Member postings for Braddock, VC
Here is a list of all the postings Braddock, VC has made in our forums. Click on a thread name to jump to the thread.
Thread: Blackhorse Hurricane 46
21/04/2019 14:31:10
Still haven't got the hang of idle down and throttle cut on the futaba 14sg, had to abort after setting it up, as I thought, last night.
I'll have a read of my kindle book and see if I can get on top of it.
Apart from that, the systems test went ok, engine started and ran a tank of fuel through, didn't really want to but I had no way of stopping the little devil blush.
21/04/2019 08:56:53
Thanks, Chris. Just charging up a new set of LiFes and then it's all systems da di da di da. Probably I'll bottle out.
21/04/2019 00:32:38
Taking mine up to maiden it tomorrow, 5 months between completion of build and first wind beneath its wings.
Thread: RCM&E May 2019 issue chat
11/04/2019 12:35:48
My planes generally don't get that old embarrassedcrying 2
Edited By Braddock, VC on 11/04/2019 12:36:03
11/04/2019 10:57:03
Lovely!
With my scythe and black cloak, what caused their passing?
Edited By Braddock, VC on 11/04/2019 10:57:27
10/04/2019 10:19:51
Posted by Dwain Dibley. on 10/04/2019 00:04:04:
That's the Australian version...cheekylaugh
D.d.
Dwain, in some offices it's a prerequisite to be able to read upside-down.....wink
10/04/2019 00:01:16
There's an article by tim hooper re the skystreak 26, he can't attribute the design. perhaps the attached photo will help.
My plan was obtained from www.model-plans.co.uk, sized up so so it's now a skystreak 48 powered by an OS 40 Surpass and with a pair of electric retracts installed in the wing. A second wing is to be made incorporating air brakes as per chris foss's wot4 as it's hard to slow the plane down. I used the flat top of the wing as per the article but in honesty it needs just a smidgen more. Also an extra bay at the aft end of the fuselage is a good idea, to extend the moment arm as otherwise it'll get twitchy, it's probably why the original c of g is where it's at, to stabilise it a bit.
It's also probably why mine has been rekitted.
BTW model-plans.co.uk is the baby of Derick Scott Plans Service and mine, including blowing up to 1.2X was £12. It's advertised in SAM35 Speaks.
Thread: Engine for largish cw Cub
03/04/2019 20:53:16
Hi Paul, I think it is.
I think yours would be far too powerful for me, I'm getting too old to fly hotrods.
02/04/2019 16:55:45
Thanks.
02/04/2019 16:50:22
I have an 80ish wingspan clipped wing Cub that weighs 7 lb ish. Currently powered by an old laser 100 that gives it about a 5 yard take off run.
The box says it suits a 90 -120 4 stroke, model dates back to the early 90s at least.
I'd like to fit a laser 80 that has very few hours on it will this be adequate do you think?
Thread: Banded on undercarriage
02/04/2019 10:22:03
Fit torsion bar u/c, I did on the thread "Undercarriage Upgrade" on this site on a BH Blade and have never looked back, at least a couple of dozen landings including two into very long grass and the u/c is still there.
If you prepare your work and have all the parts to hand it shouldn't take much longer than fitting dowels or alloy plate u/c and will be much more fit for purpose.
Thread: Vintage airframe coverings.
01/04/2019 19:52:57
Heat shrink film is fine, it was developed in the usa before ww2 so meets any vintage requirement by many years.
It's your model and should you choose to use film and one of the vintage police criticises you, advise them to remove themselves in short, jerky movements.
Keep in mind that brushless motors and lipo batteries don't have the same history.
If you can get it, fibafilm is a fantastic material to cover with as is coverite's (unfortunately discontinued)micafilm. Both really strong and very light compared to the tex coverings.
Impex HT 1780 adhesive is better than balsaloc as a heat activated glue for fixing the covering.
Just my 2ps worth.
Thread: Forum members' new models: Let's see them.
28/03/2019 17:59:45
It has quite a long moment arm, perhaps that's why. It does seem to have inertia in turns with respect to the reaction to rudder input, which I initially put down to the fairly small size of rudder then, because I cheat and put an aileron/rudder mix on, found that the total throw was automatically shared between the rudder and aileron sticks. Hence if I want to get a faster response both rudder and aileron sticks are shoved over.
I've flown it about 10 times now, on a day like today with virtually no wind, a 1/4 of a tank lasts about 15 minutes (it's an 8 ounce tank btw) on the other occasions when I've flown it's been quite windy and 15 minutes can take about 2/3 of a tank because of increased throttle to keep her moving into the wind.
28/03/2019 16:58:34
img_0117 (1).jpgI wish I could say I built this model, I didn't though but it's a beautiful slow flyer and lands like it's on rails, thanks Barrie.
It's a design from 1939 called the "thermal Magnet" I fitted an OS 40 FS , one of the originals, that I bought in the early 80s in the last century. I fitted an orange faast (futaba) rx which has a 3 axis gyro. It's fitted with a 12x4 wooden prop and drinks 15% liquid gold, very slowly.
It's really peculiar when the gyro is on, really squirrels when one tries to intercede but it's fun and very satisfying to fly slowly.
A buzzard spent some time with it in a small thermal and that was an unusual event in itself.
I spent quite some time with it in the air and now I have to order some more wing bands before the ones I have let go.
Edited By Braddock, VC on 28/03/2019 17:06:07
Thread: Undercarriage Upgrade.
21/03/2019 16:36:34
Half a dozen more landings plus several touch and goes, got to be a vast improvement.
19/03/2019 16:18:23
Flew the plane today, success, several landings and only bent a bit yes. Time to cover it now.
Thread: OS 120 strip down problem
19/03/2019 12:03:23
Have you removed the almost invisible wire circlip that retains the gudgeon pin?
Thread: Gone,but not forgotten kit mfg
16/03/2019 19:48:31
In view of the resurgence of the Scots in the Calcutta Cup, I dedicate this old ad.
Thread: Six Nations 2019
10/03/2019 20:29:45
Posted by Peter Jenkins on 10/03/2019 18:21:48:
One mustn't forget that Scotland have a great track record of upsetting England - you only have to look at last year. Never write Scotland off when playing against England I say.
Not at HQ they don't.
Thread: If you only had one engine to use, which one would it be.
10/03/2019 15:40:12
Posted by J D 8 on 10/03/2019 15:00:47:
Irvine 46, been in my go to hack for some twenty years and still going strong.Irvine 46
I like the old jupiter, I've got a part kit of it in my loft, missing the fittings regrettably but I'll get them some day.
Magazine Locator
Find RCM&E!
Support Our Partners
Cambridge Gliding Club
Slec
CADMA
CML
electricwingman 2017
Wings & Wheels 2019
Sussex Model Centre
Sarik
Advertise With Us
Latest "For Sale" Ads
 Yes
 No
 Sometimes
 Rarely
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
