Member postings for GrahamWh
Here is a list of all the postings GrahamWh has made in our forums. Click on a thread name to jump to the thread.
Thread: OS 55AX Engine - crankshaft end float
28/09/2014 23:00:51
I have an OS 55AX which has survived a nose dive crash in a Blackhorse Renegade and am near to completing the repairs to the airframe.
The engine has been cleaned out, and turns okay by hand but I have noticed about 1mm of play when I pull and push the prop shaft forward-backward (no sideways movement). Does anyone know if these engines have this amount of end float as I can't remember what it was like before the crash which was several months ago?
Cheers, Graham
Thread: Arising Star
24/09/2014 19:53:42
Worth pointing out. You'd think they'd change the writing on the boxes or at least put a sticker over that part if they've got a few hundred to get through.
Thread: Model needs a name......can you help with a suggestion?
24/09/2014 19:51:15
Magpie. They're black and at least they fly too.
Thread: Advice on a secondhand Flair SE5A
22/09/2014 23:30:07
Thanks for that explanation Jon.
Thread: What did you learn with?
21/09/2014 20:18:35
Old Cosmo King 60" trainer from my brother's loft - with a "Friday" SC 46 2 stroke which kept cutting out! Passed A test on this, but had a few electrics to fly at the same time.
My 10 year old son is learning on a Black Horse Liberty EP, which is excellent - very gentle stall. He'll be doing the A test soon I hope. This really is a good electric trainer, if you want to avoid smokies.
Edited By GrahamWh on 21/09/2014 20:21:28
Edited By GrahamWh on 21/09/2014 20:21:46
Thread: So much for Lipo charging bags!
18/09/2014 23:03:56
I don't feel so bad about not buying those expensive things now - re-used biscuit tin cost nothing.
Thread: 2015 Mass Build - Nominations Thread
18/09/2014 22:56:06
Pietenpol Aircamper - parasol wing is a bit unusual, but would be okay as a trainer and there's plenty of different full size paint jobs to copy for the scale enthusiasts.
15/09/2014 20:28:55
Posted by Jon Harper on 06/08/2014 08:43:45:
I would go for the saito 45 on a 13x5 turnigy type A wooden prop (it must be the type A),
Jon - why the type A? I have been using type C on a puppeteer - should I change?
I really like your idea of using the scale side exhaust Flyeruk, I think I'll try that if I do another SE5a. Bet it sounds great on a Saito!
Edited By GrahamWh on 15/09/2014 20:29:29
Thread: Writing on electric motors
12/09/2014 19:27:11
Freaky -
two Grahams answering the same question
at the same time
with the same answer!
Thread: A invoice for nothing, with a threat.
11/09/2014 22:43:52
You can report them on the online "Action Fraud" website, if you can be bothered. Never click on any attached "invoices" either!
11/09/2014 22:36:47
I think it means 6 turns of wire on the armatures - this effects the kv rating.
Thread: servo/aileron movement
10/09/2014 23:11:17
One possibility is that your receiver voltage is very low causing glitching when the elevator servo is working and drawing current. I may be that the elevator linkage is sticking and forcing a high current drain, momentarily causing the receiver voltage to drop thus effecting the rudder servo. I would check that the elevator linkage is free, (disconnect it and let the elevator servo run freely) and check the receiver battery is charged.
Then if it still happens let us know and with the expertise on the forum someone should able to help.
Apologies - just re-read your post and I see you are using a speed controller and thus have a regulated power supply to the receiver. It is getting late! Could still be a sticking elevator linkage though causing a voltage drop at the receiver.
Edited By GrahamWh on 10/09/2014 23:14:49
Thread: Mosquito
08/09/2014 21:23:22
Thanks Danny, very good.
Thread: Phil finally building the DF
07/09/2014 02:35:52
Thanks for your reply re exhaust Phil. I may end up doing the same on a cirrus moth in the future.
Thread: Sealing iron
07/09/2014 02:33:51
That sounds a really good idea. The iron I use is also losing its coating so I await your findings!
Thread: Not such a good day
06/09/2014 14:21:57
I have never noticed a lipo getting hot while charging. I think you were right to stop charging. I would not trust the pack. If it was just one cell that was bad, I would discharge the pack, open it up and remove the duff cell to make a 3 cell pack for another application..
Edited By GrahamWh on 06/09/2014 14:22:18
Thread: Cessna Grand Caravan
06/09/2014 14:13:54
Thanks Dave, I think that was the one I saw - it was about a year ago. I remember it being from the East. Thank you Cymaz.
06/09/2014 03:00:00
I has searched on th'web but only found a rather small kit somewhere abroad, but does any one know of a plan for a Cessna Grand Caravan, perhaps about 60 inch wingspan?
I am interested in building one with the colours of Blue Sky Aviation (operates in Mongolia). This plane was used to save my wife's life in a medical emergency airlift while we were working out there some years ago.
04/09/2014 21:56:32
If you still have the sock that came with it you could use that. As long as you keep it clean though (cleaning with white spirit when warm - not too hot! or alcohol when cold) it shouldn't stick.
04/09/2014 21:52:23
I really like your exhaust work Phil. How did you attach it to the SC exhaust? I've seen your pic on the first page, but can't quite make out what you did.
Edited By GrahamWh on 04/09/2014 21:53:42
Latest Forum Posts
Support Our Partners
Sussex Model Centre
Slec
CML
electricwingman 2017
Advertise With Us
Sarik
Latest "For Sale" Ads
Q: The effects of Coronavirus
 Yes - for the first time
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
Magazine Locator
Find RCM&E!
