Jeffrey Cottrell 2 Posted March 13, 2022 Share Posted March 13, 2022 Hi guys Picked up this model at the Horam Swapmeet. Wonder if anyone can help me identify it. Google search reveals Volantex do (did) a Sbach 342, but that is listed as 1.1 Mtr, where mine is 1.4 Mtr. It has wings which slide on from each side and then bolt in place. There is a 3/8 ply spar extending about 2/3 span. Also the rudder is operated by closed loop, but using wire rods instead of cables. Neither the motor or the esc have any markings on them. It came with a 14 x 7E prop and the recommendation to use 4s. Any of this ring any bells? Thanks Jeff Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted March 13, 2022 Share Posted March 13, 2022 Looks like this NEW SBACH 342 EPO 1400mm from hobbyking - RC Groups Steve 1 Quote Link to comment Share on other sites More sharing options...
Jeffrey Cottrell 2 Posted March 13, 2022 Author Share Posted March 13, 2022 Hi Steve, thanks. That certainly looks like the one. Always amazed how you guys come up with this info so quickly. Will have a look through that RCG thread, but its 178 pages long so may be a while. Thanks again Jeff Quote Link to comment Share on other sites More sharing options...
PatMc Posted March 13, 2022 Share Posted March 13, 2022 (edited) error Edited March 13, 2022 by PatMc Quote Link to comment Share on other sites More sharing options...
kevin b Posted March 14, 2022 Share Posted March 14, 2022 Found the esc programming manual at Hobbyking. Normal_Airplane_ESC__50A_and_above_374.pdf Quote Link to comment Share on other sites More sharing options...
Stuphedd Posted March 15, 2022 Share Posted March 15, 2022 I have one of those Sbach and I like it a lot , The only problem I have encountered is the cockpit cover has removed itself twice now during very violent manouvers !! and the "hinges" the as is foamy ones , fail and so its now go proper ones ! Quote Link to comment Share on other sites More sharing options...
MattyB Posted March 15, 2022 Share Posted March 15, 2022 (edited) Weird how the horizontal tail is all discoloured given it is an electric model. It must have been stored with the fuselage and wing covered but the tail stuck out in the sunlight being discoloured by the UV! Edited March 15, 2022 by MattyB Quote Link to comment Share on other sites More sharing options...
Colin Carpenter Posted March 15, 2022 Share Posted March 15, 2022 Yes Hobbyking SBach. I’ve had one and found ,set up correctly, it flew almost as good as a Sebbie !! Changed uc for a Riot one as sprung steel one couldn’t cope on our grass. Original esc gave up on flight 50. No damage. Nice plane. Colin Quote Link to comment Share on other sites More sharing options...
Jeffrey Cottrell 2 Posted March 15, 2022 Author Share Posted March 15, 2022 Hi Guys, thanks for your thoughts. Kevin Not sure my esc follows the normal rules. Powered it up with throttle high and all I got was a series of slow beeps, not the musical tones I expected. Mind you, doesn't really matter. The fitted esc has no markings so no idea of current capacity or bec, so I'm replacing it with a Hobbywing one I have lying around. Rather have something I can rely on. Stuphedd Re: hinges Mine has pin hinges, rather than foam ones. Look like original, and the RCG thread does mention these as being rather weak, but mine seem ok so far. Judgement reserved till after flight. MattyB Yes, that is odd. Added to that is that the leading edge of the tailplane has a series of dents in it, either through landing in tall grass or being hung up by its tail from a wall or something. Either way, not going to worry about it. 50' up no one will notice. Given I only paid £40 for it, can't expect miracles. Now a question I can't answer. The motor has a bolt-on prop driver, but this has a collet taper machined in, which I've never seen before. OK, so far, but the position of the cowl means the spinner backplate needs to go on this taper, so neither the prop or the collet is properly centralised. Managed to centralise the prop, using a plastic ring from an APC prop, but can't see a way to get the spinner ring to run true. Going to run without spinner atm, while I (or probably you guys) figure this one out. So far, so ho hum. We'll see Thanks Jeff Quote Link to comment Share on other sites More sharing options...
Jeffrey Cottrell 2 Posted March 20, 2022 Author Share Posted March 20, 2022 Hi Stuphedd, could use some help. Work proceeding well on my Sbach. Pretty much standard stuff except one thing I can't get my head around. The wings are held on by 4mm bolts through holes in the wing roots. Trouble is the holes in the roots are 7mm diameter. Can't help thinking there should be some form of insert in these holes to reduce the diameter, but not sure. Did yours have anything? Thanks Jeff Quote Link to comment Share on other sites More sharing options...
