Member postings for rcaddict
Here is a list of all the postings rcaddict has made in our forums. Click on a thread name to jump to the thread.
Thread: Same motor with different kv
07/12/2018 09:47:03
what is the point of having the same motor with different kv - eg the turnigy g46 easymatch has 3 models 420kv, 550kv and 670kv. i dont see the point as surely you would pick the highest kv so you can use the smallest prop - or am i missing something
Edited By oldgit on 07/12/2018 10:14:42
Thread: e-gangster CoG issue
06/12/2018 14:20:58
yes thrust line was the same - or not far off
06/12/2018 13:07:12
just had a prang with an old gangster 52 that i converted, i suspect the the Cog was too far forward as when i throttled back to land it kind of dived into the ground (all repaired now) also elevator was sluggish requiring a lot of input - does this sound like Cog issue to you guys?
Thread: turnigy G46 bearings
28/11/2018 15:50:07
bearings ordered from simply bearings - thanks guys
28/11/2018 14:41:04
hi dave - yeah defo rear bearing
28/11/2018 08:20:05
i dont suppose anyone knows the size of bearings for this HK electric motor
Thread: Building board
24/11/2018 17:49:14
plasterboard works for me
Thread: gangster 52 cog?
24/11/2018 14:40:22
picked an old gangster 52 which Im converting to leccy, anyone know the correct COG, search could'nt find anything
Thread: laser cutter
01/11/2018 21:44:44
Mmmm - quite fancy a diy laser cutter - how does it work do yoy prepare drawing on autocad then export file to suit the cutter (like you do with a 3D printer)
Thread: Flying in Cumbria
13/10/2018 17:37:05
percy
what are you talking about i had several breaks to the lakes in may, june & july and didnt see a drop of rain !!!
cheeky
13/10/2018 17:09:39
thanks for info - will load up with wot 4, teksumo and a seamaster (have flown from ullswater before)
and Im from scotland so know all about weather !!
13/10/2018 14:53:25
hi guys - off on a short break to Keswick and Penrith areas next week, is there anywhere I can pull the Motorhome over for a quick flight
Thread: HK postage charges
01/06/2018 18:25:27
flight1 - i think its 50 dollars not £££ - a good deal
Thread: bullet connectors
30/05/2018 19:48:05
if using bullet connectors between lipo and esc what is the normal - ie should the positive wire on the esc be male bullet ??????
Thread: acetate help please
01/05/2018 08:36:21
thanks guys now ordered - found out that a micron is a millionth of a metre !!!
30/04/2018 15:23:48
i need an a4 sheet of clear acetate to repair my precedent T180 front curved windscreen. i ordered a sheet at 0.1mm from ebay but its much to thin - question is what thickness/weight should I be ordering
Thread: 5v or 6v servos
10/04/2018 10:43:50
I have 6v mini digital servos in my teksumo wing but Im just thinking this is wrong cause the bec is 5v ( i think ), any thoughts? should it be the 5v servo version, it all works fine though
edit   -  just looked again at spec - it says voltage 4.8 - 6v
Edited By oldgit on 10/04/2018 10:47:01
Thread: Flyaway model, what would you do?
05/04/2018 18:31:24
RAF Search and Rescue - I've heard it all now !!!
Thread: WMWF Ullswater March 2018
02/04/2018 11:27:42
percy
found this
**LINK**
and this
https://www.lakelandboathire.co.uk/our-boats
i certainly seen powered craft when i was there
Edited By oldgit on 02/04/2018 11:32:30
02/04/2018 10:16:17
I dont think speed boats are banned, its just that there is speed restriction,
Latest Forum Posts
Support Our Partners
Sussex Model Centre
CML
Slec
electricwingman 2017
Sarik
Advertise With Us
Latest "For Sale" Ads
Q: The effects of Coronavirus
 Yes - for the first time
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
Magazine Locator
Find RCM&E!
