much zero bad habits. The P47 I had was a gem - it had well over 200 flights with zero issues when I sold it on to make space for other projects. It handlaunched great, had plenty of power for scale style flying and could cope with up to 15mph of wind - with a stabiliser added I’m sure 20 would have been fine. Unfortunately they aren’t still available, but the 1.2m P-51 is, though it’s about double the price I paid for the Jug 7 or 8 years ago… Edited February 21, 2022 by MattyB 2 Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted February 21, 2022 Share Posted February 21, 2022 Hi, Depends what you want to fly, big warbirds might be easier, but boy are they expensive if it turns into a bin liner job. If you want to go 3S then go 3S2200 which puts you in the Cambrian FunFighter range, can't say it was hard to fly (ME109). I wanted speed and as it has quite a thick wing and the aerodynamics of a brick its was no EFXtra by a long way despite killing very high C lipos. Launching is much the same as any hand chuck model once you have the technique its easy, but you could always fit a folding prop for a few initial flights. Tony Nijhuis does a few small, but only pick them if you can build very light. If I was to revisit this size I would look very closely at the Cambria (look on facebook) range as they are a modern design and look good quality. If you can squeeze a bit larger then take a look at the VQ range (I am using Laser 80's in the FW190 and Aircobra) as they fly well and come electric compatible. Alternatively take a look at the Motion RC kit (I have a P38) and at least they accept it needs to be able to take off from grass! Lastly if you can find any of the Eflite Parkzone models they were well sorted and fly very well. Ok they don't resemble how a much larger model will fly, but if you intend to fly large models it won't matter. 1 Quote Link to comment Share on other sites More sharing options...
leccyflyer Posted February 21, 2022 Share Posted February 21, 2022 6 hours ago, John Botomley said: I'm looking to buy a smallish warbird - I'm thinking 3S LiPo size, either hand launch or fixed undercarriage to keep it simple. I'm advised that the Mustang tends to be one of the more stable ones.....? I normally fly Futaba FASST , but also have a Spektrum DSM2/ DSMX transmitter. I would even consider a nitro capable model - I have a couple of spare engines (15 & 19 size) So - I'm after some practical advice and / or a good used model - WHY?? Find a Parkzone Spitfire IX - you might get one on the BMFA classifieds. Failing that find a Parkzone Spitfire IX as they pop up regularly on eBay and are fantastic flying machines on 3s1p 2200mah lipos - handlaunch and belly land if that suits what you are after. If that doesn't work out, you could try and find a Parkzone Spitfire IX on FB Market place, or maybe Gumtree or a local swapmeet. Whichever way you decide to go, did I mention to try and get a Parkzone Spitfire IX? 2 Quote Link to comment Share on other sites More sharing options...
Jonathan S Posted February 21, 2022 Share Posted February 21, 2022 Richards Warbirds Replica are a 4s3500. I am yet to fly mine but everybody else swears by them. Otherwise the Arrow range seem a cheap reliable foam warbird. I think flying style and what you like will depend on what you get. Do you want to build or do you just want a warbird? Quote Link to comment Share on other sites More sharing options...
Dad_flyer Posted February 21, 2022 Share Posted February 21, 2022 Or for more cartoon scale than a funfighter, but plenty light and generally easy flying, build a Flitetest foamboard warbird. The simple Spitfire is great fun, but certainly not scale. I have not tried the master series version, which is a much better shape. Quote Link to comment Share on other sites More sharing options...
Jake Bullit Posted February 22, 2022 Share Posted February 22, 2022 I`ve got the Flightline Mustang from MotionRC.Cracking wee plane.Or Hobbyking do the Galloping Ghost Mustang which is supposed to be a great flyer from what I have seen. 1 Quote Link to comment Share on other sites More sharing options...
Christopher Long 1 Posted February 22, 2022 Share Posted February 22, 2022 Why not buy British, often overlooked how about the Vintage Model Company range of Balsa Basics warbirds? They do Spitfire, Hurricane and Bf109 models. Quick build using traditional balsa and Plywood construction and are about the size asked for. https://www.vintagemodelcompany.com/rc-planes-for-beginners.html 2 Quote Link to comment Share on other sites More sharing options...
John Botomley Posted February 22, 2022 Author Share Posted February 22, 2022 Firstly, thank you for all of your comments and ideas - I will follow them up. I'm an intermediate level sports flyer who has come back into 'planes after 30+ with helicopters. In addition our new club field is not for the foreseeable future suitable for ROG The plan is get a hand launch / belly land stable-ish low wing / shoulder wing warbird that behaves like a sports low wing non-scale model. I've no plans to move onto larger scale machinery - I fly nitro larger intermediate machines 1 Quote Link to comment Share on other sites More sharing options...
MattyB Posted February 22, 2022 Share Posted February 22, 2022 8 hours ago, John Botomley said: Firstly, thank you for all of your comments and ideas - I will follow them up. I'm an intermediate level sports flyer who has come back into 'planes after 30+ with helicopters. In addition our new club field is not for the foreseeable future suitable for ROG The plan is get a hand launch / belly land stable-ish low wing / shoulder wing warbird that behaves like a sports low wing non-scale model. I've no plans to move onto larger scale machinery - I fly nitro larger intermediate machines In that case you have lots of good options in this thread. One more from me... The old Parkzone Gunfighter was a gem, no retracts and slightly smaller at 1m span, but tough as old boots and had zero vices. I guess the nearest equivalent today is that Flightline Mustang from Motion RC, but at 850mm it's a bit too small for my liking. The HK Galloping Ghost seems to fly well and is about the same size as the Gunfighter, but calling it scale or a warbird is pretty tenuous; you could always tweak it and/or dress it up in a different livery I suppose... Quote Link to comment Share on other sites More sharing options...
J D 8 Posted February 22, 2022 Share Posted February 22, 2022 Parkzone F4f Wildcat Quote Link to comment Share on other sites More sharing options...
John Botomley Posted February 23, 2022 Author Share Posted February 23, 2022 Thanks again everyone - Flightline Mustang most likely 1 Quote Link to comment Share on other sites More sharing options...
