Member postings for Harry Twist
Here is a list of all the postings Harry Twist has made in our forums. Click on a thread name to jump to the thread.
Thread: F86 "Gamma" Build
17/11/2019 11:50:40
Hi Martin, just preparing my fuselage pieces, please can I ask, ref F10, should the upper slot be deepened to 6mm to accommodate the spine or does the spine sit high here? Also ref lower spine, is it recommended to scarf joint two pieces from sheet or curve one piece? Thanks in advance!
15/11/2019 23:33:39
Hi Martin, thankyou for all the recent posts they're very very helpful. My build currently slightly stalled, I'm full of an awful cold!
Thread: Sabre Aerobatic Teams
14/11/2019 09:49:49
Hi Mark, great montage! My version is not from an aerobatic team, but I'm sure the pilot could fly in close formation!
Thread: Dave's F-86 build
12/11/2019 09:32:07
Hi David, I agree with the last two comments, also, go with whatever scheme you want to see the model in. It's your model and your building it!
Regarding time, there's plenty of time available to complete the model, were all feeling our way a little, but as said above, they seem to go together pretty quickly.
Thread: Chris McG F-86 Sabre Dog build blog
11/11/2019 21:08:49
Hi Chris, dont see a reason why you can't prepare your top skins now, but remember to allow more material "width" in the chord dimension to allow for the extra curvature of the top surface over that of the lower surface. Store the skins safely whilst you prepare the lower wing with all the internals and then you can add them later. In fact it's probably a good idea to do it first whilst you don't have the jig sat on the plan!
Thread: F-86A Sabre Montana Air National Guard
11/11/2019 10:17:50
Hi Chris, 48 shear webs, each lovingly cut and trimmed, done over 3 sessions. Aliphatic all the way. Nice progress on your fuselage and thanks for sharing the 10 planking tips!
10/11/2019 23:31:21
Really enjoying reading all the F-86 blogs, it's great that some people have started wing first and others fus first. Bit more progress on wings, false leading edges and hinge blocks added. Main work this weekend however has involved cutting, sizing and fitting the shear webs.
Enjoying the build, thanks again Martin and Gordon
10/11/2019 15:35:55
Hi Phil, I think the lead acids came to one of our model club meets, they were tired out but I saw them as weights! Just a bit of "repurposing" really! I've got 4, they're approx 2lbs each in weight so are quite useful.
Thread: Sabre made in Belgium
10/11/2019 15:29:09
Hi Dirk, great to see your Sabre started. Ref the R1 to R2 step, I glued a piece of waste wing skin sheet over the combined R1A jig root location, took up the space no problem.
Thread: In 1961 The New German Federal Luftwaffe
08/11/2019 14:11:36
Nice start to your Sabre build Mark. The speed brake angle problem creates a little head scratching, the hinge line dynamics need a good coat of looking at. It's almost looks as the base of the hinge line tilts inwards during actuation?
Edited By Harry Twist on 08/11/2019 14:12:35
Thread: Jet Provost 1.5metre Andy Blackburn PSS Plan
07/11/2019 23:37:17
Hi Pete, your JP's looking superb now, the decals and panel lines set the scheme off really well!
Thread: Avon Sabre Spirit 78
05/11/2019 22:46:08
Looking tidy that Steve, nice choice of scheme also. Your intro has got me wanting to read up on the Avon Sabre - didn't realise fitment involved fuselage mods!
Thread: An Introduction to the PSSA 2020 Mass Build Project
05/11/2019 22:37:53
Hi David, I'm sure others will pitch in here - but the short answer is - new year would not be too late, and of course you would be welcome to join in, at any time that works best for you. So I would definitely say - join in when you can and enjoy the build.
In addition it sounds like you have a close family connection to the F-86, so that's a great reason in itself to build one!
Edited By Harry Twist on 05/11/2019 22:39:30
05/11/2019 22:13:48
Hi All, Over the last couple of nights I have pushed the wings on a little more. Both lower skins now made, with centre spars and false TE's added - and whilst drying I sat them, with weights on, in the wing jig to "train" the balsa to the anticipated curve. Each rib was them trimmed to the correct angle for the top and bottom spars and the false TE, simple angle jigs helped this. The wing jig was then relocacted into position over the plan on the building board and although square, it was lifting a little in places - so the solution involved a few moulding pins and a small hammer and then gently nailing it to the building board!
