Member postings for Brian Seymour
Here is a list of all the postings Brian Seymour has made in our forums. Click on a thread name to jump to the thread.
Thread: The Warbirds Replicas Macchi C.202 is Landing!
21/02/2017 21:42:05
Cheers Colin, it's better than OK to follow along - I'm glad that folk are interested.
Cheers Richard, sadly this is high employment area and you can't get puppets to help for love nor money - although I haven't tried offering them money.
Glynn has done a sterling job on the 3D printed parts, they look ace and the air filter has come out little over half the weight of the one I used on the first model.
I also got another couple of bits done on the wing despite not having any help from the local puppets. The rear spar webs have been chopped into shape and glued on. Three of the web sections that house the aileron hinges have been laser cut with the holes for the hinge also laser cut, the intention is that the hinge holes line up with hinge holes in the aileron - I'll find out in the next day or so whether it has worked out.
20/02/2017 19:26:38
With the servo bay ribs glued in place and the adhesive thoroughly cured, yesterday saw a sterling rate of progress.
The next stage is to fit the ribs that locate in the false leading edge and glue the flap rail. I was still careful to go with the basics of making sure that the ribs were perpendicular to both the board and the main lower spars. The top jigging spar was dry fitted to ensure alignment and it was left for the glue to cure.
The flap hinge rail was fitted which tied the trailing edges of the ribs up to the aileron into line - not that any were out of line.
Once that was dry the rest of the ribs were fitted along with the bracing for the wing bolts. As there was no reason not to glue the top spar jig, that was also glued on and then the laser cut inter-spar webs were also fitted.
Whilst that little lot was curing the tip end of the top spar was shaped to feather out. The rear spars were fettled to some extent to ensure that they didn't protrude beyond the upper and lower surfaces of the ribs. There are also link spars which go from the root and join the main rear spars with a scarf join which was planed and sanded to make a nice fit.
By the time the spars were prepared the glue for the webs was dry enough to glue the spars in place and glue on the wing tips on.
It was a nice little day's progress, I even got out flying in between stages.
Edited By Brian Seymour on 20/02/2017 19:31:50
19/02/2017 08:59:54
I have got going on the wings, there a bit of prep to do with laminating and sizing spars, laminating the rear retract plate and building up the laminated wing tips.
The main spars are a lamination of spruce and balsa, the spruce for the strength and the balsa to make sanding easier and were laminated using epoxy and clamped flat and straight to set.
The wing is built up on the lower spar arrangement so the spars have to be sanded to thickness to enabled the jigging tabs to work as intended. Both the spruce and balsa strip were marginally thicker than the nominal thickness so when assembled before sanding the jigging tabs did not sit flush on the building board (and my board is dead flat). I made up a bridge to assist sanding the spars to thickness, the bridge is held over sand paper and the spar pushed too and fro under the bridge until there is little resistance. Using 80 grit aluminium oxide paper the spars were quickly sized and then buffed up with wet and dry.
The lower spar arrangement is complicated by the need for a recess for the retract so the retract mounting plate forms a structural link between two spars. To aid assembly and lining up the spars there are upper and lower laser cut rib jigs, the lower one sits upright on top of the lower spars and the ribs are located in notches.
The first proper assembly stage is to glue the ribs either side of the servo bays and fit the servo mounting rails. The the flap servo is mounted between the same ribs that go either side of the retract. This little assembly is a bit of a Chinese puzzle requiring:
  • the spars to be pinned down
  • the retract plate placed on top
  • the lower jigging spar fitted on top of the retract plate
  • the ribs are slid up to stop faces on the jigging spar whist guiding the retract plate into slots into the ribs
  • the flap servo rails fitted into slots in the ribs
  • the ribs set perpendicular to spars and the board
It's a bit tricky but humanly possible and forms an inter locked "strong box" which transfers the load. The aileron servo bay is breeze in comparison requiring the ribs to be located the jigging spar, the aileron servo rails located into slots in the ribs and then the ribs set perpendicular to the spars and board.
To assist the line up the front false leading edge assembly has locating slots so was dry fitted along with the top jigging spar.
That little lot was left pinned and clamped over night to set.
The lower spars, jigging spar and retract plate ready for the ribs to be slid on from either side.
The assembled flap/retract bay.
