Member postings for Bruce Richards
Here is a list of all the postings Bruce Richards has made in our forums. Click on a thread name to jump to the thread.
Thread: Servos - need help choosing....
31/10/2010 12:42:56
These Hitecs are a lot cheaper. These Supertecs are good if you want smaller servos.
Thread: Blackhorse Super Air
30/10/2010 09:50:32
Sounds like you have got a dodgy kit. Try and send it back and get it replaced. Failing that I would elongate the holes where the dowels fit into the fuselage so that the wing sits properly in the fuselage cut out.
Thread: Newbie to aeriel photography
29/10/2010 09:04:57
Both Key fob and Gum cams are very similar, I would just take what you can get at a good price. I think some offers supply the memory and some do not. Just make sure you look carefully at what you are getting for your money.
Good Luck
Edited By Bruce Richards - Moderator on 29/10/2010 09:05:20
Thread: Fuel-Proofer
27/10/2010 18:37:20
I have tried water based Ronseal with very poor results. It was on film covering but it went soft and sticky after a few flights.
Edited By Bruce Richards - Moderator on 27/10/2010 18:37:39
Thread: www shopping from HK
26/10/2010 13:38:34
That is a very good example of why I use Paypal, when I can. Sorry that comment doesnot help you now but may do in the future.
Thread: BEC or not to BEC!
25/10/2010 09:36:31
Just remove/cut the red wire from ESC to RX throttle channel and plug battery into any port on the RX.
Thread: Sharps disposal
23/10/2010 14:33:22
I must admit I just chuck mine in the bin. Is that bad
Thread: AA batteries
18/10/2010 13:18:21
I have to agree with the two posts above. You can buy good quality 4 cell AA pack in both flat and square arrangements. Making them yourself has no benefits that I can see.
Thread: Max current for Enya 3 glo plug.
18/10/2010 08:57:10
If your prop is coming loose when you are flicking it then it is way too loose. You can apply quite a lot of torque. If your spanner is short say 4-6 inches then you can give it a rally good yank. I find that the prop cuts into my hand to tell me to stop yanking on the spanner.
Thread: Prolapsed disc
16/10/2010 09:43:57
I had that and I feel for you. I had an operation to remove the disk 20 years ago (I was about your age) and its been very good ever since then. I still get some pain now and again but nothing like it used to be. The Doc should have prescribed some STRONG pain killers. I had Dystalgesic which was good but I am not sure if they still use them. I suggest that if you are suffering go back to the Doc and get some more/better drugs
Edited By Bruce Richards - Moderator on 16/10/2010 09:45:03
Thread: Electrifying Super 60
14/10/2010 17:41:41
I think you could get away with a lot less than 550W in a Super 60. Its a very floaty model and I 300-350W should do the trick. Having said tghat I have never done it myself. My Super 60 flys on an old 20FS.
Edited By Bruce Richards - Moderator on 14/10/2010 17:42:45
Thread: Greetings
04/10/2010 07:12:41
Welcome back and I am sure you will enjoy the forum.
Thread: Seagull Sparrow Hawk 1.8m ARTF
27/09/2010 07:41:17
Have you seen this thread?
Thread: The Big Ship - first build help
25/09/2010 10:23:43
The problem with Electric power is that there are so many variables. So the way to simplify is to make some fixed (not really fixed but just a stake in the ground) decisions to start with. As Tim says start with a decision on what sort of prop size you want and work from there. Another option is to start with the battery and work towards the prop.
If while you are doing your calculation it is just not working out, say the current is just too high, then try and start from a different fixed point.
Thread: Hi all
24/09/2010 17:22:02
Hi Huggy you discovered the best bit of RCM&E. The forum
Thread: budget receivers
24/09/2010 13:40:47
They will be fine with that Tx.
Thread: Hi from Max
23/09/2010 15:33:00
Welcome Max. Looking forward to hearing your story.
Thread: E flite Blade SR
22/09/2010 13:27:54
Eflite  stuff comes from Horizon Hobbies I think so it would be worth contacting them regarding this problem. Usually the provide outstanding service in such situations.
Thread: Ben Buckle - Mini Super
21/09/2010 21:27:44
I totally agree. Wing bands is the only way to go.
Thread: Skylon
21/09/2010 18:36:46
Oh so cynical and oh so true.
Magazine Locator
Find RCM&E!
Latest Forum Posts
Support Our Partners
Sussex Model Centre
CADMA
Slec
CML
electricwingman 2017
Wings & Wheels 2019
Cambridge Gliding Club
Sarik
Advertise With Us
Latest "For Sale" Ads
Q: The effects of Coronavirus
 Yes - for the first time
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
