retract servo movement
Hi all
Whats happening  is when the retracts are down and i switch the Tx then Rx on the retracts try to go up ,if model is on the ground they try but of course they cant/dont , only when i lift model of the ground do they go up then come back down even though switch is not touched  and it's the same the other way round if there up and i switch TX then Rx on they come down then go back up ? is this normal !!
when everything is switched on everything works fine
i am using the dx7 with ar7000 rx with ubec as it's 4cell
rob
Edited By Robert Bromwich on 06/12/2009 22:18:49