The assembled aileron servo bay.
Edited By Brian Seymour on 19/02/2017 09:00:32
16/02/2017 22:01:00
Next on the easy jobs list is the tailplane. The tailplane is build up one side at a time on a core plate which also acts to jig the ribs.
The laser cutting capabilities are put to the test with the core plate as it is 4 butt joined pieces to give a cross grain base made from soft balsa with a hard balsa leading edge which is made from two parts the keep the grain as long as possible. First job is to pin down the 4 parts of the core plate butting up to each other and glue the ribs and hinge post onto it: and then run a bead of adhesive down the join lines of the core plate.
Whilst that was drying I repeated the above process for the other tailplane half and butt joined the balsa sheeting.
By the time I had got that little lot done the adhesive on the first tailplane half had cured, so it was released from the board and the ribs etc. were added to the opposite side. The tailplane uses a symetrical section so it's the same view as the above picture except that it isnt' pinned to a building board.
This was a nice little building sequence as the glue dried quickly enough that one tailplane half had dried by the time I had finished assembling the other. Next task involved sanding so I decided it was best to leave the assemblies over night to fully cure.
The hinge post needs a little work with the sanding block to blend it to the shape of ribs. The ribs also benefit from a once over with an abrasive to get tops in-line with each other. The discolouration from the laser cutting provides an excellent guide as to how much has been sanded:
The sheeting isn't too much like hard work to fit and doing both side of the tailplane half at the same time makes sense, it just gets a bit tricky avoiding touching the glue. The sheeting was clamped in place starting from the leading edge at the root, working to the tip clamping every inch and then along the trailing edge back to the root pulling the sheeting tight to the ribs as I progressed. The sheeting over-laps the trailing so that the hinge can be shrouded.
After leaving the halves over night and sanding the leading edges to a nice shape it's all over bar the hinging and finish sanding with the elevator in situ:
It's time to stop procrastinating - next job is the wings, the plan is on the board ready to go.
Edited By Brian Seymour on 16/02/2017 22:04:36
Thread: Kit builders, what would you like???
16/02/2017 20:18:22
I'll go for an early variant electric please.
On the electric vs IC front, I'm going electric because I have a couple of paired sets of flight packs that will be ideal. I can't help thinking that the grass is greener when I see my fellow club flyers blatting twin 2 and 4-strokes (not on the same plane) across the sky with the poetic tune of synchronised engines.
Thread: Who wants a Warbird Replics Hurricane?
15/02/2017 14:20:27
As a friend of Jon's who has got a VQ Hurricane:-
Best use this for reference only as the wing section on the VQ isn't as good as that on the Warbirds Hurricane and the stubby undercarriage legs restrict the prop diameter.
Apart from half an inch here and there the VQ Hurricane 60 is the same size albeit a little heavier. The power setup I use (see below) is more than adequate and, as suggested by Chris, the flight pack is a little oversize to get the benefit from a little more power and duration for the required nose weight.
Flight Pack: 8s3300mAh
Motor: Turnigy SK3 5055 430kv
Prop: APC-E 13x8
Peak Power: 1250w
I know it's a bit OTT, she still flies fine on a 13x6.5 APC-E at 1020w but I enjoy the extra power from time to time. The pack choice came about from using two 4s3300mAh packs that I use in other planes.
14/02/2017 18:02:38
Indeed, it's like an ideal post pub lunch afternoon skive job, nice and easy and there is scope for a little artistic licence with the sanding which is just enough to make it interesting without being a ball-ache.
Apologies for naff picture, here's a better one:
The 3D printed stack is one that I printed so it's very rough compared to the ones that Richard & Glynn print. I won't be fitting the stacks until the painting has been done to save having to keep it masked.
13/02/2017 22:58:10
It looks like it won't take a great deal of effort to build the kit as a 205, the RAAF scheme is cracking with the toned down hoops.
Having laid the Laser 70 drawing over the plan there was a reasonable amount of space for it so shouldn't be too much like hard work to fit.
Having not done any serious building since April last year I decided to ease myself into the build with the simple exhaust fairings.
