Ed Anderson Posted August 20, 2016 Share Posted August 20, 2016 If he is going to start changing propellers he should check it with a wattmeter. The advice you just received is to go from a 9X4.5 to an 11X6. That is a big prop jump. That might be OK or it might overload the motor, the battery or the ESC. Once you stray from the MFG recommendations you must check with a wattmeter. I have seen too many crashes and too many buned up components due to people bumping up the voltage or changing the prop and burning something out as a result. They cry foul and blame the components until I put my wattmeter on and find they are pulling 40 amps against a 25 am ESC and a motor rated for 30 amp. Poof and all the magic smoke comes out, assuming it doesn't start a fire. Edited By Ed Anderson on 20/08/2016 21:24:38 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 20, 2016 Share Posted August 20, 2016 I know he hasn't got one. Maybe someo has one he can borrow, we do have some other electric flyers in the club. Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted August 21, 2016 Author Share Posted August 21, 2016 It had already been stated in the o/p that his friend didnt have a meter. The thead title is motors for beginners keep it simple. Im SIMPLY saying a 9" prop on 72" plain model is too small. Without knowing the exact motor specs - especially max current capabilities Its impossible to be sure. However, most decent sized 950 kv motors ive used or got are fine on a 12"prop and 12v. Mind you - what do I know 😄Edited By Tim Mackey on 21/08/2016 01:53:27 Quote Link to comment Share on other sites More sharing options...
Ed Anderson Posted August 21, 2016 Share Posted August 21, 2016 Whether the friend has a Wattmeter or not, if he is going to play around with props he should be checking the power with a wattmeter. Don't have one? If he doesn't want to get one he should stay with the MFG recommended, which, in this case is a 9X4.5 as reported in the post. Edited By Ed Anderson on 21/08/2016 02:46:04 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 21, 2016 Share Posted August 21, 2016 Thanks I will pass on both comments. As I have said, I know nothing about electrics, nor does my friend. Hence the original question. I shall suggest thathe stays with the original prop and then try bigger ones if the performance is lacking. Quote Link to comment Share on other sites More sharing options...
Ed Anderson Posted August 21, 2016 Share Posted August 21, 2016 That is a good approach. Wattmeters are an essential piece of kit for electric flyers who are moving away from Ready to fly or bind and fly packages. As you change props or battery voltage you change the power curve of the motor. As a result you can overload something leading to component failure. So you check with the wattmeter to insure that you are not overloading the motor, the ESC or the battery. They are not expensive. I have two. Here is an example of a wattmeter from HobbyKing. http://www.hobbyking.com/hobbyking/store/__14624__HobbyKing_PO_Wattmeter_100A.html Edited By Ed Anderson on 21/08/2016 14:51:19 Quote Link to comment Share on other sites More sharing options...
kc Posted August 22, 2016 Share Posted August 22, 2016 A wattmeter will save it's cost the first time it saves an ESC! Quote Link to comment Share on other sites More sharing options...
Tim Mackey Posted August 22, 2016 Author Share Posted August 22, 2016 Posted by kc on 22/08/2016 12:43:42: A wattmeter will save it's cost the first time it saves an ESC! Yup Quote Link to comment Share on other sites More sharing options...
