Andy J Posted April 14, 2022 Share Posted April 14, 2022 For some bazar reason I have ended up with reversed trims on an aileron channel. Why has this occurred and how do I correct the situation? Quote Link to comment Share on other sites More sharing options...
Andy J Posted April 14, 2022 Author Share Posted April 14, 2022 May have found the issue. Apparently I had set a negative weight on the aileron channel so set that to +ve value and then reversed the channel output. Yet to check operation on the model. Quote Link to comment Share on other sites More sharing options...
MattyB Posted April 14, 2022 Share Posted April 14, 2022 Yes, that’s correct, about the only “you must” rule of OpenTX is never have negative weights on the input page, it can give some very strange results. Quote Link to comment Share on other sites More sharing options...
Wihtgar Posted April 15, 2022 Share Posted April 15, 2022 I also had problems with reversed elevator trim on my x9D Tx. Careful checking with a servo tester confirmed that there is a problem with the elevator gimbal wiring - somewhere it is reversed and I have to reverse the elevator throw in either Inputs or Mixers to ensure the trim switch moves the elevator in the correct direction. Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted April 15, 2022 Share Posted April 15, 2022 Not sure how you know there's a 'problem' with the elevator gimbal. The direction a control surface moves in response to stick input depends on the physical layout of the servo and surface, and also on the electronics of the servo itself. Are you saying that in the servo monitor screen, with no programming on the channel, the bar doesn't move up as the stick goes up? Quote Link to comment Share on other sites More sharing options...
Wihtgar Posted April 15, 2022 Share Posted April 15, 2022 I did a lot of testing reversing servo direction in the inputs, mixers and outputs noting the corresponding trim directions concluding that the elevator signal is reversed. On the screen which shows the stick positions, when the elevator stick is moved down, its position on the screen goes up. In companion the stick position follows the control stick as you would expect. All other stick positions on the taranis screen follow the sticks correctly (but not the elevator) Quote Link to comment Share on other sites More sharing options...