The exhausts double up as an aid to cooling by channeling fresh air into the front of the motor via the aperture in the front of the fairing and drawing air out from behind the motor through the exhaust stacks. On the already built Macchi the stacks were made from folded litho plate which was quite a nice job but it's fiddly and easy to crack rather than bend so not really practical to kit, on this one they have been drawn up to be 3D printed. 3D printing the exhaust stacks and fairing as one component seemed like a good idea but it involved a lot filament, time and added weight so the fairing was redesigned as a laser cut balsa assembly.
The fairing is little more than a balsa box made from light 1/16" balsa with a 1/4" thick slab at the front which is sanded to shape. I found it best to build them in 3 stages, glue the components shown in the 2nd picture and let the glue grab before adding the other fairing side and leave that little lot to set. The next stage requires a bit of clamping so I left the assembly overnight before adding: the air dam, which ducts air into the front of the motor, and the 1/4" thick top slab, it was clamped up and left overnight before sanding the front to shape.
It all went together just nicely and has come out weighing just 3g so well worth suffering the pleasant building experience.
3D Printed exhaust stacks and fairing in one piece, they came out a bit heavy at 29g each side.
Internal ducting of the fairing, an air damn is fitted at the front of the two upright parts and channels the air to the front of the motor.
The completed and sanded exhaust fairing.
Edited By Brian Seymour on 13/02/2017 23:00:08
12/02/2017 21:47:41
I'm pretty sure that sums up the differences between the 202 and 205. With a bit of luck Vic will chip in on this as I think that he will be making his kit into a 205.
The VQ models are pretty reasonable to fly, I got the Fiat G.59 as my test-bed for the anticipated power and radio setup on the Macchi. She is little over 1/2lb heavier than the Macchi despite having an identical power and radio setup, this drains the flight pack a little more quickly and makes her a bit fussier in loops and the like but is still fun to fly.
12/02/2017 16:10:17
Macchi C.202 Folgore (Lightning)
The Macchi C202 was an Italian designed and built front-line fighter aircraft that predominantly served in the Italian Air Force (Regia Aeronautica) during WWII. Powered by a Daimler-Benz DB601 engine built under licence by Alfa Romeo and denoted RA1000, the C.202 outperformed almost all other fighters powered by the same series of engines including the deadly Bf109E. She was a formidable foe for allied fighters of the time scoring victories against such aircraft as the Spitfire, Hurricane, P40 and P39 and during the defence of Malta only the Spitfire Mk.V’s were encouraged to engage it in combat.
Origins – The Italian Spitfire?
The Macchi C.202 was designed by Schneider Trophy winning designer Mario Castoldi drawing a distinct parallel to the Spitfire which was design by R. J. Mitchell also a Schneider Trophy winning designer. Where Mitchell won three consecutive Schneider Trophies thus putting an end to the competition, Castoldi designed only one winner but to even things out he also designed the Macchi M.C.72 which set the world record for the fastest piston engine seaplane, a record that stands to this day. The C.202 retains its racing heritage with the narrow chord wings, compound curved fuselage and a cockpit fairing that could easily have come straight off a racing plane. In combat the C.202 was a very good match to the Spitfire Mk.V , the C.202 the more capable flyer and Spitfire better armed.
The Model
With CAD design and the impressive abilities of modern laser cutting, recreating the sweet surface profiles and shapes of the Macchi has been considerably simplified. The model uses traditional balsa and ply construction with a handful of vac formed components and, just to stamp modernity on the design, several 3D printed scale details. Precision laser cutting has been taken to extreme lengths to create self-jigging assemblies that be slotted together, aligned and glued. The fuselage is strip-planked to give a rigid lightweight monocoque naturally reproducing the sweet compound curves of original aircraft. All control surfaces have been design to have shrouded hinges which result in a visually and aerodynamically clean airframe. As per the original, the control surfaces have faithfully spaced ribs which show through the covering film.
It is cracking subject to build and fly, the proportions lend themselves almost perfectly to produce a model which flies very nicely and the long snout makes balancing the model a breeze. There is wide a variety of colour schemes and squadron insignia to choose from which are predominantly free-hand painted. Check out these models to see what can be done:- **LINK** **LINK** **LINK**
Model Specs.
  • Scale – 1:7
  • Wingspan – 158cm
  • Power – from 700w to 1000w 50mm dia. Outrunner *
  • Weight – 3.1 to 3.4kg.
