Dale Bradly Posted April 12, 2022 Share Posted April 12, 2022 Chaps, 2 questions. had this combo working great, many flights, no problem. Moved the Rx to another plane, and at that time two issues crop up. 1. It will bind WITHOUT the use of the bind plug. After a power cycle, has lost bind. (but easy to rebind!) I'm not the only one this has happened to, e.g. Link. Seems to me this is terminal and Rx is headed for the bin, but is there a known cause, so this doesn't happen again? 2. With this faulty Rx, and two others, one being a FS-iA6B, and the Turningy equivalent 10ch, will bind fine, but for the first 30 seconds or so, the connection is quite rough, with intermittant control, and telemetry dropping in and out. After 30 seconds or so, it comes in rock solid. I wonder if this is normal, and it's a fine-tuning "handshake" to dial in the connection, or something up with my Tx? Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted April 12, 2022 Share Posted April 12, 2022 Point 2, could you be too close to the receiver with your Tx so it is being swamped? Quote Link to comment Share on other sites More sharing options...
Dale Bradly Posted April 12, 2022 Author Share Posted April 12, 2022 Tried this, I don't believe so Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted April 13, 2022 Share Posted April 13, 2022 I don't have any of the Rx's above, but my TX16 is used with Spektrum (DSM2/DSMX), Orange (DSMX/DSM2), FrSky, FrSky clones, Radiomaster receivers, and none of them exhibit the 'dodgy' initial connection.... some do get swamped resulting in warning messages when the Tx is close to the model but I've had no other issues. Some Rx's need you to adjust the fine tuning at bind - not sure if this applies to your RX's.... Quote Link to comment Share on other sites More sharing options...
John Wagg Posted April 13, 2022 Share Posted April 13, 2022 Is there another Tx available to try the Rx's with ? Quote Link to comment Share on other sites More sharing options...
Max Z Posted April 13, 2022 Share Posted April 13, 2022 (edited) 13 hours ago, Dale Bradly said: 2. With this faulty Rx, and two others, one being a FS-iA6B, and the Turningy equivalent 10ch, will bind fine, but for the first 30 seconds or so, the connection is quite rough, with intermittant control, and telemetry dropping in and out. After 30 seconds or so, it comes in rock solid. I wonder if this is normal, and it's a fine-tuning "handshake" to dial in the connection, or something up with my Tx? I experience the same thing sometimes with my Turnigy TGY i6 Tx and Turnigy iA6A and iA6B Rx's (rebranded FlySky). Tx off and on restores normal behaviour. Edited April 13, 2022 by Max Z Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted April 13, 2022 Share Posted April 13, 2022 I sometimes use a TGY 6i or 10i with ia6B`s. No problems, but a 10i will certainly not bind with an ia6. Send me a pm then your Rx and I can easily check it out if you wish. Quote Link to comment Share on other sites More sharing options...
John Wagg Posted April 14, 2022 Share Posted April 14, 2022 Just had a look at my TX16S and there is no option to fine tune as per FRsky Rx's. Did notice there is a choice of refresh rates at 22ms or 11ms. Whether this is relevant I don't know or even if I have the correct protocol as I have it matched to an FS-iA6B. Quote Link to comment Share on other sites More sharing options...
