Member postings for Tomas Dunker
Here is a list of all the postings Tomas Dunker has made in our forums. Click on a thread name to jump to the thread.
Thread: Convert Black Diamond
22/03/2015 10:50:41
Test assembly:
What about dihedral braces in the wing center? Needed them or not? Do you have any suggestions?
Edited By Tomas Dunker on 22/03/2015 10:54:13
20/03/2015 08:19:34
black_diamond_04_1k4px.jpgThere were some trix to fit the ribs front angle to the false leading edge. You have to think in three dimensions, not a single 90 degree angle. I took a sanding block and used the plan as a guideline.
03/03/2015 13:01:49
Time passes and sometimes becomes a project put aside because others (Atom, Kwirl, Backyard Canard and NotForSale) come in between.
But now I'm back to the drawing at Black Diamond.
I have got the powertrain and thinking about how I will construct the engine nacelles?
This project can take its time...
Edited By Tomas Dunker on 03/03/2015 13:05:46
Edited By Tomas Dunker on 03/03/2015 13:08:03
Thread: Completed Atom photo gallery
16/01/2015 13:01:21
Thread: The Atom Special
15/01/2015 21:37:58
Rx and ESC outside provides plenty of space for battery (LiPo)
11/01/2015 16:47:55
Does anyone know if there is an autogyro that works with RealFlight 7?
28/11/2014 20:30:09
Posted by Max Z on 28/11/2014 16:32:35:
Hey Tomas, fitting a gyro to an autogyro? That's cheating!wink 2
Just kidding, but I am not sure it will work. Nice Atom!
Max.
It's the Rx to get the CoG right.
28/11/2014 08:16:49
Posted by Richard Harris on 27/11/2014 18:22:26
I have added the country that I believe each Atom builder is from.
Rich
Edited By Tomas Dunker on 28/11/2014 08:26:10
23/11/2014 14:39:09
The training wing seems to be something for me.
Has anyone tried to fly with it? What are the dimensions?
Placement in the model length direction?
Can this fit to Atom?>
http://www.rcgroups.com/forums/showatt.php?attachmentid=7215533&d=1414028291
13/11/2014 09:03:19
Steve mention the blades root angle. What is its funtion and how many degrees should the angle be?
27/10/2014 06:54:21
My way to sand the rotor blades. I made a "jig" and a very long sanding block.
I'm too bad in English for explaining so the pictures speak for themselves...
Edited By Tomas Dunker on 27/10/2014 06:58:13
10/10/2014 03:45:14
I'm not so good at English, what is meant by ROG?
07/10/2014 07:21:51
Does anyone have a picture of how the wires from the motor is pass through F1 / F2?
08/09/2014 17:55:06
Have you tried out what size of engine and propeller that is best suited to Atom?
I have a AbovAll 2813-18 with the data below, what do you think of it?
55 gram, diam 28 mm,
length 30 mm
kV 1200, max 25 A,
Prop: 2s (LiPo) 10x4-11x4, 3s 8x8-10x5
05/09/2014 11:06:40
In your hardware list you suggests to have a 30 amp ESC for Turnigy SK3 - 2826-980kv Brushless Outrunner with a maximum current of 10 amps!
Is there any particular reason you have oversized the ESC? It might be enough with 15 amp ESC?
02/09/2014 10:32:56
Two questions about blades for Atom:
#1. Have you no reinforcement of the rotorblades (AJ) for attachment into rotorhead?
#2. Can I instead of AJ blades use HobbyKing blades PRODUCT ID: 310000104?
/ Tomas D.
23/08/2014 17:41:19
As the ribs in the wing center section is mounted inclined, I made a tool to sharpen the angle.
20/08/2014 15:02:53
black_diamond_01_1k2px.jpgDivided plan. Easier to scan the ribs for printing and making templates
The very first ribs made!
18/08/2014 18:50:18
Thanks Trevor for your feedback.
To fit the battery (LiPo) in the body and get the CG right, I will build the wing completely finished with the motor (2), ESC (2), servos (4) and Rx. see
**LINK**
Then it will be easier to get CG right. The body I have to probably lengthen and make a little wider.
PS I'm not so good at English but I hope you understand what I mean?
Edited By Tomas Dunker on 18/08/2014 18:53:46
18/08/2014 16:04:02
In RCM & E (Aug 2014), I read in Column Fly Electric by Nigel Hawes about Slope Soarer Black Diamond. I became curious and bought the plan on the model (RCM & E plan service ref. No. RC1661).
What made me most curious was that "Black Diamond begging to be converted to electric power."
- Is there anyone who has built and been flying the model? I've thought about doing it with twin motors and one (1) landing wheel under the body and two small support wheels under each wing tip (see sketch).
The model having no rudder, instead Diffrential thrust mix into the motors. Works very well on my latest project. See **LINK**
- Would be nice to hear what you think and feel.
Black Diamond Twin Sketch
Edited By Tomas Dunker on 18/08/2014 16:36:03
Support Our Partners
electricwingman 2017
Slec
Sussex Model Centre
CML
Sarik
Advertise With Us
Latest "For Sale" Ads
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
Magazine Locator
Find RCM&E!
