Alan Hilton Posted May 1, 2022 Share Posted May 1, 2022 I would like to buy the above ,please could I have some recommendations Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted May 1, 2022 Share Posted May 1, 2022 Can't say I've seen a 4 channel Lipo charger. Personally I have 2 two channel chargers. If one goes wrong I at least have the ability to charge two batteries at a time. Quote Link to comment Share on other sites More sharing options...
Simon Clark Posted May 1, 2022 Share Posted May 1, 2022 Amongst others, I've got one of these and it seems to work very well. Good if you don't want too much power: https://www.4-max.co.uk/Toolkit-RC-M4Q-charger.html The only slight problem is the balance plug can be a little loose in the socket so you need to make sure you don't pull them out. Otherwise brilliant and versatile unit that can be driven from 240V ac or 12V dc. Simon Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted May 1, 2022 Share Posted May 1, 2022 2 minutes ago, Shaun Walsh said: Can't say I've seen a 4 channel Lipo charger. Personally I have 2 two channel chargers. If one goes wrong I at least have the ability to charge two batteries at a time. Just found one 4 Channel charger No idea how good it is though . Quote Link to comment Share on other sites More sharing options...
Alan Hilton Posted May 1, 2022 Author Share Posted May 1, 2022 31 minutes ago, Shaun Walsh said: Just found one 4 Channel charger No idea how good it is though . Thanks Shaun that looks like what I’m after Quote Link to comment Share on other sites More sharing options...
Philip Lewis 3 Posted May 1, 2022 Share Posted May 1, 2022 I've got five of these, (I have lot of batteries to charge), all working perfectly on all four channels, although I would have bought them when HK had either a UK or EU Warehouse, might even have been before Brexit. https://hobbyking.com/en_us/quad-4x6s-lithium-polymer-charger-400w-dc-only.html 1 Quote Link to comment Share on other sites More sharing options...
Dad_flyer Posted May 1, 2022 Share Posted May 1, 2022 I have got https://www.kingslynnmodelshop.co.uk/Chargers/c76/p13761/GT_Power_X4_Charger_4x100W_Charger-_Due_Early_Sept/product_info.html (I think it came from Kings Lynn) I use it AC at home, and DC from a LiFe leisure battery at the field. Four channels and four batteries keeps up with my flying, unless Child_flyer is there as well. It is convenient to carry around. I am pretty happy with it. The software is basic but functional. There seem to be two small bugs - to select 'up' 'down' you need to press different buttons in the main menu from the ones in all sub-menus - and if you press anything while the charger is doing its end-of-charge jingle then it will continue to beep loudly until you unplug it. The display gives information for only one battery, so you have to keep scrolling through. The discharge power is very limited, so it is certainly slow at home if I don't manage to fly all the batteries! I also find that each channel on this charger is slightly different on the individual cell balance. My other single channel chargers are slightly different again. I tend to have batteries in sets of four anyway, so I generally try to keep them each to the same port so they are at least balance consistently. The internal resistance measurement I don't think is as accurate as my Overlander charger. Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted May 1, 2022 Share Posted May 1, 2022 Like Simon, I have the toolkit unit and it seems to work well. As I do a lot of teaching on an electric machine, I do get through a lot of batteries in a session. Normally 10-12 for a session plus whatever I fly for myself, with the Toolkit I do seem to be able to keep up. Summer will tell for sure as I expect I will have to run it off a separate Lead Acid battery to keep up with a full days flying. As I use 4mm connectors, I have had to make up adaptors for each of the ports but so far so good. Quote Link to comment Share on other sites More sharing options...
Bruce Collinson Posted May 1, 2022 Share Posted May 1, 2022 Have the one Shaun showed, although mine came from 4Max who don’t seem to stock it. Very versatile charger with some software anomalies. In constant use. BTC Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted May 2, 2022 Share Posted May 2, 2022 7 hours ago, Bruce Collinson said: Have the one Shaun showed, although mine came from 4Max who don’t seem to stock it. He has a couple of reconditioned chargers. Lithium Polymer/LiPo chargers from £29.99 at 4-Max Quote Link to comment Share on other sites More sharing options...
Stuart Z Posted May 2, 2022 Share Posted May 2, 2022 Hi I use the GT X2 which must be broadly similar to the X4, obviously 2 outputs instead of 4, but very happy with it. Had it a few years now and buying a second as storage charging is a wee bit slow at only 1 amp. I guess that is fairly common though for storage charging. S Quote Link to comment Share on other sites More sharing options...
EvilC57 Posted May 2, 2022 Share Posted May 2, 2022 15 hours ago, Shaun Walsh said: Just found one 4 Channel charger No idea how good it is though . I have this one, which I bought from 4-Max about 4 years ago. It’s OK except that mine has developed a couple of faults. One of the two fans has developed noisy bearings, which grumble for the first few minutes of charging until everything warms up. Cheap sleeve bearings I guess. One of the channels won’t correctly charge any battery over 2S now. The same channel will not do internal lipo resistance readings on anything more than a 2S pack - a different symptom of the same fault in the channel I suspect. So not the most reliable of units, although still in regular use as my main charger. Quote Link to comment Share on other sites More sharing options...
Dad_flyer Posted May 2, 2022 Share Posted May 2, 2022 39 minutes ago, EvilC57 said: One of the two fans has developed noisy bearings, Mine has noisy fans as well. Quote Link to comment Share on other sites More sharing options...
Kevin Fairgrieve Posted May 2, 2022 Share Posted May 2, 2022 I replaced the fans on my G.T. Power X-Drive 607 Quad Balance Charger after the bearings went south. It was a ten minute job. The fans I used were these from Amazon Fan! They are showing as unavailable at the moment, but if you search I am sure an alternate could be sourced. Quote Link to comment Share on other sites More sharing options...
Alan Hilton Posted May 2, 2022 Author Share Posted May 2, 2022 Thanks chaps I have gone for a toolkit dual charger from 4max .If it comes up to expectations I will get another .I have a dual output power supply so no problems .The reliability issues with the gt4 put me off Quote Link to comment Share on other sites More sharing options...
Dad_flyer Posted May 2, 2022 Share Posted May 2, 2022 As you already have a power supply, the Toolkit chargers do seem a lot better. Quote Link to comment Share on other sites More sharing options...
Frank Day Posted May 4, 2022 Share Posted May 4, 2022 Have a nosey at this one Skyrc Q200 quatro, charges pretty much everything https://www.skyrc.com/Charger/Q200_Charger Quote Link to comment Share on other sites More sharing options...
Keith Billinge Posted July 4, 2022 Share Posted July 4, 2022 (edited) I love ISDT chargers and the desktop one I use all the time is the D2. Only 2 channel but very reliable and lots of features. LINK KB Edited July 4, 2022 by Keith Billinge Quote Link to comment Share on other sites More sharing options...
Nightflyer Posted July 4, 2022 Share Posted July 4, 2022 Tbh there are a number of good quad chargers about GT Power X4 is one example if you want AC mains or 12v DC input, 4max have a couple including the aforementioned. One aspect to consider though is what if the charger fails then you are down 4 charge outputs. Often some people opt to buy two dual output chargers so that if one fails they still can charge and / or replace faulty charger with another dual output one. Essentially you pays your money and you make your choice. Quote Link to comment Share on other sites More sharing options...
