Here is a list of all the postings Mark Elen has made in our forums. Click on a thread name to jump to the thread.
Thread: Mark’s Peggy Sue 2 Build |
14/10/2019 19:40:06 |
Thanks Nigel, Still some work to do on the cowl, but it is coming along. I had some time off work today, so got started on the wing. First job was to trace out so that I could build the other half: The lines are much easier to see than the photo shows. Then I got on with making the hold down plates: Finally, I made up the patterns for making the ribs. I like the ‘sandwich’ method: Cheers Mark |
13/10/2019 23:06:16 |
A little more done. Got the rudder and elevator servos in and the snake inners made up onto ball joints. Now starting one of my least favourite jobs, shaping the cowling: Cheers Mark |
Thread: Design & Build Sport Twin |
13/10/2019 18:03:59 |
Hi Nigel, That looks beautiful mate. Well done. Don’t start thinking about the ‘dark side’ as Bob alludes to 😂😂😂 Cheers Mark |
13/10/2019 11:25:03 |
Bit more done, but I went off on a tangent. I got fed up with cutting myself on the hole cutting tool. Up till now, it has had a piece of electrical tape wrapped around it, so I set up a piece of Ali bar in the lathe and using my homemade knurling tool, set to work making some small handles: They are just stuck on with loctite retaining compound. I still need to make up a 9mm and a 13mm, and the tops still need facing off. They will all get done together once I change the Chuck back over to the collet chuck. I made them long, so that they will fit in the collet chuck to resharpen if needed. Cheers Mark |
10/10/2019 21:13:38 |
A bit more done over the last couple of days. I've got the snake outer holder pieces made up. It has taken 3 iterations to get the snakes somewhere near straight: Not finished yet, but getting there. Cheers Mark
07/10/2019 18:43:11 |
Hi Peter, I had a couple of failures with that. Now in the scrap box for future use. Bit more done today: Seem to have spent a lot of time for not a lot of progress. Cheers Mark
Thread: BMFA 'B' Test Video Available |
07/10/2019 12:28:18 |
Its here: Cheers Mark |
06/10/2019 16:02:39 |
Bit more done last night and today. I made a start on the cowl: There are lots of compound angles on the side pieces. One of these makes getting them close easier: As you can see, this gets used an awful lot. There are not many pieces of the build that doesn't see this at some point or other. The side pieces are close, but not perfect. After about half an hour of fettling each, they are near enough. I then proceeded to drill out all of the holes needed for fuel tank fill, exhaust pressure, crank vent, needle valve and low end needle. I used my trusty cutting tool that I made ages ago. Its much easier to do these whilst they are not attached to the airframe: They are now in and glue drying: Cheers Mark
05/10/2019 19:10:15 |
Hi Peter, I don’t like using the starter on my Ballerina, I’m always careful that it’s not flooded, but, normally, it needs the starter to drag some fuel through. Bit more done today. Throttle linkage made up, so now I can get on with the cowling. Cheers Mark |
04/10/2019 21:51:24 |
Hi Gents, Nigel, your welcome mate 😂 Still a bit to do on the linkage. I like a dead straight run, so I will open out both formers at the ends to allow the snap link through, with just the centre former holding the rod in place. Photos to folllow. Peter, I had my concerns about the tank position on the Ballerina, but, having flown it , the Saito doesn’t seem too concerned about the tank being a little high. I thought that I would have a lot of trouble with it flooding after the first tank of the day, but having used it, it seems to only need the starter for the first fire up, (not being able to prime it as the carb is inaccessible) once it has been run once, it will flick start every time after. Cheers Mark
04/10/2019 19:42:19 |
