Gyro
That is the same pattern of About half a dozen easy to use giros Graham
It goes between your receiver and your servos
And needs mounting flat below or around your wing tube/ C of G
With the leads to the rear of the model, as the Aeroplane Symbol on the microchip is showing you the orientation.
The round pots need setting for Gain at about midway, so turn each fully forward and back, to find the middle.
1SW is your On/ Off switch normally set to Ch 5 or Aux1 on your tranny.
Go fly it
