craig procter Posted May 21, 2022 Share Posted May 21, 2022 Can anyone tell me what they use on their scale models paint wise, is enamel paint fuel proof? Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted May 21, 2022 Share Posted May 21, 2022 Humbrol? Definitely not. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted May 21, 2022 Share Posted May 21, 2022 Flair spectra and guild materials both claim to be fuel resistant, note resistant not proof. I've no experience with either, though. Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted May 21, 2022 Share Posted May 21, 2022 Humbrol, no, not with glow fuel, but seems to cope ok with mt d1000 diesel fuel ok... Glow fuel will attack humbrol.... Quote Link to comment Share on other sites More sharing options...
jrman Posted May 21, 2022 Share Posted May 21, 2022 I've used both Spectra and Guild. Neither work in my experience, certainly not with 10% nitro. If you want total fuel proofing then use epoxy paint or clear. 1 Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted May 21, 2022 Share Posted May 21, 2022 I found only polyurethane and epoxy paint hold up to any fuel, use your Humbrol or Tamiya acrylic paint and varnish it,,, Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted May 21, 2022 Share Posted May 21, 2022 I use Rustins Plastic Coat 2 part, it's the closest you'll get to the old Tufcoat, it works with at least 10% Nitro. Don't spray it without some serious PPE though. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted May 21, 2022 Share Posted May 21, 2022 Andy what paint are you using underneath? Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted May 21, 2022 Share Posted May 21, 2022 (edited) I have a 60" span Warbirds Replicas Hurricane finished with Guild mat enamel fuel proof paint from aerosols, not cheap but it seems to be OK. It has had a lot of flights now with a Saito 82B up front, quite a messy engine compared to a Laser but the paint work has not suffered. I waited about a month after painting before running the engine, the fuel is 5% nitro which I use all the time so I can't comment on higher nitro content fuels. My next project a Hawker Seafury has a petrol engine and I tried some petrol on a the guild paint and it was OK so I have used it on the Seafury, the only problem is a limited range of colours. I use rattle can car undercoat. Edited May 21, 2022 by Eric Robson 1 Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted May 21, 2022 Share Posted May 21, 2022 Nigel, For colour, I use acrylic car aerosol or cellulose from a spray gun. Enamel won't work well, it will pucker as Rustins has some incompatible solvent in it and you would be advised to add more to spray it. Water based colour may work though. 1 Quote Link to comment Share on other sites More sharing options...
