Brian Dorricott 1 Posted April 19, 2022 Share Posted April 19, 2022 I have a Access SR6 receiver and I cannot get it into the mode where the blue light flashes and you can calibrate the sticks etc . I have set the switch middle position delay to 0ms as that's a known problem and made sure nothing is reversed on the switches but no joy , I've gone from toggling at a slow rate to toggling like a fiddlers elbow but nothing gets the blue light on . I've even tried pushing the bind button while on even that does not do it . I only have one Access TX so can't eliminate that but it's an upto date X10 Express and the receiver is the latest firmware as well . The receiver actually works OK as a stabilised receiver but I don't like missing out a step that's in the procedure . So if anyone has an idea what I've missed please speak up as I have had to fit an old S6R to keep flying ,bit of a backward step really . Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 19, 2022 Share Posted April 19, 2022 With all Tx sticks at neautral, and model sat on its wheels Switch On Press the F/S Button on the Rx Blue light does its check Quote Link to comment Share on other sites More sharing options...
Mike Blandford Posted April 19, 2022 Share Posted April 19, 2022 From things I've read, CH12 has to change much quicker than over 2 seconds, and CH3 (throttle) must be at -100%. Mike Quote Link to comment Share on other sites More sharing options...
Brian Dorricott 1 Posted April 19, 2022 Author Share Posted April 19, 2022 No Denis it doesn't after pressing the F/S , no blue light tried that. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 19, 2022 Share Posted April 19, 2022 Quote Link to comment Share on other sites More sharing options...
Graeme White Posted April 19, 2022 Share Posted April 19, 2022 Following as I too have an s6r that I have never been able to calibrate. It does stabilise and I had to raise 1 end of the receiver to ensure the plane was kept level as I could never get the thing to calibrate. Quote Link to comment Share on other sites More sharing options...
Brian Dorricott 1 Posted April 20, 2022 Author Share Posted April 20, 2022 Funny thing Graeme I put in a S6R after the SR6 ( damn confusing names) problem and that went straight in after toggling the switch so not the TX settings then . As an aside Accst D16 stabalised - S6R Access stablised -SR6 Frsky why such similar model numbers - very confusing ! Quote Link to comment Share on other sites More sharing options...
Brian Dorricott 1 Posted April 21, 2022 Author Share Posted April 21, 2022 Update for anyone following apparently there is a self test button in the menus somewhere but for the life of me I can't find it . A lot of reports that people can't get the SR6 receivers to start the self test . Maybe I need an updated SR6 lua script or whatever its called in Ethos . Quote Link to comment Share on other sites More sharing options...
Jake Bullit Posted April 21, 2022 Share Posted April 21, 2022 Are you in 8-16 channels? 1 Quote Link to comment Share on other sites More sharing options...
Brian Dorricott 1 Posted April 21, 2022 Author Share Posted April 21, 2022 No 1-16 channels I know it won't work unless the extra channels are enabled . Also checked the throttle is at -100% and the latest firmware is on the TX and the RX and transmit module is also up to date also the switch centre crossover set 0mS . Done these loads of times with S6R and RM TX16S and never had a problem except with this pesky little blighter and the X10 Express . Tomorrow might put an S6R on the X10 Express and see what happens for an exercise . Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted April 22, 2022 Share Posted April 22, 2022 With the latest RX firmware self check is a menu option when the setup software is run. SD CARD SCRIPTS TOOLS Frsky SxR_R9S.lua Toggling the CH12 switched worked until I flashed the latest RX FW. Steve Quote Link to comment Share on other sites More sharing options...
Brian Dorricott 1 Posted April 22, 2022 Author Share Posted April 22, 2022 (edited) Finally got to bottom of the problem . I thought because Frsky website said 1.1.1 was the latest version i believed it ( like a lemon) so off to Github and 1.1.4 is much later version which gives me the " SELF CHECK" mode in SxR . Now it reliably goes into blue light mode and allows calibration - eureka . I could not for the life of me get the switch method to work no matter how fast or slow you toggled , think its been removed from the TX. It will do me i now feel safe ( pun intended ) cheers for suggestions everyone and people who messaged me direct much appreciated . Edited April 22, 2022 by Brian Dorricott 1 Spellin mistake 3 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted April 23, 2022 Share Posted April 23, 2022 10 hours ago, Brian Dorricott 1 said: Finally got to bottom of the problem . I thought because Frsky website said 1.1.1 was the latest version i believed it ( like a lemon) so off to Github and 1.1.4 is much later version which gives me the " SELF CHECK" mode in SxR . Now it reliably goes into blue light mode and allows calibration - eureka . I could not for the life of me get the switch method to work no matter how fast or slow you toggled , think its been removed from the TX. It will do me i now feel safe ( pun intended ) cheers for suggestions everyone and people who messaged me direct much appreciated . Yes that's what I found. The latest version does not use the switch toggle method as it's in the Menu. A big improvement IMO. Well done Brian.? Steve Quote Link to comment Share on other sites More sharing options...
Brian Dorricott 1 Posted April 23, 2022 Author Share Posted April 23, 2022 Earlybird just goes to show with the Internet lots of information most of it out of date ! Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted April 23, 2022 Share Posted April 23, 2022 14 minutes ago, Brian Dorricott 1 said: Earlybird just goes to show with the Internet lots of information most of it out of date ! Even the Instruction Manual that comes with SR6 is out of date. ? no wonder we struggle at times. I have found in the past that printed instructions do not keep pace with product improvements. Steve Quote Link to comment Share on other sites More sharing options...
