martin collins 1 Posted May 11, 2022 Share Posted May 11, 2022 Excuse what i guess for some of you is a pretty basic question, i have not flown petrol or glow for years but am putting a Zenoah 26 mag engine in an 82" plane and need a prop for it. Can anyone recommend a make, what would be the best choice, wood or plastic for this, something that isn`t too noisy either, i gather the prop can make a big difference. I had a look at the Falcon 18/6 beech prop, would that be a good choice? Many thanks for your thoughts on this............ Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted May 11, 2022 Share Posted May 11, 2022 (edited) Here goes and will probably start a debate fiercer than party gate ? as opinions vary so much, 100 flyers = 100 different answers ? Xoar props ( beech wood) seem very good and reasonably priced and are my first choice for petrol engines. All the ones I have been excellent quality wood with good finish and seem fairly well balanced but I alway try to get an exact balance if possible. They also seem to pull air efficiently . Some props just don't perform as expected. You might want to experiment with di and pitch to get the best from your zenoah. I try not to use composite props on petrol engines as they are very unforgiving in a light ground strike. They will/ can twist or bend a petrol crank. I believe your zenoah will have a passed together crank that can be twisted comparatively easy and a wooden prop will splinter and break easier than a composite . Ps. Look around at swap meets . You can often pick up large props in new condition for a fraction of their value. Edited May 11, 2022 by Engine Doctor Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted May 11, 2022 Author Share Posted May 11, 2022 Thanks Doctor, like your picture, that is what this is going on, a Pac Aero model Y.............. Quote Link to comment Share on other sites More sharing options...
Jon H Posted May 11, 2022 Share Posted May 11, 2022 (edited) For a racing type model you might want more than 6 inch of pitch. I would use 6 inch for a tiger moth or similar with 8-10 inch for WWII fighters. As your model is somewhere in the middle of tiger moth and WWII fighter 8 inch would probably be about right. As for prop choice, like ED i have no problem recommending wooden props with menz, fiala, xoar and falcon all being good choices. Menz tend to be fairly heavy as a load and fiala run fast from what customers have told me. Falcon seem to be in the middle. Xoar also offer scale props that are painted/a nice shape and although their efficiency might suffer (i have no data on this) there is an advantage in looks. If my memory is accurate the z26 offers similar performance to a laser 155 so 16x8-10, 17x6-8, 18x6 etc would be in the ballpark as a range of props. I would proably start with a 17x8 and see how the revs are. if you are in the 7800-8200 range then all good, if you find its faster then perhaps add an inch and go for 18x8 at around maybe 7200-7500? Prop selection can make or break the performance of a model and it will take some experimentation. Each prop brand offers different performance and an 18x8 from one brand will not match the performance of that from another. As an example, based upon customer reports i think the fiala props run a good 500-800rpm faster than the menz for the same DxP on the same engine. Edited May 11, 2022 by Jon - Laser Engines Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted May 11, 2022 Share Posted May 11, 2022 As a starter I would choose a cheap plastic prop, not everyone is familiar with tightening down wooden props or the dangers associated with them splitting and coming loose, and being new to petrol you will get some dead stick landings and nose overs,,, Quote Link to comment Share on other sites More sharing options...
Alan Gorham_ Posted May 11, 2022 Share Posted May 11, 2022 ISTR that it's good practise to fit a wooden prop to an engine with a pressed-together crankshaft and web such as the Zenoah. the thinking is that if you nose over and catch the prop, then a wooden prop will break before the crank moves. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 11, 2022 Share Posted May 11, 2022 Can't say I have ever had a bad make from reputable suppliers, Xoar, Falcon, Menz all been fine, Agree with Jon re pitch, 8 for me and will help quieten a tad. Props breaking, I would have no probs using a APC myself good efficient quieter prop. Quote Link to comment Share on other sites More sharing options...
