Brian Parker Posted December 1, 2010 Share Posted December 1, 2010 Agreed, elevator trim it is.My CoG is tad over 4”(105mm) with an AUW of 2lbs. Quote Link to comment Share on other sites More sharing options...
Ross Pert Posted December 1, 2010 Share Posted December 1, 2010 so it could be not enough reflex as they call it (?)... you might have it sussed because I flew it the time before last in about 30mph with 4oz of church roof from a steep cliff so the lift was near vertical, had trouble keeping it in sight from the height it was gainging, must have thrown heaps of down trim in and left it there last time. When out with it last week it was almost hyper stalling in 12-15mph, or possibly just me occasionally pulling up to try and control the height loss which is never a great idea. Cheers fellas, always get the answers pronto round here. Ross Quote Link to comment Share on other sites More sharing options...
Peewhit Posted December 1, 2010 Share Posted December 1, 2010 Glad that we have found the answer. Reflex is up and camber is down (technically on flaps/ ailerons), yet with a delta wing the ailerons work the other way. Anyway, too much down trim. My fusion needs the elevator trim setting for most outings as the lift is different nearly every time. Trim it so that when it is flying across the slope it is just gaining height. That is the "sweet spot".Edited By Peewhit on 01/12/2010 18:53:07 Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted March 17, 2021 Share Posted March 17, 2021 Hi, i have been given a SaS Fusion. Looks like the Ailerons have been fitted the wrong way round. The wider part of the Aileron is on the outside of the wings and the narrow part of the Aileron is next to the fin. Anyone know if this will give me problems and how much control throw do i need. ? Cheers Steve. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted March 17, 2021 Share Posted March 17, 2021 Hi Stephen I don't think it will cause any issues.. Throws here: f60m.PDF (webs.com) GG 1 Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted March 17, 2021 Share Posted March 17, 2021 Thanks. ? Steve Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted March 17, 2021 Share Posted March 17, 2021 12 hours ago, Stephen Jones said: Hi, i have been given a SaS Fusion. Looks like the Ailerons have been fitted the wrong way round. The wider part of the Aileron is on the outside of the wings and the narrow part of the Aileron is next to the fin. Anyone know if this will give me problems and how much control throw do i need. ? Cheers Steve. This is how I fitted the ailerons on all my Zagis, It looks much better with the thin outer most and is less likely to tip-stall that way. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted March 17, 2021 Share Posted March 17, 2021 @Andy StephensonYes, the illustration shows the smaller part outermost........................ Steve's are fitted with the narrowest part innermost ? I suspect given the low aspect ratio, tip stalling will not be a major problem. GG Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted March 17, 2021 Share Posted March 17, 2021 The Zagi suffered from something we called the Zagi screw which was a precipitous spin cased by an obvious tip-stall, The Zagi had a bigger aspect-ratio which was most certainly a contributory factor. A. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted March 18, 2021 Share Posted March 18, 2021 (edited) Here is a picture of my SAS Fusion wing span 46 inch I have added some new tape fixed the fin . I could always cut the Aileron down so that it is thinner at the tip of the wing. Steve. Edited March 18, 2021 by Stephen Jones Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted March 18, 2021 Share Posted March 18, 2021 If it's not broke don't fix it. A. Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted March 18, 2021 Share Posted March 18, 2021 2 hours ago, Andy Stephenson said: If it's not broke don't fix it. A. Well Yes, I will test fly it 1st ? Steve. Quote Link to comment Share on other sites More sharing options...
Dickw Posted March 18, 2021 Share Posted March 18, 2021 6 hours ago, Stephen Jones said: Here is a picture of my SAS Fusion wing span 46 inch I have added some new tape fixed the fin . .................................... I could always cut the Aileron down so that it is thinner at the tip of the wing. Steve. I wouldn't worry too much about the ailerons and just try flying it as it is. The attached image shows a wing which shows no adverse characteristics with ailerons that shape. It may be small, but it gets thrown about quite a bit during every flight and is very forgiving! Dick 1 Quote Link to comment Share on other sites More sharing options...