Hi Paul, Many thanks for your kind comments. Yes, I have gone for an inverted engine. The set up is exactly the same as my Ballerina, and, exactly the same as the plan. Tank in centre of engine mount, it is a little higher than the centre line of the carb, with the engine inverted, but I have had no problems with the Ballerina. If this engine is anything like the one in the Ballerina, it’s just going to want to run and run. Normally, the Ballerina engine will start first flick, every now and then it gets to see the starter😂 I’m considering putting a remote glow on this, but I have had no real issue on the Ballerina, the Saito plug is angled rearwards at about 45 degrees, so, as long as you are careful, your fingers are never too close to the prop at start up. Cheers Mark |
Thread: Fouga magister 1/4.5 moulded from scratch |
04/10/2019 18:43:38 |
Some people take our hobby to another level. You, Sir, are one of those. Beautiful work. Cheers Mark |
Thread: C No Ohmen |
04/10/2019 16:46:24 |
Is this the stuff you are looking for Piers? Toolbox anti slip mat. Cheers Mark |
04/10/2019 16:25:45 |
I Thanks Peter. I do try hard to keep it neat and tidy. I have had the afternoon off work today, so lots done. Starting with a trip to my LMS (Gliders at Newark) for some Superphatic. - they didn’t have any, but I spotted this: I have a bit of a fetish for tools..... What a great bit of kit. I can see it’s going to be the ‘go to tool’ for engines and servos. I did some testing with it this afternoon:
Then I got set up to start building the cowl: I was just about to start, then realised I still needed to make up and drill for the throttle linkage. I made this mistake on the Ballerina, it’s much easier to sort out without the cowl in the way. That’s it for now.... it’s beer o’clock. 😎 Cheers Mark |
03/10/2019 22:37:04 |
Hi Nigel, I have been watching your build with great interest. Beautiful neat and precise build. I will be interested to see how you get on with the set up/flying as I have plans for a Grumman Cougar that is getting further up my build list. Keep up the good work Cheers Mark |
03/10/2019 22:29:13 |
Hi Nigel, Many thanks for your kind comments. Been out and done a little bit more. I had a bit of scrap light ply that was just the right size for the nose ring, so I got it marked out and ready for routing the hole. I had made up a spacer tool when I built the Ballerina, so I cut out the hole 35mm to fit the spacer tool. This follows Peter's cowl build sequence, it works really well and gives a great finish: The inner hole of the spacer is a snug fit on the engine prop driver. Cheers Mark
Edited By Mark Elen on 03/10/2019 22:47:25 |
03/10/2019 21:40:10 |
A little bit more done tonight. Port stringers sanded down, then Fin glued into place. I used a couple of spare engine bearers to hold the fin straight. Glued in with normal Aliphatic, so I'm going to leave it overnight to go off before I move it about too much. Cheers Mark |
02/10/2019 21:14:14 |
Hi Peter, Many thanks for your kind comments. I have done a little more tonight, just pottering about with it. Sanded down the Starboard Stringers to rough finish: Then sanded the fin to rough finish. I spent a little time sanding a vee into the rear to match both sides, but I went a little too far, so added a couple of little filler pieces. The fin sits nicely on the 1/8 filler piece above the vertical stab slot. I really need to clear the bench and get on with repairing the Ballerina, after my mishap with the hedge a couple of weeks ago, but I'm enjoying building this too much. Cheers Mark
01/10/2019 21:13:21 |
Hi Peter, Yes, anything that makes things easier is good in my book. Bit more done tonight, starting with sanding down the filler block and filing out a slot for the top stringer. The photo below shows me using masking tape to protect the wing seat from the sanding bar. It leaves a very small step, that is sanded down very gently once the tape is removed. Stringer installed: And sanded down to blend in: Then blank made up for vertical stabiliser. I like to add a small piece of cross grain at the top to help stop it from warping: Cheers Mark
30/09/2019 21:32:52 |
Hi Peter, It is a bit OTT, but the mill was sat doing nothing, so it got used. I have got a few ‘bits’ done the last couple of days. I got the wing seat sanded to final finish, F2 was a little short, so I put a 45 degree onto a piece of 1/8 light ply, then cut and fitted it. I also made up a couple of tiny fairing pieces to blend the rear sides in at the top: And made a start on the filler piece at the rear of the wing seat: Cheers Mark |