  • Functions: -
    • Rudder
    • Elevator
    • Aileron (2 servos)
    • Throttle
    • Flaps (2 servos, reverser required)
    • Undercarriage
    • Undercarriage doors (can be operated by retracts)
* Prototype had a peak power of 800w using: SK3 5045 450kv motor, 80A ESC, 5s4000 flight pack and 16x12 APC-E prop.
The kit is being produced in collaboration with Warbirds Replicas and will soon be available as kit from Warbirds Replicas. It is an evolution of the Macchi C.202 model that I built a couple of years, the design has been updated with quite a few improvements and adaptations to better suit production, simplify construction and make it more robust to handle the stresses of everyday flying. This is a video of one of the early flights: **LINK**, this video shows her taxiing and taking off: **LINK**
These following pictures of the model were kindly taken by Jon Harper at one of the club’s Warbird Wednesday meetings:
This blog will feature the pre-production prototypes that Richard, Vic and myself will be putting together so expect to see Richard and Vic chipping in. You almost all know Richard so needs no introduction. Vic is an expert modeller and self-confessed rivet counter, having seen pictures of his other models, I am really looking forward to seeing his build. Vic is based in one of the most picturesque areas of North Eastern Italy.
Thread: Balsa bashing
22/01/2017 11:27:02
I'll 2nd that, cracking colour scheme too.
23/10/2016 16:18:34
I finally got round to measuring the controls throws:-
  • Rudder - left & right 30mm
  • Elevator - up 20mm, down 16mm
  • Aileron
    • medium rate - up 16mm, down 11mm
    • Low rate - up 11mm, down 6mm
  • Flaps - 60°
She is still great fun to fly and despite a few Rodney moments hasn't needed much hanger time. I have found that when landing with the flaps down it's best not to go for a three pointer as she balloons up and landing on the mains still looks sweet enough. She lands fine without flaps but as she is sleek and streamlined (and I built her a little on lardy side) she doesn't slow up much and I tend to over-shoot.
Taking off from the club's Chinnor strip.
23/09/2016 22:49:31
Top notch, she looks sweet and a half!
29/07/2016 17:47:06
Richard, what can I say.. you've come to the right blokes. I take it that the couple of dozen is the monthly requirement as we'll sweat to hit that volume weekly devil
Top job Guy, cracking colour scheme done sweetly.
14/06/2016 19:25:49
Nice progress on both, Jon - the metal covering looks ace.
Andy, I guess that the recommended electric setup on the Yak is the same as the Spitfire but I used some kit kicking around from an airframe that I sold:-
  • Motor - EMP 5055 580kv
  • ESC - Hobbywing Platinum 100A
  • Flight Pack - 5s4000mAh
  • Prop. - APC-E 13x8
In the meantime I had a couple of exhaust stacks 3d printed (thanks to Richard and Glynn), the finishing process applied has nicely smoothed out the contour lines that 3d printing usually leaves. The contour lines are very faintly visible but I reckoned that it gave them character so painted straight onto them and glued them in:-
She has racked up quite a few flights now and she is still my current favorite, get them flying fellow builders - you're in for a treat!
16/05/2016 22:58:21
The Yak had a nice little outing at the club's Fun Fly-in on Sunday, I didn't use her to compete but a got a few flights with her after the competitions - the warbird fun started when the Fun Fly finished!
Jon took her up so, with a bit of luck, he'll divulge a technical and non-biased appraisal of the way she flies.
In the meantime, my biased appraisal is that she is superb! With 970W she has an abundance of power, easily takes off on 3/4 throttle, doesn't peter out on vertical climbs and W.O.T. fly pasts almost crick my neck. By the time I flew her the breeze had dropped just nicely and there wasn't much in the way turbulent air so she was responsive, stable and predictable. Big loops are a breeze, requiring a bit of right rudder to keep her honest on the way up and barrel rolls are easily executed. As it was pretty calm I didn't get round to landing without flaps but she lands easily with full flap in dead calm conditions, the half flap setting seems to make her balloon up when flaring. Flight time varies from 7mins for full on recreational flying to 10mins when pottering round between tricks.
The CG was set according to the plan and is just about right for me.
05/05/2016 22:03:26
That's sweet how they operate one at a time and they move at nice rate.
The Yak is ready for action, the magnets hold the battery hatch tightly so with the elasticated chord I've got be in with a chance.