With the wing skin sat in the jig I did notice that there was a gap between the underside of the wing skin and R1 - whereas all the other ribs sat neatly. To force the skin down onto R1 would have created a largish step form R1 to R2. So to remove this step/gap I glued a piece of scrap wing sheet balsa over the top of the twin R1 centre braces in the jig - this took up the gap and the wing sits much better now at the root.
Next stage was to locate the ribs in their final position and glue them. (the false TE was located prior to any ribs going in). To keep the skin "in the seat" I sat weights between each rib as I glued, and finally placed a piece of waste spruce in the slot on the top of the ribs and weighted down on this.
So as of tonight - I have located all the ribs on the right wing apart from R1. As an additional aid to keeping the rib leading edges located on the sheet I wedged a piece of 1" triangle below the front of the sheet.
Photos....offer better explanations than my words!
Additional strip over R1 area- indicated by blue pen
Weighted between ribs
Right wing ribs glued in situ
Rib leading edge trimming jig
Edited By Harry Twist on 05/11/2019 22:17:00
Thread: Phil Beard's F-86 Sabre Build Blog
05/11/2019 21:07:46
Hi Phil, looking good, I like the use of sockets as masses!
03/11/2019 23:54:02
Hi All, got a little more done over the weekend. Once dried, the wing jig was carefully removed from the plan and stored. Right and left lower wing sheets were then made up. Careful cutting gets one wing panel from 2 x 3"x 36" lengths. These were joined by the "tape on the back, fold along the tape line, glue in the fold, then unfold, wiping any excess away and adding weights to the new panel whilst drying" method. Once the panel was dry the rib and spar locations were added and the lower spruce spar cut and glued in location. Finally, I looked at a method for adjusting the spar slots in the ribs to get the correct spar/rib angle at the base. A simple jig to hold the rib made from scrap balsa and two clothes pegs helped! Photos below...
Edited By Harry Twist on 03/11/2019 23:57:11
02/11/2019 21:44:33
Hi Martin, thanks for your reply. Sorted the wing skin I think! Careful measuring and cutting gets a lower wing skin for one side from 2 x 3" x 36 " sheets. Thanks
Edited By Harry Twist on 02/11/2019 21:46:16
02/11/2019 00:14:14
Off we go! Its Nov 1st, so, being a miser I've turned over my piece of plasterboard building board and rescrewed it down on the other (clean!) side. I've then spent a little time making a start on the F-86. I started by fettling the wing jig sub pieces, just minor trimming needed. Then I cut up the wing plan sheet and then added extended lines for the ribs and wing spars. Once done I assembled the wing jig sub pieces and then finally assembled the wing jig, on the covered plan, carefully ensuring it all sat square and flat on the bench. I did add some triangular support as suggested by Martin in his gamma build.
Couple of shots...
01/11/2019 21:42:15
Hi Martin, pls could you advise, I'm trying to get my head around preparing the lower wing skins. Is it 2 X 3" wide sheets step jointed/ optimised to cover the main area, plus a little bit more thickness added at the wing root area to get full chord depth? Plus is the wing sheet joint roughly parallel to the main spar? Thanks in advance.
29/10/2019 22:23:38
Hi All, Firstly - thankyou to Martin Gay and Gordon Studley for the planning, design, production and general "effort" that has led to us obtaining our F-86 PSS kits. Also many thanks to Phil Cooke for his detailed work in supporting and promoting this mass build 2020 project.
I've decided to attempt the scheme shown below for my F-86. Its a USAF F-86A of the Montana ANG, target tug, circa 1955 at Nellis AFB.
Profile view:
Model kit (not by me!)
Edited By Harry Twist on 29/10/2019 22:25:31
Latest Forum Posts
Support Our Partners
electricwingman 2017
CML
Sussex Model Centre
Slec
Sarik
Advertise With Us
Latest "For Sale" Ads
Q: The effects of Coronavirus
 Yes - for the first time
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
Magazine Locator
Find RCM&E!
