Diamond Geezer Posted May 14, 2022 Share Posted May 14, 2022 Hi everyone I have a webra 40 in a plane that I have just got on running it up it dies on full throttle if I close it down to half throttle runs fine adjusting the main needle valve makes no difference could it be the mixture screw would it be to rich or weak. Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted May 14, 2022 Share Posted May 14, 2022 I had one very many years ago and it was a reliable motor despite being a finger biter. Does it idle? if not then someone may have turned the idle screw all the way in. Unscrew it about 2 1/2 turns then try again. They have a simple carb so there could well be a blockage of oil etc in the main jet. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted May 14, 2022 Share Posted May 14, 2022 Yep most likely some sort of blockage restricting the fuel flow. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted May 15, 2022 Share Posted May 15, 2022 As already said its likely to be a blockage somewhere in the fuel line or NV. A blow through with some fuel from a syringe may force the debris through if you are lucky. If not a proper Strip and clean out the NV and carb is the way to go . Let us know how you get on. Quote Link to comment Share on other sites More sharing options...