To fit the magnets I used a tapered reamer to make a couple of holes through the crutch plate and glued offcuts to the underside of the crutch plate to make the hole a recess. The magnets were glued into the pockets with CA which worked surprisingly well. To mark the position of the magnets in the hatch, the hatch magnets were placed on top of the crutch plate magnets and covered with paint and the hatch fitted, the paint transferred onto the hatch highlighting the exact position. Recesses were cut into the hatch with a scalpel, they came out slightly oversize so a strip of Solartex backing was used to isolate the crutch plate and crutch magnets, the hatch magnets were positioned on top of the Solartex backing, the recesses in the hatch filled with epoxy and then the hatch fitted. Once the epoxy cured the hatch was removed and Solartex backing removed - it came out just right.
Crutch plate with magnets:-
Magnets in the hatch:-
A couple of other pictures from the final stages:-
Air duct in the cowl for motor cooling, made from 1/16" balsa:-
Motor mount with ESC, also the hole through the firewall to draw the hot air our from the cowl:-
Edited By Brian Seymour on 05/05/2016 22:04:08
04/05/2016 19:05:44
Thanks Nigel, I'm glad that this thread has been inspirational. The Lavochkin kit has got some sweet details and has the look of a menacing airborne brute, all the best with the build.
04/05/2016 00:17:37
Thanks Richard & Jonathan - Nostrovia!
She flies sweetly, the maiden was typically (for me) nervy and the landing was somewhat bungled but after a tweak or two on the undercarriage and tightening the motor screws she was ready to go again. Just as I was starting to enjoy the 2nd flight Jonathan kindly pointed out that the battery hatch had popped off, despite flying a few more circuits the hatch didn't pop back on so I swung her round for a landing, she came in sweetly for a nice little landing. I would have lined her up for another run after refitting the battery hatch but the handset started beeping due to a low battery. I'm sure that I could have borrowed the pack out of my Dad's handset but it had been a pleasant evening with my fellow fliers and I decided to call it a day.
I can't wait to send her skywards again, she has been a thoroughly enjoyable winter build and if this evenings performance is anything to go by she will be an even more enjoyable summer flier!
Next job is to fit magnets to retain the battery hatch, my elasticated chord prevented the hatch from blowing away but couldn't hold it firmly shut. She could also do with a set of exhaust stacks, a few wafts of weathering spray and, a few panels smeared on.
Thanks to Richard for producing such a sweet model, to Jonathan for organising our winter build and the rest of our build group for the support, encouragement and, top tips.
My photos don't hold a patch on the action photos that Jonathan kindly took but here they are.
Posing in the pits just before packing away:-
Pilot relieved that both he and the plane made it back to solid ground safely but narked that the handset pack wasn't charged:-
02/05/2016 10:11:21
She really isn't far off now, should ready to take to the skies by the end of the day.
The cables for the rudder have been fitted and setup. The adjusters have been fitted on the servo side in order to keep weight away from the tail, it's a faff to adjust but shouldn't need constant tweaking. I have never had the cables pull through the crimped collars but couldn.t resist bolstering them with blobs of thick CA.
On the nose section, fitting the ESC and ducting to aid motor cooling is underway, nothing clever or ingenious is required as there is plenty of space. I want to duct the air from the chin scoop directly to the motor to ensure that air does actually flow around/through it rather than taking the path of least resistance and going straight through the firewall. The plan for cooling is to take air in from the chin scoop, duct it over the motor and ESC, through the firewall & fuselage and out through the back of the radiator (which has been blocked off) via a hole (or holes) through the root of the wing.
Once that's done there is just the balancing and securing of the rx pack and receiver to do - I've got be in with a shout of a maiden tomorrow.
The washers discussed in previous posts:-
Rudder closed loop (tail wheel needs adjusting straight):-
Closed loop adjusters in the fuselage:-
Planned ESC install although I'll see if routing the motor wires over the top of motor mount is neater :-
Magazine Locator
Find RCM&E!
Latest Forum Posts
Support Our Partners
electricwingman 2017
CML
Cambridge Gliding Club
Gliders Distribution
Slec
Wings & Wheels 2019
Pepe Aircraft
Sarik
Advertise With Us
Latest "For Sale" Ads
 Yes
 No
 Sometimes
 Rarely
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
