Member postings for Mike Rolls
Here is a list of all the postings Mike Rolls has made in our forums. Click on a thread name to jump to the thread.
Thread: electric glider question
16/02/2007 07:56:00
Dave
Protech do a 2m - the Omega. Unlike the Alpha, whihc I like - and was the reason for me buying an Omega - this one I don't like.
With the supplied power train (identical to the smaller, lighter Alpha) it is horribly underpowered.
The aileron horns are so placed that one or other of them touches the ground as the model slows on landing - grass sites are murder on the horn and/or the servo gears. (Actually it has so much dihedral that ailerons are totally unnecessary and pretty ineffective unless used in coordiantion with rudder.
The T tail mounting is very weak - rapid deceleration on a grass landing sees the tailplane sheer off from the top of the fin (the grain on the fin runs the wrong way).
Mike
Thread: petitition against pay per mile please sign it effects you all
12/02/2007 20:47:00
I have just tried, yet again, to sign up to this petition. It said I had been sent a confirmatory E-mail - I hadn't.
Could something be stinking just a little bit? Four attempts to sign up without success - I wonder how many signatures haven't made it to the list in the same way as mine?
Mike
12/02/2007 11:38:00
Interesting to see that with the signatures over the one million mark the site can not, as I write, cope and advises people to try and sign up 'later'. I've tried three times to sign up over the last two weeks and each time the site has been too busy. I wonder how many other people have tried unsuccessfully?
On the actual principles involved - please do not run away with theide that this will be good news for anyone except a very few fortunates individuals.
It's just anothe excuse to:
a. Squeeze more money out of the motorist
b. Provide an excuse for allowing our road system to continue to deteriorate
c. Provide an excuse to do nothing about our woeful and very expensive public transport systme (looking at the systme for the country as a whole, not just a few fortunate city locations)
Mike
Thread: Diesel or glow?
09/02/2007 05:56:00
Peter
Wasn't mine - mine all were shown propless. All the best
Mike
Thread: mustang in RAF markings
08/02/2007 17:53:00
Don't forget that the -D was the Mk IV in RAF service - might be another useful filter
Mike
07/02/2007 17:54:00
Mike
I didn't mention David because, like you, I haven't heard of anything from him for quite awhile. Exquisite little engines.
Mike
07/02/2007 17:52:00
Anthiny
Have you tried simply putting Mustang RAF into Google? There are hundreds of schemes 'out there' and that will bring up thigs for you to make your own choice
HTH
Mike
07/02/2007 05:14:00
The advanatge of diesels for 'low-tech' F/F models such as the Ebeneezer is that they are far more controllable than glow motors. Because of that they can also swing a substantially bigger prop if wanted.
PAW are just about the only UK maker of diesels left. Their smallest is a 0.55cc - absolute little gem. However, their motors have benefitted from decades of development and tend to more powerful, for their size, than the motors of earlier years. Do't make the mistake of assuming that the 0.55 is the equivalent of motrs of the same size from the 'old days' such as the ED Baby or Frog 50 - it is actullay a lot more powerful. Similarly, the PAW 80 (0.8cc) and 100 (1.0 cc) are a lot more powerful than motors such as the Mills 75 or Allbon Merlin - same size as the 80 - or the ED Bee or Allbon Spitfire - same size as the 100.
Unless they have been badly mistreated, small diesels used for F/F last virtually for ever. I still have an ED Bee dating from 1949 which works fine; I recently sold a couple of Mills 75s of similar age and stillin first class runnnig condition.
HTH
Mike
Thread: Which Lipo Charger?
06/02/2007 06:23:00
I also have a Chameleon and am very pleased with it - although 'quirky' is a bit of an understatement regarding the manual whihc left me totally cross-eyed after reading it. Fortunately the manula includes a 'user's algorithm' diagram whihch is much easier to understand.
You don't have to go to the expense of the Chameleon though - for whatit costs, and provided you don't intend to use packs bigger than 4S you can get two perfectly good chargers - I have two Graupner Ultramat 10s which only cost 54 each, and although they are now out of production Graupner have a similar specced replacement and there are of course other makes.
Two chargers make sense - Li-pos take a lot longer to charge than Ni-Cads or Ni-Mh cells. A full charge typically takes 80-90 minutes, even more if charging through a balancer, and leaving Li-pos to charge unattended is a defintie no-no, so can be a pretty boring and lenghty process if you have several packs to charge.
HTH
Mike
05/02/2007 19:33:00
Forgot to say that the 20 minute run would be using the same size prop - or a tad bigger than - as the original. For maximum rate of climbe use a 10x6 folder which roughly trebles rate of climb at the cost of reducing motor run to around 10-12 minutes
Mike
03/02/2007 11:13:00
The Protech Alpha V is a good starter. 72" span one piece wing so easy to transport in any reasonable size car.
Comes with generic 540 motor and 35A speed controller. 7 cells maximum with that set up and the supplied prop. Climb out is gentle.
Performance can be improved slightly by substituting a Graupner 8x4.5 folding prop. Can be improved a lot by replacing the motor (after you have gained experience) with a 600 size brushless such as the Tornado 3630/1000 or Jeti 30/3 and suitable ESC. The battery compartment will take an E-tek 3400 3s lipo for even greater performance.
The standard set-up gives a motor run of around 7 minutes - the brushlee/li-po upgrade gives around 20 minutes climb time and double th eclimb rate
HTH
Mike
Thread: Errors in plans
02/02/2007 05:30:00
Mike
Windy Ain't It - brings back memories. One of the regulars at Hounslow Heath used tofly one with an ED 246 up front in the mid 50s. Can't remember if it was F/F or single channel R/C (not that there was much difference in many cases!)but do remember he had painted it a really grotty sort of 'dirty red' all over - still, it was beautiful in his eyes!
Mike
Thread: Building from plans
02/02/2007 05:20:00
Dependent on how many ribs you need, if they are the same size (parallel chord) then it is worthwhile making a template in ply to cut round. Also worth keeping the template in case of accidents - repairing will be simplified.
Mike
Thread: How Many flyable planes do you have ?
29/01/2007 07:09:00
Not enough!
Currently:
Electric
5xown design aerobats
1x ARTF (Pelikan Dingo)
1 shockie
1 plan built - Tigershark
IC
SAS Starjet
KK Phantom
APS Lucky Lady
Gliders
Middle Phase
Protech Alpha and Omega (electric gliders)
Plus about 7 or 8 needing some form of TLC before being used.
Mike
Thread: Covering techniques
28/01/2007 04:49:00
I've never known Prymol cause Solarflm to wrinkle. I apply it with a wad of kitchen paper - don't like cotton wool as you can get bits of it coming off as you use it - and also a fine brush for small areas. Perhaps you are applying too much? You only need to smear it lightly over the surface
HTH
Mike
Latest Forum Posts
Support Our Partners
electricwingman 2017
Sussex Model Centre
Slec
CML
Advertise With Us
Sarik
Latest "For Sale" Ads
Q: The effects of Coronavirus
 Yes - for the first time
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
Magazine Locator
Find RCM&E!
